Problems with SainSmart Mega 2560 R3
October 20, 2013 10:52AM
I tried to upload sketches (marlin) to the board but I always got a timeout error and the sketch was not uploaded.
I am using Win 7.
The board is found by windows and COM2 or COM10 is assigned.
I have tried various cables.
Changed the USB port.
Used an additional external poweradapter ( 7V)
The yellow pin13 LED is constantly blinking.
Then I tried one hint from another forum and pressed shift while uploading to execute the "verbose" mode.
I was able to upload "BlinK" but it also didn´t worked.
No timeout message but a not sync message appeared.
Later I uploaded the RAMPS test sketch [reprap.org] using the same method (shift+upload). But I do not get an connect neither in cura nor a reaction when I attach the steppers and run the RAMPs test sketch.
The blinking of pin13 will also appear if there is no USB cable connected but only the powersupply.
Any idea on how to solve this problem?
Edited 2 time(s). Last edit at 10/20/2013 11:37AM by maboo.
Blogs:
Meine 3D Druck Abenteuer
[3dptb.blogspot.de]
FLSUN Delta Drucker für Deutschland
[flsun-deutschland.blogspot.com]
Books on 3D patents:
[goo.gl] (english)
[www.amazon.de] (deutsch)
Re: Problems with SainSmart Mega 2560 R3
October 21, 2013 01:21AM
Have you installed the Arduino driver from within the Arduino s/ware?
_______________________________________
Waitaki 3D Printer
October 21, 2013 07:22AM
I just received the following note from Sainsmart:
„Dear friend, Have a nice day. Glad to receive your e-mail. Thank you so much for contacting us about this issue. No any worry about the item, we are glad to help you. Yes, we had confirmed this issue with our engineer. He said the code is not correct. Would you please open this link for the code? [s3-ap-northeast-1.amazonaws.com] Do you install the drive? Drive Path should be arduino-1.0.1-windows\arduino-1.0.1\drivers And test with our code, you will use the item well. Do you choose the correct board on your software and correct COM port? May we suggest you to test again with our instructions? And would you tell us the detailed problem if you still can not use the item well? We will confirm the problems with our engineer. No any worry about the item, we will do our best to help you and make you satisfied. Waiting your early reply. Best wishes for you and your family. Lily Lee“
Now what is this RAR file, a driver? a new bootloader? Does she mean driver when she says "drive"? I am using WIn 7 and I have installed Arduino IDE 1.5.4. Should I really go back to 1.0.1? The 2650 V3 is brandnew.
Blogs:
[3dptb.blogspot.de]
[goo.gl] (english)
October 21, 2013 07:39AM
Hi. Did you configured baud rate?
October 21, 2013 08:56AM
Which baud rate?
I have tried various settings in the systemtray starting with 9600 but Arduino SW would always come up with "overriding baudrate to 115000"
I have not altered the baud rate in the config file. Should I try this as well?
Blogs:
[3dptb.blogspot.de]
[goo.gl] (english)
October 21, 2013 02:45PM
Now this is "funny". The downloadlink they gave me is a packed PDF for the UNO R3 not the MEGA 2560.
The company name is ProfitVanity(!) from China. The controller (is said to be) one from Saint Smart.
Let´s see if they come up with a solution or if this remains blabla....
Edited 1 time(s). Last edit at 10/21/2013 03:23PM by maboo.
Blogs:
[3dptb.blogspot.de]
[goo.gl] (english)
October 21, 2013 06:19PM
I would step back to Arduino 1.05. 1.5x is not production ready.
The 1.5x series (which is still pretty beta) are only properly tested on the Due (SAM3X), and support for the Mega and other (AVR) boards isn't really their priority.
Once 1.5x has settled down, they'll update the AVR side of things.
