[Rumba + FGS-LCD-C] USB connection and flashing problem May 03, 2014 04:47AM |
avrdude: verification error, first mismatch at byte 0x3e000
0x0d != 0xff
avrdude: verification error; content mismatch
Re: [Rumba + FGS-LCD-C] USB connection and flashing problem May 04, 2014 04:09AM |
Pronterface connexion feedback
“Connexion en cours...
start
Imprimante connectée.
echo: External Reset
Marlin1.0.0
echo: Last Updated: May 4 2014 09:33:24 | Author: Couby
Compiled: May 4 2014
echo: Free Memory: 3254 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoteps per unit:
echo: M92 X78.74 Y78.74 Z533.33 E836.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z5.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z100 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:pID settings:
echo: M301 P22.20 I1.08 D114.00
Error:0
[ERROR] Error:0
: Extruder switched off. MINTEMP triggered !
Error:printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
[ERROR] Error:printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Re: [Rumba + FGS-LCD-C] USB connection and flashing problem May 04, 2014 05:56AM |
Re: [Rumba + FGS-LCD-C] USB connection and flashing problem May 04, 2014 06:33AM |
