[Rumba + FGS-LCD-C] USB connection and flashing problem
May 03, 2014 04:47AM
Hi, I'm having some problems trying to run my RUMBA + FGS-LCD-C with my in progress build new printer (TAZ).
I wanted to check my first wirings (X motor, X endstop and FGS-LCD-C).
A picture :
The first problem I have is that the USB connection doesn't work. A detail in case it can be usefull, the TR/RX lights were off all the time.
I followed the instructions reported on the RepRap wiki (DFU mode...), without any success.
So I flashed the 16u2 chip with my USBtinyISP and the firmware given on RepRap wiki.
Since then I have the TX/RX orange lights on all the time, no blink, like on the picture.
No USB connection under Windows XP. I have something using Ubuntu.
So using Arduino IDE under Ubuntu, I tried to upload Marlin firmware.
It doesn't work reporting timeout issues.
I connected my USBtinyISP on ATMega2560. By this way it seems the firmware upload is working (I'm not an expert, I don't really know if it is effectively the case).
But, if now I have light in the LCD, nothing displayed, it doesn't work. And no connection with host.
So I tried to flash the ATMega2560 with my USBtinyISP.
I got a verification at the end :
avrdude: verification error, first mismatch at byte 0x3e000
0x0d != 0xff
avrdude: verification error; content mismatch
I searched the net and it is unclear if it is a real problem or not. Some are reporting their boards working after such flash with this message.
What I can report in my case is that it didn't change anything. I still can't upload firmware directly via USB, and what I think I've uploaded via USBtinyISP, behaves the same way (light in LCD but it deosn't work).
Any help, check, idea or orientations are welcome.
Regards
PS : I reported a ticket with my order reference.
open | download - Configuration.h.zip (10.8 KB)
Re: [Rumba + FGS-LCD-C] USB connection and flashing problem
May 04, 2014 04:09AM
phd0 oriented me on a USB cable issue, on reprapdiscount forum. And effectively I had a problem with this cable !
I tried with another USB cable and... it works :cool:.
USB connection is good. I can upload the firmware and connect Printrun.
I still have nothing on LCD screen but I think it is because almost everything is not wired (just X axis...).
If someone can confirm that point, that would comfort me yawning smileyops:.
Here is what I get from Pronterface :
Pronterface connexion feedback
“Connexion en cours...
start
Imprimante connectée.
echo: External Reset
Marlin1.0.0
echo: Last Updated: May 4 2014 09:33:24 | Author: Couby
Compiled: May 4 2014
echo: Free Memory: 3254 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoconfused smileyteps per unit:
echo: M92 X78.74 Y78.74 Z533.33 E836.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z5.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z100 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:pID settings:
echo: M301 P22.20 I1.08 D114.00
Error:0
[ERROR] Error:0
: Extruder switched off. MINTEMP triggered !
Error:printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
[ERROR] Error:printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
Merci beaucoup Philippe, j'avance smiling smiley.
Bon dimanche.
May 04, 2014 05:56AM
I do confirm that with some more wiring, it works smiling smiley, except for the FGS-LCD-C sad smiley.
I can command X avis movements. X endstop is working. So I think the RUMBA board is fine now.
Yet for the FGS-LCD-C, I still have a blue screen sad smiley.
I also notice a SD init fail when connecting the printer in Pronterface feedback messages.
Any idea ?
I paid attention installing additionnal libraries (8Uglib).
May 04, 2014 06:33AM
Following this topic recommendation : [forum.reprapdiscount.com] .
I switched cables of the LCD screen and now it all works. smiling smiley
Have all a nice sunday smiling smiley.
