2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 04, 2014 07:41PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 04, 2014 07:42PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 05, 2014 04:45AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 05, 2014 04:46AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 06, 2014 07:30AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 06, 2014 07:35AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 06, 2014 09:21PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 07, 2014 09:38PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 01:14AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 01:17AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 01:33AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 02:34PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 02:41PM |
Cefiar
Are the stepper drivers set for 1/16th microsteps (this is what the jumper settings are for? Those numbers in Marlin are fairly specific for fairly standard setups for drivers set up for 1/16th microstep. They will be different if you're using 1/8th microstep or 1/32nd microstep jumper setting for your drivers.
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 08, 2014 11:34PM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 09, 2014 05:20AM |
Re: 2nd Build Ord Bot: Help ! Stepper Motor Problem ![]() June 09, 2014 05:30AM |
