Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 17, 2014 04:31PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 17, 2014 06:47PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 17, 2014 09:22PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 17, 2014 11:50PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 12:07AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 11:08AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 12:32PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 01:28PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 01:45PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 02:40PM |
Yes, this takes care of bypassing the 11amps ptc fuse. This is main thing to do.Quote
1. Solder wire from + input terminal to + output terminal
2. Solder wire going from - input terminal to onboard MOSFET source
3. Solder wire going from MOSFET drain to - output terminal
Is that right? If so, that's pretty darn simple. Basically I'm using all of the stock onboard components, and just bypassing the 11A fuse, and adding a thick gauge wire in addition to the thin traces.
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 03:00PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 03:21PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 18, 2014 03:40PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 19, 2014 10:15AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 19, 2014 03:54PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 19, 2014 06:24PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 19, 2014 10:18PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 20, 2014 10:38AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 20, 2014 11:42AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 20, 2014 04:43PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 20, 2014 04:47PM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 22, 2014 07:20AM |
Re: Help Wiring Large (12"x12") Heatbed Through Relay or MOSFET June 23, 2014 10:21AM |
