Why are there no AT90USB1287 boards ? November 24, 2014 04:43AM |
Re: Why are there no AT90USB1287 boards ? November 24, 2014 02:28PM |
Re: Why are there no AT90USB1287 boards ? November 24, 2014 02:47PM |
Re: Why are there no AT90USB1287 boards ? November 24, 2014 07:10PM |
Re: Why are there no AT90USB1287 boards ? November 24, 2014 09:55PM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Why are there no AT90USB1287 boards ? November 25, 2014 12:33AM |
dc42
The AT90USB line might have been a good choice a few years ago, but it is still an 8-bit processor. The 32-bit ARM-core ATSAM processors are so inexpensive now that there is no longer any reason to use an 8-bit processor in a system as large as a 3D printer controller. Many of the ATSAM series have USB built in. Some have Ethernet as well, such as the ATSAM3X used in the Arduino Due (which sadly does not make the Ethernet interface available) and the Duet electronics for 3D printers (which does).
Personally I don't think using an Arduino core is a significant advantage. The Arduino IDE is awful compared to typical IDEs for C++, and while the Arduino core is very helpful for novices to microcontroller programming, it gets in the way when doing serious software development.
Dust
hey, open your eyes...
http://reprap.org/wiki/Printrboard Atmel AT90USB1286 Microcontroller (or AT90USB1287 drop-in compatible for 20mhz support)
http://reprap.org/wiki/Teensylu also a AT90USB1286 (same as AT90USB1287, but 16mhz)
http://reprap.org/wiki/SAV_MKI also a AT90USB1286 (same as AT90USB1287, but 16mhz)
cdru, yip works fine in Arduino IDE, you have to add the cpu files, like you do for a 644p
NB these micros can't keep up with true usb speeds, but I agee is nicer than serial over usb implmentation that has baud rates.
Re: Why are there no AT90USB1287 boards ? November 25, 2014 04:23AM |
Chri
i know that the Atmel is not so fast compaired to a 32 bit arm, but when i look to my Sanguino i can print with 400mm/s from SD-Card including a Panelolu2 so its still fast enough for the job, and most people are printing below 200mm/s , so i think the Atmel still has a lot of resources left and there are also no single board solutions that are small and inexpensive afaik.
Re: Why are there no AT90USB1287 boards ? November 25, 2014 06:21AM |
Re: Why are there no AT90USB1287 boards ? November 25, 2014 06:03PM |
