Re: New MKS SBASE Smoothieware-compatible board from China July 06, 2015 09:07AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 06, 2015 02:15PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 06, 2015 04:00PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 07, 2015 06:28PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 09, 2015 12:26PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 09, 2015 02:54PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 13, 2015 10:43AM |
That's very odd. I removed the SBASE and connected the exact same printer in the exact same configuration to a Smoothieboard and the temperature is rock solid. My SBASE is almost unusable as a 3D printer controller due to the noise making the nozzle temperature jump all around. I'm going to try updating the firmware because the smoothieboard has a much newer version of the firmware, which maybe adds some software filtering to the ADCs.Quote
innkeeper
I've had no such issues in maintaining hot end temp, and so far tested it with a Pico, a e3d v4 and a makergear v3b. Also auto tune seems to work fine for me.
Re: New MKS SBASE Smoothieware-compatible board from China July 13, 2015 05:49PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 14, 2015 05:31AM |
tadawson
FWIW, I have gotten cables with the LCD panels with cables both ways, it appears that the Chinese have refused to accept anything as a standard . . .
Re: New MKS SBASE Smoothieware-compatible board from China July 14, 2015 09:36AM |
I tried installing the newer firmware from the Smoothieboard to the SBASE (which is awesomely simple to do) to see if it worked any better but it does not. The temperature still jumps around by more than a degree, which leaves the software struggling to keep the temperature stable. For fun I tried hooking it to the bed temperature input and it jumps around as well so I think it is an inherent flaw in this specific board or the layout in general. The variation can be kept small by selecting conservative PID constants, I used P=30 I=1 D=15.Quote
CapnBry
My GLCD was missing a surface mount resistor so the backlight didn't work reliably. Because it is an open source design I just looked at the schematics and tracked it down and said "Wait a second, there's no resistor here". It was a size I happened to have on hand so I just soldered a new one in. As I did with the head-mounted magnifier, I found the resistor that was supposed to be there a couple of inches away stuck to the LCD pins. Good thing it had the holographic sticker that said "QC" on it so I know it passed all the tests!Quote
Re: New MKS SBASE Smoothieware-compatible board from China July 17, 2015 05:42AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 17, 2015 10:57PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 18, 2015 03:51PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 22, 2015 05:20AM |
flyway97
To CapnBry ,
Thanks for your trying our MKS SBASE Smoothieware-compatible board and find the problem in maintaining hotend temperature.After we compare the origenal Smoothieware oard and our MKS Sbase. We find that when we use the DC-DC converter R-78E5.0-1.0 as origenal Smoothieware, it is OK. And our DC-DC conver L5970D is using in our MKS series Board for 2 years with Marlin and other firmware, it is OK. So we think maybe the Smoothieware firmware cause the problem. We are trying to check the firmware further and solve the problem.
Re: New MKS SBASE Smoothieware-compatible board from China July 22, 2015 08:37AM |
There's two reasons those 100K thermistors work better. At 100C (typical bed temperatures), there's a lot more resistance than at 230C hotend temperatrures. This means less variation in the temperature. They're also 3950 beta compared to 4265 beta for the Semitec, which means they have less resistance change per degree C. If you measure the resistance at 100C you're probably getting like 6500 ohms, but at 230C it would be closer to like 400 ohms which makes a big difference in the noise.Quote
GeoDave
UPDATE 7/18: I hooked up the heated bed using some 100k thermistors I ordered here [www.aliexpress.com]. The temperature is holding solid with no problem. It does jump up/down one degree every once in a while but no big jumps like on the hotend.
Re: New MKS SBASE Smoothieware-compatible board from China July 22, 2015 10:09PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 26, 2015 06:18PM |
Re: New MKS SBASE Smoothieware-compatible board from China July 30, 2015 05:00AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 30, 2015 08:19AM |
lmclaren
Any updates? I am waiting to purchase a board but need to know if the problem is resolved.
thanks
Re: New MKS SBASE Smoothieware-compatible board from China July 31, 2015 06:22AM |
Re: New MKS SBASE Smoothieware-compatible board from China July 31, 2015 10:54PM |
. MKS SBASE V1.1 will be saled about August or Setpember.
Re: New MKS SBASE Smoothieware-compatible board from China August 01, 2015 05:18AM |
flyway97
add heatsinks on Drv8825, just as frodriguez96 said..
Re: New MKS SBASE Smoothieware-compatible board from China August 02, 2015 02:09AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 03, 2015 01:29PM |
flyway97
we have found the reason of temperature problem come from DC-DC, L5970D 's Switching Frequency is not enough , we are testing new DC-DC now . This problem will be solve on on MKS SBASE V1.1 , and will add pins used for Max31855 thermocouples ,add heatsinks on Drv8825, just as frodriguez96 said.. MKS SBASE V1.1 will be saled about August or Setpember.
Re: New MKS SBASE Smoothieware-compatible board from China August 03, 2015 02:38PM |
innkeeper
flyway97
flyway97: is there any modification that we can do to the 1.0 boards to fix this issue or if not, anything that can be done for the existing 1.0 board owners that have the issue?
Re: New MKS SBASE Smoothieware-compatible board from China August 03, 2015 10:42PM |
Re: New MKS SBASE Smoothieware-compatible board from China August 04, 2015 02:35AM |
flyway97
innkeeper , frodriguez96 : change the DC-DC from L5970D to R-78E-5.0 can solve this problem on V1.0.
arthurwolf : yes, DRV8825 and A4988 's radiating is on the chip bottom, so the best method to cool them is by the PCB, so we have carefuly deal with it on our PCB. But if the current up to 1.5a or higher, the temperature is also too high in spite of good PCB design. So add heatsink is useful(not include those small heatsinks ) .The best way to cool is use fan to blow the board, at this time heatsinks is useful too.
Re: New MKS SBASE Smoothieware-compatible board from China August 04, 2015 05:50AM |
Re: New MKS SBASE Smoothieware-compatible board from China August 04, 2015 04:55PM |
flyway97
1. take off component D5 and F3;
2. Connect R-78E-5.0's 3 pins to the 3 solder joints as shown in the picture,
(pin1 to label 1, pin2 to label 2, pin3 to label 3),then it can work well.
Re: New MKS SBASE Smoothieware-compatible board from China August 04, 2015 05:39PM |
Boxcar
flyway97
Thank you! My MKS SBASE should show up in a week or so. I ordered a few R-78E5.0-1.0 from Digikey so I'll report back once I have everything setup.
