SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 23, 2015 02:29PM |
1 Arduino Nano socket.
4 Pololus sockets (X,Y,Z y E)
3 Line in for X_MIN, Y_MIN and Z_MIN endstops.
2 Line in for Hotend and heated bed sensors.
3 Mosfets outputs for Heater, Fan and Bed (this last with independent power supply).
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 23, 2015 02:46PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 24, 2015 01:51PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 24, 2015 05:25PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 24, 2015 10:26PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 25, 2015 02:04AM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 25, 2015 02:04PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 25, 2015 06:08PM |
tatubias
Please check the wiki Site There you will be able to download :
* Firmware TeaCup_-_CoreXY
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 25, 2015 06:44PM |
Traumflug
Yupp, good idea!
High current tracks like 12/24V for the steppers and corresponding GND are a bit thin for my taste. Here's a track width calculator: [www.circuitcalculator.com]
tatubias
Would you mind to fully integrate this into official Teacup? I've seen you dropped a config.h, but unfortunately the use of this file in this way is deprecated already in favour of Configtool. With full integration we can both take advantage of each other, you get our work and we get yours.
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 26, 2015 06:24AM |
tatubias
Yes its my idea to develop the config for the new version of teacup . the issue was that I did try to run the tool py under windows an I got error so I need to install lunix in a VM an do the test.
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 26, 2015 04:14PM |
Traumflug
tatubias
Thanks for the report. Configtool should definitely work under Windows (and Mac OS X). Prerequisites are about the same as those of Pronterface.
Could you copy the error message (or whatever happened)? Thanks.
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 26, 2015 07:44PM |
tatubias
ImportError: No module named wx
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 27, 2015 09:01AM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 28, 2015 01:37PM |
Traumflug
Another thing is, your Python might default to Python3, which can't be supported, because there's no wxPython for Python3. Typing "python2 configtool.py" should help.
And thanks to your error report we managed to add two commits giving better hints: [github.com]
i did install wxPython and did work perfect. /***************************************************************************\ * * * 1. CPU * * * \***************************************************************************/ /** \def CPU_TYPE CPU types a user should be able to choose from in configtool. All commented out. */ //#define CPU_TYPE ATmega328 /** \def CPU CPU actually present on the board. */ #define CPU atmega328 /** \def F_CPU_OPT CPU clock frequencies a user should be able to choose from in configtool. All commented out. */ //#define F_CPU_OPT 16000000UL /** \def F_CPU Actual CPU clock rate. #ifndef required for Arduino compatibility. */ #ifndef F_CPU #define F_CPU 16000000UL #endif /** \def MOTHERBOARD This is the motherboard, as opposed to the extruder. See extruder/ directory for GEN3 extruder firmware. */ #define MOTHERBOARD /***************************************************************************\ * * * 2. PINOUTS * * * \***************************************************************************/ #include "../arduino.h" #define X_STEP_PIN DIO12 #define X_DIR_PIN DIO11 #define X_MIN_PIN AIO0 //#define X_MAX_PIN xxxx #define X_ENABLE_PIN DIO10 #define X_INVERT_DIR #define X_INVERT_MIN //#define X_INVERT_MAX xxxx #define X_INVERT_ENABLE #define Y_STEP_PIN DIO9 #define Y_DIR_PIN DIO8 #define Y_MIN_PIN AIO1 //#define Y_MAX_PIN xxxx #define Y_ENABLE_PIN DIO10 #define Y_INVERT_DIR #define Y_INVERT_MIN //#define Y_INVERT_MAX xxxx #define Y_INVERT_ENABLE #define Z_STEP_PIN DIO4 #define Z_DIR_PIN DIO2 #define Z_MIN_PIN AIO2 //#define Z_MAX_PIN xxxx #define Z_ENABLE_PIN DIO7 #define Z_INVERT_DIR #define Z_INVERT_MIN //#define Z_INVERT_MAX xxxx #define Z_INVERT_ENABLE #define E_STEP_PIN AIO4 #define E_DIR_PIN AIO5 #define E_ENABLE_PIN AIO3 //#define E_INVERT_DIR xxxx #define E_INVERT_ENABLE //#define PS_ON_PIN DIO9 //#define PS_MOSFET_PIN xxxx //#define STEPPER_ENABLE_PIN DIO8 //#define STEPPER_INVERT_ENABLE xxxx /** \def DEBUG_LED_PIN Enable flashing of a LED during motor stepping. Disabled by default. Uncommenting this makes the binary a few bytes larger and adds a few cycles to the step timing interrrupt in timer.c. Also used for precision profiling (profiling works even without actually having such a LED in hardware), see [reprap.org] */ //#define DEBUG_LED_PIN DIO13 /***************************************************************************\ * * * 3. TEMPERATURE SENSORS * * * \***************************************************************************/ #ifndef DEFINE_TEMP_SENSOR #define DEFINE_TEMP_SENSOR(...) #endif /** \def TEMP_MAX6675 TEMP_THERMISTOR TEMP_AD595 TEMP_PT100 TEMP_INTERCOM Which temperature sensor types are you using? Leave all used ones uncommented, comment out all others to save binary size and enhance performance. */ //#define TEMP_MAX6675 #define TEMP_THERMISTOR //#define TEMP_AD595 //#define TEMP_PT100 //#define TEMP_INTERCOM /** \def TEMP_SENSOR_PIN Temperature sensor pins a user should be able to choose from in configtool. All commented out. */ //#define TEMP_SENSOR_PIN AIO0 //#define TEMP_SENSOR_PIN AIO1 /** \def DEFINE_TEMP_SENSOR Define your temperature sensors here. One line for each sensor, only limited by the number of available ATmega pins. Name must match the name of the corresponding heater. If a heater "extruder" exists, a temperature sensor of that name has to exist as well. Same for heater "bed". There can be one sensor without corresponding heater, name it "noheater". Types are same as TEMP_ list above - TT_MAX6675, TT_THERMISTOR, TT_AD595, TT_PT100, TT_INTERCOM. See list in temp.c. The "additional" field is used for TT_THERMISTOR only. It defines the name of the table(s) in thermistortable.h to use. This name is arbitrary, often used names include THERMISTOR_EXTRUDER and THERMISTOR_BED. Also, several sensors can share the same table, which saves binary size. For a GEN3 set temp_type to TT_INTERCOM and temp_pin to AIO0. The pin won't be used in this case. */ //DEFINE_TEMP_SENSORS_START // name type pin additional DEFINE_TEMP_SENSOR(extruder, TT_THERMISTOR, AIO7, THERMISTOR_EXTRUDER) DEFINE_TEMP_SENSOR(bed, TT_THERMISTOR, AIO6, THERMISTOR_BED) // r0 beta r2 vadc //TEMP_TABLE EXTRUDER (100000, 4092, 4700, 5.0) //TEMP_TABLE BED (100000, 4092, 4700, 5.0) //DEFINE_TEMP_SENSORS_END /***************************************************************************\ * * * 4. HEATERS * * * \***************************************************************************/ #ifndef DEFINE_HEATER #define DEFINE_HEATER(...) #endif /** \def HEATER_PIN Heater pins a user should be able to choose from in configtool. All commented out. */ //#define HEATER_PIN DIO8 //#define HEATER_PIN DIO9 //#define HEATER_PIN DIO10 /** \def DEFINE_HEATER Define your heaters and devices here. To attach a heater to a temp sensor above, simply use exactly the same name - copy+paste is your friend. Some common names are 'extruder', 'bed', 'fan', 'motor', ... names with special meaning can be found in gcode_process.c. Currently, these are: HEATER_extruder (M104) HEATER_bed (M140) HEATER_fan (M106) Devices don't neccessarily have a temperature sensor, e.g. fans or milling spindles. Operate such devices by setting their power (M106), instead of setting their temperature (M104). Also note, the index of a heater (M106 P#) can differ from the index of its attached temperature sensor (M104 P#) in case sensor-less devices are defined or the order of the definitions differs. The first defined device has the index 0 (zero). Set 'pwm' to ... 1 for using PWM on a PWM-able pin and on/off on other pins. 0 for using on/off on a PWM-able pin, too. Using PWM usually gives smoother temperature control but can conflict with slow switches, like solid state relays. PWM frequency can be influenced globally with FAST_PWM, see below. */ //DEFINE_HEATERS_START // name port pwm DEFINE_HEATER(extruder, PD3, 1) DEFINE_HEATER(bed, PD6, 1) DEFINE_HEATER(fan, PD5, 1) #define HEATER_EXTRUDER HEATER_extruder #define HEATER_BED HEATER_bed #define HEATER_FAN HEATER_fan //DEFINE_HEATERS_END /***************************************************************************\ * * * 5. COMMUNICATION OPTIONS * * * \***************************************************************************/ /** \def BAUD Baud rate for the serial RS232 protocol connection to the host. Usually 115200, other common values are 19200, 38400 or 57600. Ignored when USB_SERIAL is defined. */ //#define BAUD 115200 /** \def XONXOFF Xon/Xoff flow control. Redundant when using RepRap Host for sending G-code, but mandatory when sending G-code files with a plain terminal emulator, like GtkTerm (Linux), CoolTerm (Mac) or HyperTerminal (Windows). */ //#define XONXOFF /** \def USB_SERIAL Define this for using USB instead of the serial RS232 protocol. Works on USB-equipped ATmegas, like the ATmega32U4, only. */ //#define USB_SERIAL
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 28, 2015 02:43PM |
* 3. TEMPERATURE SENSORS Old CFG //#define TEMP_SENSOR_PIN AIO0 //#define TEMP_SENSOR_PIN AIO1 New CFG //#define TEMP_SENSOR_PIN AIO7 //#define TEMP_SENSOR_PIN AIO6 * 4. HEATERS Old CFG //#define HEATER_PIN DIO8 //#define HEATER_PIN DIO9 //#define HEATER_PIN DIO10 New CFG //#define HEATER_PIN PD3 //#define HEATER_PIN PD6 //#define HEATER_PIN PD5
* 1. CPU *
/** \def CPU_TYPE
commented out.
//#define CPU_TYPE atmega328
/** \def CPU
/** \def F_CPU_OPT
All commented out.
/** \def F_CPU
#ifndef F_CPU
#endif
#define MOTHERBOARD
* 2. PINOUTS *
[reprap.org]
#endif
performance.
All commented out.
"noheater".
// r0 beta r2 vadc
* 4. HEATERS *
#endif
/** \def HEATER_PIN
commented out.
HEATER_bed (M140)
HEATER_fan (M106)
Set 'pwm' to ...
// name port pwm
/** \def BAUD
is defined.
/** \def XONXOFF
//#define XONXOFF
/** \def USB_SERIAL
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 28, 2015 05:38PM |
* 6. MECHANICAL/HARDWARE *
/** \def KINEMATICS_STRAIGHT KINEMATICS_COREXY
This defines the type of kinematics your printer uses. That's essential!
Valid values (see dda_kinematics.h):
KINEMATICS_STRAIGHT
Motors move axis directions directly. This is the
traditional type, found in many printers, including
Mendel, Prusa i3, Mendel90, Ormerod, Mantis.
KINEMATICS_COREXY
A bot using CoreXY kinematics. Typical for CoreXY
are long and crossing toothed belts and a print head
moving on the X-Y-plane.
#define KINEMATICS KINEMATICS_COREXY
/** \def STEPS_PER_M_X STEPS_PER_M_Y STEPS_PER_M_Z STEPS_PER_M_E
Steps per meter ( = steps per mm * 1000 ), calculate these values
appropriate for your machine.
All numbers are integers, so no decimal point, please :-)
Valid range: 20 to 4'0960'000 (0.02 to 40960 steps/mm)
#define STEPS_PER_M_X 167600
#define STEPS_PER_M_Y 167600
#define STEPS_PER_M_Z 4571428
#define STEPS_PER_M_E 678400
/** \def MAXIMUM_FEEDRATE_X MAXIMUM_FEEDRATE_Y MAXIMUM_FEEDRATE_Z MAXIMUM_FEEDRATE_E
Used for G0 rapid moves and as a cap for all other feedrates.
#define MAXIMUM_FEEDRATE_X 7200
#define MAXIMUM_FEEDRATE_Y 7200
#define MAXIMUM_FEEDRATE_Z 200
#define MAXIMUM_FEEDRATE_E 960
/** \def SEARCH_FEEDRATE_X SEARCH_FEEDRATE_Y SEARCH_FEEDRATE_Z
Used when doing precision endstop search and as default feedrate. No
SEARCH_FEEDRATE_E, as E can't be searched.
#define SEARCH_FEEDRATE_X 1200
#define SEARCH_FEEDRATE_Y 1200
#define SEARCH_FEEDRATE_Z 72
/** \def ENDSTOP_CLEARANCE_X ENDSTOP_CLEARANCE_Y ENDSTOP_CLEARANCE_Z
When hitting an endstop, Teacup properly decelerates instead of doing an
aprupt stop to save your mechanics. Ineviteably, this means it overshoots
the endstop trigger point by some distance.
To deal with this, Teacup adapts homing movement speeds to what your
endstops can deal with. The higher the allowed acceleration ( = deceleration,
see #define ACCELERATION) and the more clearance the endstop comes with,
the faster Teacup will do homing movements.
Set here how many micrometers (mm * 1000) your endstop allows the carriage
to overshoot the trigger point. Typically 1000 or 2000 for mechanical
endstops, more for optical ones. You can set it to zero, in which case
SEARCH_FEEDRATE_{XYZ} is used, but expect very slow homing movements.
Units: micrometers
Sane values: 0 to 20000 (0 to 20 mm)
Valid range: 0 to 1000000
#define ENDSTOP_CLEARANCE_X 1000
#define ENDSTOP_CLEARANCE_Y 1000
#define ENDSTOP_CLEARANCE_Z 100
/** \def X_MIN X_MAX Y_MIN Y_MAX Z_MIN Z_MAX
Soft axis limits, in mm. Define them to your machine's size relative to what
your host considers to be the origin.
#define X_MIN 0
#define X_MAX 110
#define Y_MIN 0
#define Y_MAX 110
#define Z_MIN 0
#define Z_MAX 85
/** \def E_ABSOLUTE
Some G-code creators produce relative length commands for the extruder,
others absolute ones. G-code using absolute lengths can be recognized when
there are G92 E0 commands from time to time. If you have G92 E0 in your
G-code, define this flag.
This is the startup default and can be changed with M82/M83 while running.
#define E_ABSOLUTE
/** \def ACCELERATION_REPRAP ACCELERATION_RAMPING ACCELERATION_TEMPORAL
Choose optionally one of ACCELERATION_REPRAP, ACCELERATION_RAMPING or
ACCELERATION_TEMPORAL. With none of them defined, movements are done
without acceleration. Recommended is ACCELERATION_RAMPING.
//#define ACCELERATION_REPRAP
#define ACCELERATION_RAMPING
//#define ACCELERATION_TEMPORAL
How fast to accelerate when using ACCELERATION_RAMPING. Start with 10 for
milling (high precision) or 1000 for printing.
Units: mm/s^2
Useful range: 1 to 10'000
#define ACCELERATION 1000
/** \def LOOKAHEAD
Define this to enable look-ahead during *ramping* acceleration to smoothly
transition between moves instead of performing a dead stop every move.
Enabling look-ahead requires about 3600 bytes of flash memory.
#define LOOKAHEAD
/** \def MAX_JERK_X MAX_JERK_Y MAX_JERK_Z MAX_JERK_E
When performing look-ahead, we need to decide what an acceptable jerk to the
mechanics is. Look-ahead attempts to instantly change direction at movement
crossings, which means instant changes in the speed of the axes participating
in the movement. Define here how big the speed bumps on each of the axes is
allowed to be.
If you want a full stop before and after moving a specific axis, define
MAX_JERK of this axis to 0. This is often wanted for the Z axis. If you want
to ignore jerk on an axis, define it to twice the maximum feedrate of this
axis.
Having these values too low results in more than neccessary slowdown at
movement crossings, but is otherwise harmless. Too high values can result
in stepper motors suddenly stalling. If angles between movements in your
G-code are small and your printer runs through entire curves full speed,
there's no point in raising the values.
Units: mm/min
Sane values: 0 to 400
Valid range: 0 to 65535
#define MAX_JERK_X 120
#define MAX_JERK_Y 120
#define MAX_JERK_Z 24
#define MAX_JERK_E 120
* 7. MISCELLANEOUS OPTIONS *
/** \def USE_INTERNAL_PULLUPS
The ATmega has internal pullup resistors on it's input pins which are
counterproductive with the commonly used eletronic endstops, so they should
be switched off. For other endstops, like mechanical ones, you may want to
uncomment this.
#define USE_INTERNAL_PULLUPS
/** \def TEMP_HYSTERESIS
Actual temperature must be target +/- this hysteresis before target
temperature is considered to be achieved. Also, BANG_BANG tries to stay
within half of this hysteresis.
Unit: degree Celsius
#define TEMP_HYSTERESIS 2
/** \def TEMP_RESIDENCY_TIME
Actual temperature must be close to target (within set temperature
+- TEMP_HYSTERESIS) for this long before target is achieved (and a M116
succeeds).
Unit: seconds
#define TEMP_RESIDENCY_TIME 10
/** \def TEMP_EWMA
Smooth noisy temperature sensors. Good hardware shouldn't be noisy. Set to
1.0 for unfiltered data (and a 140 bytes smaller binary).
Instrument Engineer's Handbook, 4th ed, Vol 2 p126 says values of
0.05 to 0.1 are typical. Smaller is smoother but slower adjusting, larger is
quicker but rougher. If you need to use this, set the PID parameter to zero
(M132 S0) to make the PID loop insensitive to noise.
Valid range: 0.001 to 1.0
#define TEMP_EWMA 1.0
/** \def REPORT_TARGET_TEMPS
With this enabled, M105 commands will return the current temperatures along
with the target temps, separated by a slash: ok T:xxx.x/xxx.x B:xxx.x/xxx.x
With this disabled, only temps will be returned: ok T:xxx.x B:xxx.x
Enabling adds 78 bytes to the image.
//#define REPORT_TARGET_TEMPS
/** \def HEATER_SANITY_CHECK
Check if heater responds to changes in target temperature, disable and spit
errors if not largely untested, please comment in forum if this works, or
doesn't work for you!
//#define HEATER_SANITY_CHECK
/** \def EECONFIG
Enable EEPROM configuration storage.
Enabled by default. Commenting this out makes the binary several hundred
bytes smaller, so you might want to disable EEPROM storage on small MCUs,
like the ATmega168.
#define EECONFIG
/** \def BANG_BANG
Drops PID loop from heater control, reduces code size significantly
(1300 bytes!).
//#define BANG_BANG
/** \def BANG_BANG_ON
PWM value for Bang Bang 'on'.
//#define BANG_BANG_ON 255
/** \def BANG_BANG_OFF
PWM value for Bang Bang 'off'.
//#define BANG_BANG_OFF 0
/** \def MOVEBUFFER_SIZE
Move buffer size, in number of moves.
Note that each move takes a fair chunk of ram (107 bytes as of this writing),
so don't make the buffer too big. However, a larger movebuffer will probably
help with lots of short consecutive moves, as each move takes a bunch of
math (hence time) to set up so a longer buffer allows more of the math to
be done during preceding longer moves.
#define MOVEBUFFER_SIZE 8
/** \def DC_EXTRUDER DC_EXTRUDER_PWM
If you have a DC motor extruder, configure it as a "heater" above and define
this value as the index or name. You probably also want to comment out
E_STEP_PIN and E_DIR_PIN in the Pinouts section above.
//#define DC_EXTRUDER HEATER_motor
//#define DC_EXTRUDER_PWM 180
/** \def USE_WATCHDOG
Teacup implements a watchdog, which has to be reset every 250ms or it will
reboot the controller. As rebooting (and letting the GCode sending
application trying to continue the build with a then different Home point)
is probably even worse than just hanging, and there is no better restore
code in place, this is disabled for now.
//#define USE_WATCHDOG
/** \def TH_COUNT
Temperature history count. This is how many temperature readings to keep in
order to calculate derivative in PID loop higher values make PID derivative
term more stable at the expense of reaction time.
#define TH_COUNT 8
/** \def FAST_PWM
Teacup offers two PWM frequencies, 76(61) Hz and 78000(62500) Hz on a
20(16) MHz electronics. The slower one is the default, as it's the safer
choice and reduces MOSFET heating. Drawback is, in a quiet environment you
might notice the heaters and your power supply humming.
Uncomment this option if you want to get rid of this humming and can afford
a hotter MOSFET or want faster PWM for other reasons.
See also: [reprap.org]
//#define FAST_PWM
/** \def PID_SCALE
This is the scaling of internally stored PID values. 1024L is a good value.
#define PID_SCALE 1024L
/** \def ENDSTOP_STEPS
Number of steps to run into the endstops intentionally. As endstops trigger
false alarm sometimes, Teacup debounces them by counting a number of
consecutive positives.
Use 4 or less for reliable endstops, 8 or even more for flaky ones.
Valid range: 1...255.
#define ENDSTOP_STEPS 4
/** \def CANNED_CYCLE
G-code commands in this string will be executed over and over again, without
user interaction or even a serial connection. It's purpose is e.g. for
exhibitions or when using Teacup for other purposes than printing. You can
add any G-code supported by Teacup.
Note: don't miss these newlines (\n) and backslashes (\).
#define CANNED_CYCLE "G1 X100 F3000\n" \
"G4 P500\n" \
"G1 X0\n" \
"G4 P500\n"
* 1. CPU *
/** \def CPU_TYPE
commented out.
/** \def CPU
/** \def F_CPU_OPT
All commented out.
/** \def F_CPU
#ifndef F_CPU
#endif
#define MOTHERBOARD
* 2. PINOUTS *
#define X_INVERT_MAX False
#define Y_INVERT_MAX False
#define Z_INVERT_MAX False
#define E_INVERT_DIR False
#define STEPPER_INVERT_ENABLE False
[reprap.org]
#endif
performance.
All commented out.
"noheater".
// r0 beta r2 vadc
* 4. HEATERS *
#endif
/** \def HEATER_PIN
commented out.
HEATER_bed (M140)
HEATER_fan (M106)
Set 'pwm' to ...
// name port pwm
/** \def BAUD
is defined.
/** \def XONXOFF
//#define XONXOFF
/** \def USB_SERIAL
#define USB_SERIAL
/** \def USB_SERIAL
Add help text here.
#define USB_SERIAL
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 28, 2015 10:23PM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 28, 2015 11:54PM |
f3rDz
enif
Great - I love it!!!
enif, any chance we can have your DIY Tiny OLED I2C full graphics controller connected to this board
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 01:06AM |
f3rDz
[enif, any chance we can have your DIY Tiny OLED I2C full graphics controller connected to this board
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 10:34AM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 11:25AM |
enif
f3rDz
Yes, that would be nice, but I fully agree with tatubias that this is probably asking too much from the Nano - not enough pins and probably also not enough free memory for the graphics library either...
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 11:30AM |
tatubias
Now does teacup support i2c ? Do we have enough space to enable i2c and the library for the display?
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 11:34AM |
Traumflug
Typical for such small controllers is to connect them to a small PC, like a RaspPi. Then you get all the glory, including a web interface, touchscreen, slicer, standalone operations and whatnot.
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 11:36AM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano May 29, 2015 11:37AM |
Traumflug
tatubias
There is some support for displays on the delta branch. Not integrated, yet, currently Configtool has priority.
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano June 09, 2015 11:58AM |
Re: SinapTec AT328.02 is a 3D FDM printer controller board of ultra low cost, Based on Arduino Nano June 12, 2015 10:04AM |
f3rDz
just want to know if there is a possibility of using the arduino micro instead of the nano. since it has more pins, things like lcd and what not
