Re: RADDS work now stable with RepRap Firmware January 07, 2016 12:45AM |
WestonWW
I'm trying to get my hotend fan to turn on when the hotend reaches 40C so I defined M106 P1 T40 H1 but it doesn't seem to work. M106 P1 S255 works fine, although any S value other than 0 turns the fan on, there isn't a gradient to the speed. I may be missing something about this function.
Re: RADDS work now stable with RepRap Firmware January 07, 2016 02:50AM |
WestonWW
Yes, you can have high endstops on some axes and low endstops on others.
How do you do this? I have M574 X2 Y2 Z1 S1 defined for the end stops but I don't know how to change the "S1" without changing all of the end stops. I can rewire, but I would rather have the X,Y wired closed for an additional safety check. My IR probe is normally open and closed when triggered.
The Z steppers wired in series seem to work well so far, I haven't started to print yet though.
Re: RADDS work now stable with RepRap Firmware January 07, 2016 03:51AM |
WestonWW
Re: RADDS work now stable with RepRap Firmware January 07, 2016 10:05AM |
Re: RADDS work now stable with RepRap Firmware January 07, 2016 11:17AM |
WestonWW
I was able to get the endstops configured with M574 X2 Y2 S1 Z1 S0, is it more proper to use the 2 lines like you both have commented?
WestonWW
For the hotend fan, is there a way to configure the function into the firmware where, anytime the hotend heater is active the fan turns on or do I need to write this into my macros and print start gcode? It would be nice if it was in firmware so I don't forget to turn it on.
WestonWW
As far as editing the config files on the SD card, it there an easier way to do this since I don't have an LCD or network access to the board? Right now I'm ejecting the card, editing on my PC and then rebooting the printer. I tried to access the card with Repetier host and Pronterface but couldn't get a response.
Re: RADDS work now stable with RepRap Firmware January 08, 2016 12:00PM |
Re: RADDS work now stable with RepRap Firmware January 08, 2016 06:17PM |
Re: RADDS work now stable with RepRap Firmware January 08, 2016 06:24PM |
dc42
RepRapFirmware on Duet supports file upload over the web interface and full access to the SD card over FTP. But whoever designed the Arduino Due made the strange decision to use an Ethernet-capable chip but not to provide an Ethernet port, even as an add-on. So Due/RADDS doesn't have Ethernet. You can upload and manage gcode files and some configuration files on the SD card over USB from Pronterface or another USB host program, but that's about it.
Re: RADDS work now stable with RepRap Firmware January 08, 2016 06:37PM |
Re: RADDS work now stable with RepRap Firmware January 08, 2016 10:55PM |
Re: RADDS work now stable with RepRap Firmware January 09, 2016 12:58AM |
WestonWW
I'm having an issue getting my Z probing working. I have it hooked up to the Z min endstop pins. It works great for homing. When running G32 (bed.g) M574 P1-3 says the probe is already triggered and P4 doesn't trigger at all. Is it possible to use the Z End (with digital mode IR trigger) as the probe?
Re: RADDS work now stable with RepRap Firmware January 14, 2016 03:04PM |
Re: RADDS work now stable with RepRap Firmware January 15, 2016 06:24AM |
WestonWW
Re: RADDS work now stable with RepRap Firmware January 29, 2016 11:48AM |
Re: RADDS work now stable with RepRap Firmware January 29, 2016 05:54PM |
mundsen
Hi, my 5" LCD arrived today. Connected it to the PanelDUE controller. Then I get the text: Touch the spot, and a black spot - but nothing happens when I touch the spot.
I reflashed the controller using the PanelDue-5.0-1.13 file (image from the cmd after flashing)
Have I done something wrong?
I have not connected it to my RADDS yet - should Iget some menus.. without connecting to RADDS?
I have this LCD panel: [www.ebay.com]
Re: RADDS work now stable with RepRap Firmware January 29, 2016 06:02PM |
Re: RADDS work now stable with RepRap Firmware January 29, 2016 06:31PM |
Re: RADDS work now stable with RepRap Firmware January 29, 2016 06:54PM |
Re: RADDS work now stable with RepRap Firmware January 30, 2016 07:50AM |
Re: RADDS work now stable with RepRap Firmware February 02, 2016 02:13PM |
Re: RADDS work now stable with RepRap Firmware February 02, 2016 02:16PM |
wrreek
I have a RADDS 1.5 on Arduino Due and a RADDS LCD 4 x 20.
I want to set it up with Repetier firmware but I cannot get it to work.
It looks like the RADDS and Arduino are working well but the LCD doesn't.
I need the right uiconfig.h and configuration.h settings.
Can you help me. It cost me two days already.
Can I use repetier firmware 0.92.8?
Thanks a lot in advance.
Re: RADDS work now stable with RepRap Firmware February 02, 2016 03:38PM |
Re: RADDS work now stable with RepRap Firmware February 02, 2016 03:43PM |
Re: RADDS work now stable with RepRap Firmware February 02, 2016 03:51PM |
Re: RADDS work now stable with RepRap Firmware February 02, 2016 04:16PM |
Re: RADDS work now stable with RepRap Firmware February 03, 2016 05:26AM |
Re: RADDS work now stable with RepRap Firmware February 03, 2016 07:46AM |
Re: RADDS work now stable with RepRap Firmware February 03, 2016 07:59AM |
Re: RADDS work now stable with RepRap Firmware February 03, 2016 10:09AM |
Re: RADDS work now stable with RepRap Firmware February 03, 2016 12:11PM |
