Re: RADDS work now stable with RepRap Firmware March 15, 2016 12:44AM |
toxuin
Hello, guys.
Where do I connect a inductive Z probe on RADDS?.. Probe model is LJ18A3-8-Z/BX. I wired it up through a voltage divider so it outputs a 3.2 V when triggered. A perfect replacement for normally-open Z min switch, but a manual for Duet says I need to connect it to E0 endstop. There is also a reference in code to E0_AXIS, but it is not in Pins.h for RADDS.
Re: RADDS work now stable with RepRap Firmware March 15, 2016 01:45PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 01:51PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 04:12PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 05:19PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 07:55PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 08:42PM |
toxuin
I will try it, thank you!
toxuin
Also, I've noticed that although Z probe works, it is very inconsistent. Sometimes it triggers while airborne 100 mm above bed. Does the pin 39 have any pullup\pulldown modes? My sensor is PNP, I use it with 12V, 4.7k and 12k resistors which should produce a ~ 3.3V output.
toxuin
Fun fact: when I connect it to Z endstop pins – it is super-consistent. What am I doing wrong?..
Re: RADDS work now stable with RepRap Firmware March 15, 2016 11:12PM |
Re: RADDS work now stable with RepRap Firmware March 15, 2016 11:58PM |
toxuin
Sorry for the confusion. That's just me and my ~amazing~ soldering skills. Probe now works quite stable, I confirm.
toxuin
I haven't flash a newer version you've linked yet, but I must say that OctoPrint talks with the "old" version just fine. I'll still try newer version with RepetierHost. Flashing with bossac just requires me to boot up a Windows machine.
Re: RADDS work now stable with RepRap Firmware March 16, 2016 05:41PM |
Re: RADDS work now stable with RepRap Firmware March 16, 2016 05:44PM |
Re: RADDS work now stable with RepRap Firmware March 16, 2016 06:05PM |
Re: RADDS work now stable with RepRap Firmware March 16, 2016 07:24PM |
GroupB
Hey dan , I just want to report since the last time, the DVR8825 bin you sent me, everything is fine except its kinda acting weird when I try to manually extract/retract via octoprint. If I ask to extrude 5mm its gonna retract a bunch (20+) if I try to resent the same command, it not working, I have to change the number for it to work and its random if its gonna retract or extrude and how much it gonna, its the same thing if I send a G command via terminal or manually control. But its look OK while I was printing last week. But im kinda afraid its gonna start acting weird sometime during a print and mess up the print.
Could it be the lack of direction delay in the pulse ?
Any progress on getting the pulse delay ( stepper driver brand) in M command ?
Re: RADDS work now stable with RepRap Firmware April 25, 2016 03:17AM |
Re: RADDS work now stable with RepRap Firmware April 25, 2016 04:08AM |
Re: RADDS work now stable with RepRap Firmware April 25, 2016 12:10PM |
shofman
Hi everyone,
As we see here : [github.com] Dan Newman as stopped the developpement of the firmware.
Dan, can you explain your choice please ?
shofman
RADDS can use your new CoreNG firmware ?
Re: RADDS work now stable with RepRap Firmware April 25, 2016 06:02PM |
Re: RADDS work now stable with RepRap Firmware April 25, 2016 06:24PM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 01:37AM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 03:33AM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 04:49AM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 05:34AM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 10:19AM |
angelo
@shofmann
Depends which firmware do you like.
I do not know which expiriance do you have and which 3d-Printer do you would like to build and which add-ons do you would like to implementate?
Reprap-Firmware is a great Firmware.It is programming very good and I like the setup via SD-Card.
Marlin4Due is also great. People, who have expirience with Marlin has it easyer to handle it.
MarlinKimbra is also fine.
I personaly use Repetier-Firmware for my Deltas.
Personaly I like all Firmware.
Have Fun
Angelo
Re: RADDS work now stable with RepRap Firmware April 26, 2016 03:28PM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 04:11PM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 05:35PM |
Re: RADDS work now stable with RepRap Firmware April 26, 2016 05:38PM |
Re: RADDS work now stable with RepRap Firmware April 29, 2016 04:50AM |
Re: RADDS work now stable with RepRap Firmware April 29, 2016 07:49AM |
Re: RADDS work now stable with RepRap Firmware May 26, 2016 02:22AM |
