Duet 0.8.5 with 2 Z-Axis Steppers January 12, 2016 09:14PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 12, 2016 10:33PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 12, 2016 10:57PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 13, 2016 03:53AM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 13, 2016 01:16PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 13, 2016 05:40PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 13, 2016 09:05PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 14, 2016 03:15AM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 15, 2016 03:30PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 15, 2016 07:24PM |
Pole04
I wish I could, but I have been unable to find specs for these cheap Chinese motors. The are from goldenmotors.cn (Part 45HD2037-01 S-22 15/8/27). These steppers came with a kit. I will likely be replacing them in the future, but I need to get the printer up and running again before changing too much.
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 15, 2016 11:26PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 16, 2016 02:45AM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 18, 2016 02:43AM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 18, 2016 02:59AM |
RickRap
I just set up two z-axis steppers on my Duet. I wired them in parallel. These are NEMA 17 from OpenBuilds. I set current to 2.0 in the firmware and they seem to be functioning just fine.
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 18, 2016 05:17PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 19, 2016 08:37PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 28, 2016 01:55PM |
dc42
Here's another RepRapPro wiring diagram, showing how to connect two Z motors in in series without using extra connectors on the optional linear regulator board for the Duet.
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 28, 2016 06:22PM |
Gaou
dc42
david at this diagram the two coils are blue/red and green/black ?
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 29, 2016 05:08PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers January 30, 2016 01:44AM |
Pumlux
I made a adaptor PCB to connect both z-axis stepper towards one driver connector. (currently for parallel mode, but serial mode should be doable also)
Re: Duet 0.8.5 with 2 Z-Axis Steppers February 10, 2016 08:52PM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers February 11, 2016 03:01AM |
Re: Duet 0.8.5 with 2 Z-Axis Steppers March 04, 2016 03:04PM |
