Re: lerdge board 32 bits July 15, 2017 11:53AM |
Anonymous User
Re: lerdge board 32 bits July 15, 2017 01:36PM |
Re: lerdge board 32 bits July 15, 2017 01:53PM |
Re: lerdge board 32 bits July 15, 2017 03:11PM |
Anonymous User
Re: lerdge board 32 bits July 15, 2017 06:57PM |
Re: lerdge board 32 bits July 16, 2017 08:38AM |
Re: lerdge board 32 bits July 17, 2017 12:26AM |
Re: lerdge board 32 bits July 20, 2017 05:35AM |
Graphoid
Just received my Lerdge board to replace a Ramps setup.. 5 days delivery to UK through Aliexpress.
Interestingly, it came with firmware 2.0 Beta 1 installed. Should I downrev to 1.1.7 beta6 or does anyone have this version 2.0 running with no problems, the website still does not list V2 firmware last time I checked (today)
Machine is a Kossel Delta in case that matters
Re: lerdge board 32 bits July 23, 2017 05:26AM |
Re: lerdge board 32 bits July 23, 2017 03:51PM |
Re: lerdge board 32 bits July 23, 2017 06:09PM |
Re: lerdge board 32 bits July 25, 2017 02:17AM |
Re: lerdge board 32 bits July 25, 2017 03:51AM |
Re: lerdge board 32 bits July 25, 2017 12:30PM |
Graphoid
Just started test wiring mine, all seems ok for me so far, no issue with the endstop reversal that titef007 mentioned, but I am rewiring with new connectors anyway so I can have the right cabling from the start.
So far with V2 beta1 firmware, nothing to worry about, other than the interface is a little different to the current documentation, but it is not rocket science and pretty easy to work out. Personally, I like it, stuff you don't need to keep messing with is kept neatly away from poking fingers (remember it is a touch screen control and settings are live, no uploads)
To fiveangle, personally, I would not write off a printer purchase because it uses this board. The one thing you can easily change out later if you really have to is the control electronics, what you cannot so easily change is poorly designed and/or crappy quality mechanicals in your printer, that is what you really want to avoid if you don't want to trash your investment and buy again
Re: lerdge board 32 bits July 25, 2017 12:37PM |
Re: lerdge board 32 bits July 25, 2017 01:36PM |
Re: lerdge board 32 bits July 25, 2017 01:43PM |
Re: lerdge board 32 bits July 25, 2017 01:45PM |
Re: lerdge board 32 bits July 26, 2017 02:16AM |
Re: lerdge board 32 bits July 26, 2017 02:17AM |
Re: lerdge board 32 bits July 26, 2017 02:19AM |
Re: lerdge board 32 bits July 26, 2017 02:25AM |
Re: lerdge board 32 bits July 29, 2017 12:18PM |
Re: lerdge board 32 bits July 29, 2017 12:33PM |
Re: lerdge board 32 bits July 30, 2017 08:43PM |
grimlok2000
[attachment 95523 Untitled.jpg]
hello owners of Lerdhe board
Dual extruder module is published and you can order module on Aliexpress 3Dsway international shopp..New firmware is ready with new UI and will be published next week on offical page.
[www.aliexpress.com]
Keep calm and go shopping,
Anonymous User
Re: lerdge board 32 bits July 30, 2017 09:33PM |
Re: lerdge board 32 bits July 31, 2017 01:17AM |
Re: lerdge board 32 bits July 31, 2017 01:31AM |
Suggy
grimlok2000
I think this will give control over RGB LED aswel
Anonymous User
Re: lerdge board 32 bits July 31, 2017 07:49AM |
