Milling and laser engraving on one machine May 15, 2017 08:50AM |
Re: Milling and laser engraving on one machine May 15, 2017 02:10PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Milling and laser engraving on one machine May 16, 2017 03:19AM |
Re: Milling and laser engraving on one machine May 17, 2017 01:15PM |
Re: Milling and laser engraving on one machine May 18, 2017 02:39AM |
Re: Milling and laser engraving on one machine May 18, 2017 01:43PM |
Re: Milling and laser engraving on one machine May 20, 2017 02:58AM |
Re: Milling and laser engraving on one machine May 20, 2017 11:29AM |
Re: Milling and laser engraving on one machine May 20, 2017 02:20PM |
Re: Milling and laser engraving on one machine May 20, 2017 02:37PM |
cozmicray
Perhaps this should be titled "very expensive British build"
Confounds me how a $21 USD item becomes $130 (100 pound) in UK
They make sure you don't use anything outside the island?
but
The proper UK linear slides should thrill the Queen?
£99.00 with the £500.00 Economy Delivery (used Rolls Royce)
Where is the linear rail production factory located in the UK?
Alternative V rail
[vgrooverail.com]
Re: Milling and laser engraving on one machine May 20, 2017 02:41PM |
o_lampe
I'm also concerned about dust and debris contaminating the rail carriers. My mgn12 have dust covers on the sides, but you can see the balls from below.
Re: Milling and laser engraving on one machine May 20, 2017 05:18PM |
Re: Milling and laser engraving on one machine May 21, 2017 04:08AM |
NEVER TAKE THE BLOCKS off the rail!!!!
Re: Milling and laser engraving on one machine May 21, 2017 01:21PM |
Re: Milling and laser engraving on one machine May 22, 2017 03:28AM |
Re: Milling and laser engraving on one machine June 03, 2017 03:12AM |
Re: Milling and laser engraving on one machine June 03, 2017 04:19AM |
Re: Milling and laser engraving on one machine June 03, 2017 08:30AM |
Re: Milling and laser engraving on one machine June 04, 2017 03:43AM |
Re: Milling and laser engraving on one machine June 05, 2017 03:37AM |
Re: Milling and laser engraving on one machine June 05, 2017 03:54AM |
Re: Milling and laser engraving on one machine June 05, 2017 07:30AM |
Re: Milling and laser engraving on one machine June 07, 2017 07:45AM |
Re: Milling and laser engraving on one machine June 09, 2017 06:53AM |
Re: Milling and laser engraving on one machine June 09, 2017 11:43AM |
Re: Milling and laser engraving on one machine June 10, 2017 07:25AM |
o_lampe
I think 3mm steel will be strong enough to reproduce the brackets in 10mm aluminum. It's like "pulling yourself out of the mud on your own hair" ( quote from Baron Munchhausen stories )
Why tooling plate?
Re: Milling and laser engraving on one machine June 11, 2017 12:14AM |
Re: Milling and laser engraving on one machine June 11, 2017 06:25AM |
Re: Milling and laser engraving on one machine June 11, 2017 12:29PM |
VDX
... the cavities in the common extrusion profiles aren't wide enough to give much of stiffness - better search "light" types with big caities and thin walls.
You can use any 2K epoxy resin with sand - it should be roughly 6% of the resin, compared to the sand volume, for highest stiffnes values ...
Re: Milling and laser engraving on one machine June 11, 2017 12:58PM |
