capture nut vs threaded part
February 08, 2014 01:52AM
I see that on the Prusa i3, the z axis movement is translated by a M5 hex nut from the actuator. If I am making my frame pieces out of aluminum, would threading the part instead of using a capture nut work just as well? Anyone tried this or see any potential problems with it?
Thanks
Re: capture nut vs threaded part
February 09, 2014 12:23PM
Bump
February 10, 2014 01:43PM
It should work. Only problem I can see it that standard threaded rod is somewhat rough, and would wear out the plastic threads relatively quickly.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
February 10, 2014 05:53PM
I think OP is going to cut the threads into aluminium. It will work for a while, but I have noticed that I have to change the nuts in my printer every half a year of intense printing. So when the threads wear out, it would be easier to change only the nut, not the whole part. So either use a captive nut or threaded insert.
February 10, 2014 07:36PM
Yep, I somehow missed that he was going to use aluminum parts. I would still think that wear would be a problem.
