Threadless Leadscrew ??? March 21, 2014 06:59PM |
Re: Threadless Leadscrew ??? March 21, 2014 08:13PM |
cozmicray
36" 12mm stainless steel rod
Rod OD 13mm
cozmicray
between two flange bearings
Re: Threadless Leadscrew ??? March 22, 2014 05:19PM |
Re: Threadless Leadscrew ??? March 22, 2014 06:03PM |
Re: Threadless Leadscrew ??? March 22, 2014 06:10PM |
Re: Threadless Leadscrew ??? March 22, 2014 06:23PM |
Re: Threadless Leadscrew ??? March 22, 2014 07:26PM |
cozmicray
I get the motor stalling out if a crank down on tension screw on rider.
It is very sesitive to tension or rider
Re: Threadless Leadscrew ??? March 27, 2014 05:27PM |
Re: Threadless Leadscrew ??? March 27, 2014 05:41PM |
Re: Threadless Leadscrew ??? March 27, 2014 09:42PM |
Re: Threadless Leadscrew ??? March 27, 2014 11:39PM |
but works for shapes like the vases when some creative slant does not really detract, putting it aside for a while, need to get some other projects done then will add magnetic encoder. that vase completed in 1 piece though and was 120mm tall at the end|
Re: Threadless Leadscrew ??? March 28, 2014 12:31PM |
Re: Threadless Leadscrew ??? March 28, 2014 12:43PM |
Re: Threadless Leadscrew ??? March 28, 2014 01:06PM |
cozmicray
These use guides along with the leadscrew.
Lisa Simpson forbids the use of guides.
Re: Threadless Leadscrew another rider March 30, 2014 03:08PM |
Re: Threadless Leadscrew yet another rider March 30, 2014 03:16PM |
Re: Threadless Leadscrew some video March 30, 2014 05:02PM |
Re: Threadless Leadscrew some video March 30, 2014 08:40PM |
Re: Threadless Leadscrew ??? March 30, 2014 11:02PM |
Re: Threadless Leadscrew ??? March 31, 2014 10:21PM |
Re: Threadless Leadscrew ??? April 01, 2014 05:44PM |
A2
Not a favorable report on this thread.
Threadless Ball Screws
[forums.reprap.org]
Sorry I don't read German
Looking at McMaster Carr, as supplied 17-4 is RC44 which is on the soft side compared to harden rods for bearings RC60.
Corrosion-Resistant High-Strength 17-4 PH Stainless Steel
[www.mcmaster.com]
Hardened Shafts with Tapped Mounting Holes
[www.mcmaster.com]
Soft rods will wear a grove with pressure waves (just like what you find on a gravel road or sandy trail), and will cause the threadless lead screw to bind.
Another concern is the plastic retainer creeping over time, and reduce the pressure/grip.
The threadless bearing that I reviewed used an aluminum block, and I couldn't get it to work on a ground SS rod, because it wore groves into the shaft.
It would stutter, and bind up rather quickly.
I think the last thing to try is to lap a track/race/grove for the bearing to follow into harden steel.
The track wouldn't have to be very deep to guide the bearing, and if you program the stepper to automatically go back and forth it might not take much effort to test it.
Re: Threadless Leadscrew ??? April 01, 2014 10:01PM |
Re: Threadless Leadscrew Inverted April 03, 2014 04:23PM |
Re: Threadless Leadscrew Inverted April 03, 2014 09:38PM |
Re: Threadless Leadscrew Inverted April 04, 2014 12:52PM |
Re: Threadless Leadscrew ??? April 06, 2014 03:00PM |
Re: Threadless Leadscrew ??? April 06, 2014 03:45PM |
Re: Threadless Leadscrew ??? April 07, 2014 12:32PM |
Re: Threadless Leadscrew ??? April 07, 2014 03:31PM |
cozmicray
I can't see what bearings riding on a threaded rod has any advantage over a proper nut?
Re: Threadless Leadscrew ??? April 07, 2014 04:48PM |
