Vibration/noise problem November 08, 2014 09:01PM |
Re: Vibration/noise problem November 09, 2014 10:18AM |
Re: Vibration/noise problem November 12, 2014 12:05AM |
Re: Vibration/noise problem November 13, 2014 09:41PM |
Re: Vibration/noise problem November 14, 2014 01:48PM |
Re: Vibration/noise problem November 21, 2014 07:55PM |
It's pretty good, but I am always striving to make it better. More photos of the printer and some recent prints for the SnakeBite extruder here: https://drive.google.com/drive/#folders/0BxckS0Y4E9lzN1hlOGtaeUdZcUUQuote
Garry Bartsch
Sorry I can't comment on the vibration but that's a wicked looking Heavy Metal printer. How's it's print quality?
A2
It looks to me like the idler belt pulley is retained by tension only, is this correct? Possibly there is some flexing or movement in this component. You stated that if you remove the belt the vibration is eliminated. The belt looks like it's installed backwards, is there a twist in it? If your time/energy permits I would like to see if the GT2 belt makes any difference.
cdru
I presume that you've looked for any place where the belt may rub up against something. Are the bearings and the mounting points in a straight line, making sure that none of them are pulling to the angle to mess with alignment? Does the idler bearing spin smoothly?
When you removed the belt and manually moved the bed, were you pushing on the bed with your fingers or were you pulling on the bed as the belt would? If you were pushing on it, your hand might have been dampening it and not making as much noise. One of the things that helped with noise on my machine was to make sure the balls in the linear bearings were aligned at 45 degree angles to vertical/horizontal, like an X, instead of straight up and down and left and right like a +. With the former, the load is transferred to 2 rows of balls, where the latter all the weight rides on a single row.
One other thing is the bolt that you use to tighten the idler. If that is just using tension of metal on metal, it might be vibrating loose and tight as the belt moves. try putting something under the bolt to dampen it from metal-on-metal contact and see if that makes a difference too.
Re: Vibration/noise problem November 22, 2014 01:41AM |
the_digital_dentist
Re: Vibration/noise problem November 22, 2014 01:48AM |
Re: Vibration/noise problem November 22, 2014 08:34PM |
Re: Vibration/noise problem November 23, 2014 12:08AM |
Re: Vibration/noise problem November 23, 2014 09:09AM |
Re: Vibration/noise problem November 23, 2014 05:21PM |
Re: Vibration/noise problem November 25, 2014 11:49AM |
Re: Vibration/noise problem December 07, 2014 01:58AM |
Re: Vibration/noise problem December 10, 2014 08:42AM |
Re: Vibration/noise problem December 13, 2014 04:27PM |
Re: Vibration/noise problem December 13, 2014 09:34PM |
Re: Vibration/noise problem December 14, 2014 06:31PM |
Re: Vibration/noise problem December 16, 2014 12:16AM |
Re: Vibration/noise problem December 16, 2014 07:56AM |
Re: Vibration/noise problem December 16, 2014 11:38PM |
Re: Vibration/noise problem December 20, 2014 10:08AM |
Re: Vibration/noise problem January 05, 2015 10:37PM |
