Re: 1mx1m hot plate? December 07, 2015 06:18PM |
Re: 1mx1m hot plate? December 07, 2015 06:37PM |
Re: 1mx1m hot plate? December 07, 2015 07:02PM |
Re: 1mx1m hot plate? December 07, 2015 07:10PM |
Re: 1mx1m hot plate? December 07, 2015 07:31PM |
I hope
Re: 1mx1m hot plate? December 07, 2015 07:46PM |
Re: 1mx1m hot plate? December 07, 2015 09:00PM |
Re: 1mx1m hot plate? December 08, 2015 05:23AM |
Re: 1mx1m hot plate? December 08, 2015 11:16AM |
rowow
val c.
dc42
IMO you cannot build a large 3D printer on a budget. The only way I know of getting a sufficiently flat bed of that size is to use an aluminium tool plate. To heat it, I would ask these people [www.aliexpress.com] to quote for a silicone heater slightly less than 1m square. They did a custom heater for my delta printer at a very good price, so I would expect it to cost a lot less than the $450 that has been mentioned.
you're right about the budget.
I think I passed 11.000 on mine.
regarding the 450 usd, that was for a 1275 x 1110 mm etched foil silicone pad (there is a picture of it in one of my previous posts on this thread). I don't know the size of your heater, but as you say, Aliexpress can have some darn good deals sometimes. Considering I got a quote from durex of about 2000 doillars for the same thing, I believe I still came out ok with only 450 usd from china.
$11,000 for a 3d printer? It must be either REALLY huge or really complex with gadgets and gizmos that I cant even imagine, or you got ripped off badly...
BTW I have already finished building the 3d printer frame, all I need to do is wait for 20 more screws that I lost somewhere and it will be assembled. Literally everything is finished except for hooking up the Z to the Y and those two to the X. And after that I got the basics of hooking up the stepper motors, and hooking up those to the controller, but as I have already said, I managed to do this whole project for way under 400$ (excluding the heat bed), so if you spent $11,000 then I must be missing something
Re: 1mx1m hot plate? December 08, 2015 11:54AM |
These days you can buy almost as good printers for 300$ ... Well not really! The extra expenses really show, the high quality bearings, stronger motors etc. But you could take a 300-400$ kit, purchase stronger steppers, higher quality rods & bearings and come close to the print quality & speed my first one had.
Re: 1mx1m hot plate? December 08, 2015 04:14PM |
If you read the rest of the post you would realize people (including I) are building 3D printers larger then yours for under 400$Quote
val c.
rowow
val c.
dc42
I designed and built it myself. The printing size, for the money, is around 50x43x45 inches. Such a printer costs from 40 to 70 thousand, and above, if I were to buy it. I think that, under the circumstances, 11 thousand is not that much.
Re: 1mx1m hot plate? December 08, 2015 04:19PM |
Ill have to see if I have any drills with a 1" chuck, otherwise ill have to go with smaller wheels, which aren't an issue, but means ill have to go with a slight different path. But before I even do that ill do the 3d printing and sanding, and hopefully that works.|
Re: 1mx1m hot plate? December 08, 2015 06:49PM |
rowow
But man I wish I had a lathe, it would make things much more precise and accurate for even cheaper!
Ah right, the good ol drill latheIll have to see if I have any drills with a 1" chuck, otherwise ill have to go with smaller wheels, which aren't an issue, but means ill have to go with a slight different path. But before I even do that ill do the 3d printing and sanding, and hopefully that works.
Maybe instead of ordering plastic rod, I could just make it from recycled HDPE. Ive never worked with HDPE, but it should be good as wheels.
Re: 1mx1m hot plate? December 08, 2015 07:01PM |
Re: 1mx1m hot plate? December 08, 2015 08:09PM |
rowow
cozmicray
Drill a 1/4" hole in the center of your stock and put in a 1/4 - 20 bolt and nut and mount that in a drill.
Get a lathe
-- 6 years, a ton of stock
--- 50 different cutters, 8 different measuring devices
--- 56000 questions on how to turn materials
--- to learn techniques and how to be accurate
-- then you can "Machine" your accurate parts.
Then you will need a mill
Then a new six car garage on house 1 bay for car 5 bays for projects
or just purchase parts made by a good machinist or CNC machine.
Wha Wha Wha --- my part is off by 12 nanometers Whaaaaaaaaa1
Re: 1mx1m hot plate? December 09, 2015 10:46PM |
rowow
But im sorry if you live your life by purchasing everything online because you cant do anything yourself but thats not how I live.
Also a lathe is used MUCH more then a few wheels and takes the space of a table...
Re: 1mx1m hot plate? December 10, 2015 08:39AM |
cozmicray
I have a lathe, I turn all kinds of parts I can't buy
I have a mill, that use more than lathe
I have a CNC router with a spindle and solid state laser, I swap out
I am building a SCARA robot arm to do what ever I program it to do.
I rip logs into planks with chainsaw mill.
Don't be sorry for me -- if I use my time to make things I want to make --- NOT things that are better or cheaper purchased on-line
rowow
Re: 1mx1m hot plate? December 10, 2015 08:46AM |
Re: 1mx1m hot plate? December 10, 2015 06:41PM |
rowow
Each wheel kit costs over 25$, If I can make my own wheels, and mill my own plates, I can save over $24 as the 1x5mm 25mm bolt, 1x5mm nut, 2xwashers, and 2xbearings are dirt cheap.
So as I said, these things are expensive, and well worth the time and effort to make your own.
Re: 1mx1m hot plate? December 10, 2015 07:21PM |
Who doesn't buy their nuts and bolts in 100 pcs??? Im sorry but im not going to only use 4 bolts and throw the rest away. Lets make it simpler and go with 1 wheelQuote
cozmicray
Reality Check!!!!
608zz bearing $1.00
M3 Stainless Black Hex Head Socket Cap Bolt $1.00
M3 SS Hex Locking Lock Nuts $0.50
M3 SSBolt Flat Washer $0.10
Black Acetal / Delrin rod 0.98" (25mm) dia - 4.25" $5.00 $1.25 per wheel
Per wheel $4.95 without your time to turn wheels
to get under kit price -- your machining price
$1.30 per hour --- if your real good at turning delrin and don't screw up
I think the kids in Shirlanka get a better hourly rate
and while your turning wheels -- you are NOT putting a printer together?
40 lb potting soil (dirt) $2.50
Unless you are going to buy 100 piece lots
Not as cheap as dirt
rowow
Re: 1mx1m hot plate? December 11, 2015 02:00AM |
Re: 1mx1m hot plate? December 11, 2015 04:57AM |
Re: 1mx1m hot plate? December 11, 2015 05:06AM |
Re: 1mx1m hot plate? December 11, 2015 05:19AM |
Of course, I dont expect everyone to lathe their own wheels... But some people will want to. Just like the plates which cost $12. Some people may want to make their own if they are precise enough. Others may just want to buy it to not risk anything in case they are not able to do it and they would have to pay extra shipping costs later.Quote
o_lampe
rowow,
you mentioned you want to build a printer kit for everyone to be cheap.
But when you put so much of your own time ( making the rollers ) into each kit, you'll have to raise the bill.
Or do you only want to proof, that someone with a complete metal and wood workshop can build things cheaper than buying stuff?
If so, I believe you are right. If not, be realistic about what others would have to pay for a kit, you've put together.
-Olaf
Re: 1mx1m hot plate? December 11, 2015 05:39AM |
Im not going to be positive when someone claimed im wrong and the ways I do things are completly stupid when he didnt even do the smallest amount of research,Quote
PulsedMedia
Guys Guys! Stop the hate, be positive!
I find it kinda ironic that on reprap M3s are so popular but they cost more than M4s
M4s you get by the kilo, here it is usually about 6€ per kilo, but M3s by the piece 0.10-0.5€ a piece
And since no one stocks them had to online order, so 100x short M3s + nuts cost me more than couple kilos of M4s -.-
If the driving force was to get price down, why use more expensive hardware when cheaper is available
I received the motors for my printer yesterday. Damn they are big compared to the average Nema 17s!
Re: 1mx1m hot plate? December 11, 2015 06:40PM |
rowow
[openbuildspartstore.com]
$4.85
Delrin rod:
[www.eplastics.com]
$3 per foot
1 wheel is 0.4 inch long, lets say half an inch for when we make the final cut between wheels
1 foot = 12 inches
12 inches/0.5 = 24
$3/24 = $0.125
13 cents
Bearings:
[www.ebay.com]
10pcs = $2.44
2.44/10 = .24
.24 x 2 (2 pcs per wheel) = .48
48 cents
Washer:
[www.zoro.com]
100pcs = $0.33
0.33/100 = .003
.003 x 2 (2 pcs per wheel) = .006
less then 1 cent
Nut:
[www.zoro.com]
100pcs = $1.61
1.61/100 = .0161
2 cent
Total cost: $0.64 vs $4.85 vs your bullshit number of $4.95
Reality check!!! You dont know at all what your talking about. At least so SOME research and you would have realized these are 5mm wheels, NOT 3mm.
So thanks for wasting my f*cking time! makes me wonder if you even know how to use "your lathe" or if you even own one.
BTW I know a better forum for you, its by cubify 3d printer owners. I bet you and your "research" and logic will fit right in with the cubify 3d printer owners
Now that I think of it I bet you own one... do you? please tell me you do ;D
Re: 1mx1m hot plate? December 11, 2015 07:06PM |
Re: 1mx1m hot plate? April 23, 2016 11:43AM |
Re: 1mx1m hot plate? April 23, 2016 08:45PM |
Anonymous User
Re: 1mx1m hot plate? April 24, 2016 12:56AM |
