High Resolution Extruder Help March 23, 2016 01:05AM |
Re: High Resolution Extruder Help March 23, 2016 01:15AM |
Re: High Resolution Extruder Help March 24, 2016 06:41PM |
Re: High Resolution Extruder Help March 25, 2016 03:49AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: High Resolution Extruder Help March 26, 2016 01:43AM |
Re: High Resolution Extruder Help March 26, 2016 02:32AM |
Re: High Resolution Extruder Help March 26, 2016 08:44PM |
Re: High Resolution Extruder Help March 27, 2016 01:50AM |
Re: High Resolution Extruder Help March 28, 2016 01:53PM |
Re: High Resolution Extruder Help March 28, 2016 10:56PM |
Re: High Resolution Extruder Help March 29, 2016 09:52AM |
Great advice, I forgot to think about microstepping ability and potentially skipping steps when running at lower currents. I was just looking at these 2A motors because they were a good deal, but I will try and find some in the 0.5A-1.2A range.Quote
dc42
At lower currents, microstepping is less accurate because the detent torque interferes more with the torque due to current.
I agree with you there. It's just this is my first 3D printer and I don't want to make it too complicated for me to build. But I definitely see the use of an lcd.Quote
Dust
I am not a fan of putting things on the internet just because you can
Re: High Resolution Extruder Help March 29, 2016 04:12PM |
Dust
In my view a web interface is a con.
a) you are back to needing a comping device to see it, the main reason for a LCD was to remove the need to have a computing device.
Dust
b) you need a working network to see it. Adds in more levels of insecurity and more points of failure.
Dust
c) in most cases this opens up your reprap to the internet, ie it will get hacked eventually, no matter how secure you think it is, its only a matter of time.,.
Anonymous User
Re: High Resolution Extruder Help March 30, 2016 02:39AM |
milner
Hello All,
I am new to 3D printing, and am wondering about high resolution with a paste extruder. I would like to print with 100um (100 microns, or 0.1mm) resolution in the x and y axes. The needle extruding the paste does not need to be 100um thin (I would like it to be thicker), but I want to be able to have gaps between x-y layers of paste that are 100um. Basically, it would print something like a maze, with walls made of paste and pathways of 100um in width. Are there any motors that are capable of such fine movement and accuracy? Would calibration be an issue? Thank you in advance, and apologies for my lack of 3D printer terminology/experience!
Re: High Resolution Extruder Help March 30, 2016 03:26AM |
Thanks for bringing it back to the original topic.Quote
MKSA
I suppose you have solved the problem of the extruder because you need to achieve less than 50 micron thickness variation of the extruded paste. How do you plan to do it ?
Anonymous User
Re: High Resolution Extruder Help March 30, 2016 12:05PM |
milner
MKSA
Yes, the variation would need to be +/- 50 microns from the extruded paste thickness. The thickness of the extruded paste itself can be much larger. Honestly, I don't know a lot about extruders (especially paste extruders). Is this even possible?
Maybe I can use an extruder that extrudes thin paste and hopefully get the variation within 50 microns (I think that might be more plausible than with thick paste, which would probably have much more variation). But that would lead to extremely long prints. What kind of extruders (paste or any other type) that are out there which I could use/modify for this? An injet printer head is about 70 microns thick, but I don't know about it's variation. I'm hoping one of you can shed light on this issue!
Re: High Resolution Extruder Help March 31, 2016 12:41AM |
Anonymous User
Re: High Resolution Extruder Help March 31, 2016 03:52AM |
milner
I didn't know XY resolution was that easy to achieve. This is the first 3D printer I am attempting to build. It will be a hydrogel paste.
Re: High Resolution Extruder Help March 31, 2016 04:00AM |
MKSA
Considering the requirements, it is easy for someone who has the appropriate background of course.
MKSA
The accurate extrusion of this gel the way you want it, this is what you have to focus on.
Re: High Resolution Extruder Help March 31, 2016 04:55AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: High Resolution Extruder Help April 01, 2016 12:43AM |
Anonymous User
Re: High Resolution Extruder Help April 01, 2016 02:16AM |
milner
MKSA
Yeah, I figured that out from the previous users' comments (which were very helpful).
MKSA
So do you have a solution for the extruder issue? Or are you just here to point out the problem without having a solution for this?
Re: High Resolution Extruder Help April 01, 2016 05:22AM |
Re: High Resolution Extruder Help April 14, 2016 11:32AM |
Re: High Resolution Extruder Help April 15, 2016 10:24AM |
Re: High Resolution Extruder Help May 15, 2016 11:55AM |
Re: High Resolution Extruder Help May 15, 2016 02:24PM |
