Flexible hosepipe style air-ducts... using Masking tape! September 01, 2017 08:17AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 01, 2017 05:37PM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 01, 2017 08:19PM |
frankvdh
Ummm... how do you stop the masking tape tube from collapsing and sticking together into a ribbon? Do you do two layers, with the sticky sides facing each other?
Since you're concerned about weight, I assume that one end will connect to (I guess) the hot-end, and move around. I'd be worried that the tube would crease, fatigue, and eventually tear. No big deal to repair, but you maybe lose a print and get a hot-end jam along the way.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 02, 2017 03:30AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 02, 2017 05:25AM |
o_lampe
Why not use shrinktube and shrink it on top of the off_the_shelf flexible hosepipe. Then remove the inner hosepipe and voilá: crinkled rubber hosepipe.
Removing the inner hosepipe should be easy when it's slotted lengthwise.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 03, 2017 03:00AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 03, 2017 06:07AM |
o_lampe
You can get shrinktube in any size, but it's not rubber. Food industry uses shrinking foil ( and tubes ). Its more flexible too.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 04, 2017 01:59AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 04, 2017 07:41AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 06, 2017 04:52AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 07, 2017 08:23AM |
M_Xeno
Use a cheap corrugated tube from an aquarium cleaner :
It works very well with a 60x15mm blower. You need to print an adapter. I use this sort of tube since 2 years on my Zatsit delta prototype:
www.zatsit.fr
Re: Flexible hosepipe style air-ducts... using Masking tape! September 07, 2017 12:40PM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 07, 2017 06:58PM |
MKSA
Masking tape has the big advantage to capture any insect avoiding it to clog heatsink fins etc....
Not to mention the fun to make it. Cling film and scotch tape, hard to beat to test your nervous system.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 01:09AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 06:24AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 11:36AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 11:41AM |
MKSA
Always look at the big picture. Done. OK, now, what is the purpose again ? Usually it is one 30mm fan for the hot end, one blower fan for the part. SO ?
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 01:09PM |
lkcl
MKSA
one blower is nowhere near enough to deal with 250 to 300mm / sec or above print speeds. i'm getting perfect prints at 50mm/sec even with 50 to 55 degree overhangs. but with a square 20x20x20mm test cube running at 300mm / sec the edges curl up by at least 2 or 3 layers (0.4 to 0.6mm).
i need a *lot* of airflow, basically. one blower is nowhere near enough.
l.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 03:44PM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 08:39PM |
MKSA
Where can we see it printing at these speeds ? 0 to 300 mm/s on a 20mm long race track, gee ! (in fact more than 2 )
Re: Flexible hosepipe style air-ducts... using Masking tape! September 11, 2017 09:01PM |
the_digital_dentist
Either it's a work of art, or it will scare the crap out of children, or both.
Oh yeah, that's the other thing. Axial fans can't blow air through a tube. You need a radial fan, aka a blower.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 02:20AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 03:08AM |
MKSA
Looks like you have far more problems than just the part cooling fan !
And definitely the speed is NOT 300mm/s. It may look like it but that is because of the noise and the shaking , typical of these playful crappy chinese bearings that must grind the rods !
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 05:01AM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 05:38AM |
MKSA
How do you measure the speed to be so sure ? Is it average, peak etc ??? PLA is the easiest to print.
What about PETG ? I bet at this speed and with all these fans, the required T° and filament output won't be achieved.
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 03:00PM |
Re: Flexible hosepipe style air-ducts... using Masking tape! September 12, 2017 11:06PM |
MKSA
OK and how does these test cubes look at 60mm/s, 120mm/s and 180mm/s ?
