Dual extrusion setup - Which to choose?
November 09, 2017 05:01PM
Hi Guys!
I was using the search function and also was googling it... but couldnt find any satisfying answer...
I am looking forward to build a dual extrusion system, because i want to print PVA and PLA... YEAH! Nice support material winking smiley I am really looking forward to make something like that...
My plans were about using the prometheus system, or more exact, just the splitter and run it via my own bowden extrusion system...
BUUUTTTT.... I am not sure about PVA and PLA beeing used with the prometheus system... What do you think? What alternatives do i have? which ones are the better ones to use with a Prusa clone?
I am really thankfull for any suggestion, since there is no real information out there ;/
cheers, luke
Re: Dual extrusion setup - Which to choose?
November 11, 2017 05:38AM
I'm not sure I like splitter systems for multi material. It relies on the temperature profiles being the same, or finding some sort of compromise between the material profiles. Large retractions needed also introduce a source of error and it generally has to be done on a bowden system. Capricorn bowden tubes have helped the issues surrounding bowden systems, but I hear that the large retractions needed for splitter systems doesn't get on well with the tight inner diameter of capricorn. Next up is splitter systems require purging, and PVA is expensive. I'm not sure I'd want most of my expensive PVA in a purge tower.
Separate hot ends are the answer in my opinion for true multi material systems. This adds a bit of bulk to the hotend gantry though depending on what system you get. E3D chimaera is nice and compact but again requires bowden (but will not have the same issues as splitter thankfully). You could go for independent X axis's, but this adds complexity. You could also get a lifting nozzle system. the ultimaker 3 uses this to lift the inactive nozzle out of the way. This is in my opinion the best style.
November 11, 2017 06:39AM
Hey!
Thank you for your reply.
As now I group the extruders as followed:
  • Extruders With a single nozzle (Prometheus System or Diamond Hot End, though they are different approaches)
  • Extruder With two sepperate nozzles and heater blocks (Basic dual extrusion)
  • Extruders with two in one block nozzles (no X,Y,Z problems --> Chimera or Ultimaker sys
For me I also tend to a two nozzle System now, though I was convinced that the Prometheus System, printing with one nozzle, is Ideal... But its not... Im afraid of the retraction (stringing inside the extruder) and the different temperatures of the materials needed for a nice extrusion...
So now im looking for the Chimera System...
As for Single nozzle extrusion: What do you guys think about the Diamond hot end?
Looking at the prusa Multi material system again... it looks so nice... but the waste of material... hummm.... Any further thoughts on this?
regards luke
November 11, 2017 01:13PM
Probably the best option for dual-material is IDEX (independent dual X carriages), but this requires much greater modifications to the printer.
Ian (deckingman) is an expert on Diamond hot ends, both 3- and 5-input versions. His blog is at [somei3deas.wordpress.com]. Click on tag "Diamond hot end".
Edited 1 time(s). Last edit at 11/11/2017 01:14PM by dc42.
November 11, 2017 01:31PM
Hey ho!
Thanks for the blog article... Seems like he put a lot of effort in that.
The IDEX system seems realy interesting. I orderd to day some parts to start with a simple bowden system... Than I will upgrade to double bowden with dual extrusion and the Chimera hot end...
When this is working, I am happy and will give further updates and photos.
I also think that my reprap with wood frame is not "worth" upgrading... I think for an IDEX system a better "base" should be available. More stable, less noisy, enclosure and so on...
November 15, 2017 07:38PM
I think the way forward for multi-extrusion is via a tool changer.
I am working on a design for independent tool heads. Each one would have it's own "umbilical cord" for wiring, reverse bowden, flex/nimble style remote extruder drive, and possibly water cooling lines and Berd-Air cooling (as chamber will likely be heated).
Corexy gantry "cart" would simply pick whichever head is selected.
Clamping via kinematic coupling and magnet(s).
XYZ offsets handled in software, so they don't have to be physically identical.
Ideal nozzle geometry and temps for each material.
1) PLA
2) PVA
3) CF Nylon
4) Flexible TPU
Anyways, that's my plan.
November 17, 2017 05:06AM
StephenM
1) PLA
2) PVA
3) CF Nylon
4) Flexible TPU
Although it makes sense, the question is: Will there be enough demand for it considering the price ? To make such a system will be costly. Two different materials is nice (a rigid and a flexible one for ex.) but more than that ?
Different colors is a no for me as it can be done by mixing the dye in the hot end.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
November 17, 2017 07:12AM
Regarding Systems with two nozzles, there is something else: You can have different nozzle diameters.
So it should be possible to print on Extruder 2 with PVA support, at a higher speed with a bigger nozzle and use a fine one for the rest of the print.
The question for the demand on the market is some kinda difficult, because there was no demand for 3D printers before they came up with the idea.
Nevertheless I understand the argument that it is not worth it, because looking at a modern CNC machine with interchangable tools, they need to be change to get connected with the engine. So having 2 or more engines in one CNC is not economic. Instead having 3 extruders parked on a 3D printer is still cheaper than a fancy interchangable system.
November 18, 2017 01:16AM
I tried a lot of solutions, and want to give my own opinion.
First:
Dual extrusion is not an easy thing.
Pva printing is totally different from Pla printing (so don't even think about a single nozzle system for this application, i had the original diamond, only usable with materials really compatible)
The only way to go, is 2 separate nozzle's, either 2 carriages or single carriage with a switching height solution like Ultimaker 3. 2 nozzles at same height on same carriage gives you a lot of problems.
Just some tips regarding PVA:
-Cura software has the best temperature management, it cools the not used PVA head down while not being used, and heats it up quickly so it is ready for the next layer just in time. If you do't use this feature, you will have clogged heads very soon!!
-PVA does not bond with PLA, so printing PVA on top of PLA is a bad idea, always let the PVA touch the buildplate, (horizontal expansion can help), or with other PVA.
-Expect printing time to go up almost 3X.
-Pva is extremely hygroscopic!! 24 hours left on the printer can ruin your filament because of moisture absortion. Keep it dry in a drybag with silicagel, even while printing!!!!, or use a Polybox (just google it, easy thing which you can build yourself)
My main filament use regarding supports:
Polymax PLA (better then ABS)
in combination wit Ultimaker PVA, or Polymax Polysupport (much easier to use, can be removed traditionaly)
Have fun, once it works, it is a nice evolution for 3D printing.
Edited 1 time(s). Last edit at 11/18/2017 01:22AM by RudydG.
March 25, 2018 12:25PM
Hi ,
If someone is looking for a working system with two nozzles E0 and E1, that can heat like you want, I have a perfect solution.
I have a Prusa i3 with a ZONESTAR V3.1 board (ATMEGA 2560). I changed a lot. Now I am working with two nozzles with a servo. Most parts were printed myself. I designed them myself with Sketch and Fusion 360.
I changed the firmware and now the nozzles change with instruction T0 and T1 automatically. So no extra work in g-code instruction.
You can adjust the nozzles in high as desired (make them equal to the bed). No more problems with hitting printed material by the new nozzle.
So, let me know if someone is interested in it.
March 25, 2018 02:26PM
That sounds really interesting!
please give us some pictures / photos or a video demo!
Would be great to see
March 25, 2018 03:25PM
Another possibility for dual or greater extrusion is E3D's tool changing system, see [e3d-online.com].
March 26, 2018 05:44PM
I am talking about a very easy way to change the Prusa i3 printer. And most important: less costs and maximum result. The tool-changing system is very expensive and it is not sure that we ever can buy it.
The original double extruder coolblock was sawed in two parts of equal width. It is even possible to make the part a little bit smaller, without loosing functionality. The distance between the two nozzles can than be between 15 and 16 mm (now about 17 mm).
I will make some photos and put them here. I printed yesterday a two-colour cat (see picture). As you can see there was about a mis-alignement between white and black of 0.3 mm. I changed that later. Now it is OK.
The main problem is the bowden, because than you miss the direct drive at the nozzle. By changing the place of the extruder-motors I eliminated the teflon tube till half, with same functionality and less space-drag (space between filament and inner tube).
Edited 6 time(s). Last edit at 03/28/2018 07:41AM by DutchKees.
May 13, 2021 05:52AM
dc42
Thank you for the thread and links, pals, a lot of useful information. I'm a newbie, just started. Still have a lot of doubts, what is the best printer with IDEX configuration for the start.
