Bricked MKS Base v1.3 after ICSP update July 12, 2015 01:02PM |
Re: Bricked MKS Base v1.3 after ICSP update July 13, 2015 04:29AM |
Re: Bricked MKS Base v1.3 after ICSP update July 13, 2015 05:23AM |
Re: Bricked MKS Base v1.3 after ICSP update July 13, 2015 10:34AM |
Re: Bricked MKS Base v1.3 after ICSP update July 13, 2015 11:26AM |
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 03:29AM |
Atmega fuse calculator. Written by Nick Gammon. Version 1.10 Compiled on Jul 14 2015 at 08:56:56 with Arduino IDE 10601. Attempting to enter programming mode ... Entered programming mode OK. Signature = 0x1E 0x98 0x01 Processor = ATmega2560 Flash memory size = 262144 LFuse = 0xFF HFuse = 0xD8 EFuse = 0xFD Lock byte = 0xFF Clock calibration = 0xA2 OCD Enable.............................. [ ] JTAG Enable............................. [ ] Enable Serial (ICSP) Programming........ [X] Watchdog Timer Always On................ [ ] Preserve EEPROM through chip erase...... [ ] Boot into bootloader.................... [X] Divide clock by 8....................... [ ] Clock output............................ [ ] Bootloader size: 8192 bytes. Start-up time: SUT0: [ ] SUT1: [ ] (see datasheet) Clock source: low-power crystal. Brownout detection at: 2.7V.
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 04:39AM |
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 04:43AM |
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 05:01AM |
agehall
You mean I should tell the Arduino IDE to use a programmer even though I'm connected directly to the MKS board with my USB cable?
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 05:04AM |
Re: Bricked MKS Base v1.3 after ICSP update July 14, 2015 05:14AM |
Re: Bricked MKS Base v1.3 after ICSP update July 15, 2015 03:20AM |
Re: Bricked MKS Base v1.3 after ICSP update July 15, 2015 03:50AM |
Re: Bricked MKS Base v1.3 after ICSP update July 15, 2015 06:48AM |
Re: Bricked MKS Base v1.3 after ICSP update July 15, 2015 11:06AM |
Re: Bricked MKS Base v1.3 after ICSP update July 15, 2015 12:35PM |
Re: Bricked MKS Base v1.3 after ICSP update July 18, 2015 04:01PM |
Re: Bricked MKS Base v1.3 after ICSP update July 20, 2015 04:22PM |
Re: Bricked MKS Base v1.3 after ICSP update July 20, 2015 06:28PM |
Re: Bricked MKS Base v1.3 after ICSP update July 21, 2015 12:22PM |
Re: Bricked MKS Base v1.3 after ICSP update July 21, 2015 03:48PM |
Re: Bricked MKS Base v1.3 after ICSP update July 21, 2015 06:58PM |
Re: Bricked MKS Base v1.3 after ICSP update July 22, 2015 01:25AM |
Re: Bricked MKS Base v1.3 after ICSP update July 23, 2015 04:49AM |
Re: Bricked MKS Base v1.3 after ICSP update January 19, 2016 03:00PM |
Re: Bricked MKS Base v1.3 after ICSP update February 15, 2016 08:22PM |
Re: Bricked MKS Base v1.3 after ICSP update March 30, 2016 01:42PM |
Did you fix this ??Quote
HenryAT
I have an MKS Base V1.3 on my machine which is an HIC Technology Reprap Prusa I3 LCD.
Since I completed assembly of the unit, last summer, I have not been able to get it to print properly.
I have tried different printing software programs with exactly the same end results from each one.
The first layer will print and the subsequent layers do not adhere to the layer below because the
hot end gets to high for the filament to adhere to the layer below. Some time the extruder quits
working, probably needs a rest, and then starts up again.
The unit connects to the computer properly, because I can control the steppers and the extrusion
of filament from my keyboard. I can also set the heat for the bed as well as the hot end.
I am quite new at this, however, I have everything calibrated and level and am now at my whits end.
Is there anyone out there that can help me???????
Henry
Re: Bricked MKS Base v1.3 after ICSP update March 30, 2016 01:44PM |
Re: Bricked MKS Base v1.3 after ICSP update May 17, 2016 08:31AM |
Re: Bricked MKS Base v1.3 after ICSP update May 18, 2016 05:36PM |
