New RepRapFirmware release 1.09o-dc42 December 27, 2015 04:20PM |
Re: New RepRapFirmware release 1.09o-dc42 December 27, 2015 08:09PM |
Re: New RepRapFirmware release 1.09o-dc42 December 27, 2015 11:44PM |
Re: New RepRapFirmware release 1.09o-dc42 December 28, 2015 03:43AM |
ElmoC
Were you able to fix the cold extrusion issue? I didn't see that listed in the fixes.
Re: New RepRapFirmware release 1.09o-dc42 December 28, 2015 10:53AM |
Re: New RepRapFirmware release 1.09o-dc42 December 28, 2015 05:52PM |
Re: New RepRapFirmware release 1.09o-dc42 December 29, 2015 09:18AM |
Re: New RepRapFirmware release 1.09o-dc42 December 29, 2015 09:20AM |
Re: New RepRapFirmware release 1.09o-dc42 December 29, 2015 09:22AM |
Re: New RepRapFirmware release 1.09o-dc42 December 29, 2015 09:25AM |
Re: New RepRapFirmware release 1.09o-dc42 December 29, 2015 11:09AM |
Re: New RepRapFirmware release 1.09o-dc42 December 31, 2015 03:39PM |
Re: New RepRapFirmware release 1.09o-dc42 December 31, 2015 04:37PM |
Re: New RepRapFirmware release 1.09o-dc42 December 31, 2015 04:42PM |
Re: New RepRapFirmware release 1.09o-dc42 December 31, 2015 06:43PM |
Re: New RepRapFirmware release 1.09o-dc42 January 01, 2016 04:34AM |
WZ9V
Solved. Needed to change the 320mm X/Y/Z to 400mm in homedelta.g
I've noticed that if I do a Home All from a point on the outer radius of my build area it does not always home all three axis without doing a second Home All. It's usually the carraige that was lowest not going all the way to the end stop after the other two hit the end stop.
Re: New RepRapFirmware release 1.09o-dc42 January 03, 2016 04:15AM |
Re: New RepRapFirmware release 1.09o-dc42 January 03, 2016 09:12AM |
Re: New RepRapFirmware release 1.09o-dc42 January 03, 2016 02:23PM |
Re: New RepRapFirmware release 1.09o-dc42 January 03, 2016 03:15PM |
DADIY
Intrigued by the fan control you've added. At the moment the fisher uses the 50 pin connector for the fan. Am I right in thinking I just need to reconnect the fan to the pwm 1 fan pins as shown here [uet_0.8.5_Duex4_wiring_0.2.svg" target="_blank" rel="nofollow">reprap.org] and then add to config.g M106 P1 T45 H1 so that its activated above 45c.
I'm probably being too simplistic.
If this works you've wrecked my plans to goto a 12v fan.
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 09:42AM |
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 10:03AM |
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 11:56AM |
mhackney
@DADIY, David has pulled the 1.09o release due to these connection issues - he stated this in my thread last week (the ethernet issue thread). His recommendation is to go back to the "m" release. I loved the new thermistor controlled fan too! Cut down a lot of noise when the printer was on but not printing.
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 01:36PM |
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 04:07PM |
WZ9V
I discovered an issue with M558 P1 vs P4 causing a 6C to 8C shift in temperature readings. Dave is rolling that fix into the next version also. You may want to recheck your temps because of it and recalibrate the H parameter in M305.
My discovery was that P1 (IR Probe) was reading correctly but just changing the M558 to P4 (switch) would cause a jump of 6 to 8C on both readings. Dave discovered it was something to do with the default ADC setup causing crosstalk on the ADC channels. BTW, I sent the information Saturday night and he said he had a fix on Sunday afternoon.
Re: New RepRapFirmware release 1.09o-dc42 January 11, 2016 06:13PM |
Re: New RepRapFirmware release 1.09o-dc42 January 14, 2016 07:42AM |
Re: New RepRapFirmware release 1.09o-dc42 January 14, 2016 09:47AM |
Re: New RepRapFirmware release 1.09o-dc42 January 14, 2016 02:19PM |
Re: New RepRapFirmware release 1.09o-dc42 January 14, 2016 02:21PM |
