Adding fan in firmware repetier January 27, 2017 05:01PM |
Re: Adding fan in firmware repetier January 28, 2017 12:24AM |
Admin Registered: 13 years ago Posts: 7,007 |
Re: Adding fan in firmware repetier January 29, 2017 10:52PM |
Re: Adding fan in firmware repetier January 30, 2017 06:58AM |
Re: Adding fan in firmware repetier January 31, 2017 02:34PM |
Re: Adding fan in firmware repetier February 03, 2017 12:30AM |
Re: Adding fan in firmware repetier February 08, 2017 11:34AM |
RaBrand
Go into the Arduino Software, select configuration.h, search for "#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN" and change the pin number in the end to 44. Click upload and your printer should now start at a temperature, which you can change again in configuration.h by changing the last number in this setting: "#define EXTRUDER_FAN_COOL_TEMP 50"
