the problems about the hot end temperature hot smiley
Posted by caorunchen
March 20, 2014 07:54AM
there are some problems about the hot end temperature.
In the software pronterface, it does not give the right e-temp.
Here is the info in pronterface:
Printer is now online.
echo:Marlin 1.0.7 RRP
echo: Last Updated: 2013-06-14/2 | Author: RepRapPro - AB
echo: Free Memory: 10846  PlannerBufferBytes: 1232
Slave init. Please wait ...
Slave error(s); comms errors will also cause heater errors: Dud heater 1, Dud heater 2, Comms timeout,
Firmware version: V08, EEPROM version: V08
ok p:12.00 i:2.20 d:80.00 w:125
echoconfused smileytored settings retreived:
echoconfused smileyteps per unit:
echo:  M92 X87.49 Y87.49 Z4000.00 E660.00
echo:Maximum feedrates (mm/s):
echo:  M203 X300.00 Y300.00 Z3.00 E45.00
echo:Maximum Acceleration (mm/s2):
echo:  M201 X800 Y800 Z30 E250
echo:Acceleration: S=acceleration, T=retract acceleration
echo:  M204 S1000.00 T1000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s),  Z=maximum Z jerk (mm/s)
echo:  M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00
echo:  M206 X0.00 Y0.00 Z0.00
echotongue sticking out smileyID settings:
echo:   M301 H1 P12.00 I2.20 D80.00 W125.00
Slave not working! Default values are:
   M301 H2 P12.00 I2.20 D80.00 W125.00
   M301 H3 P12.00 I2.20 D80.00 W125.00
FPU Enabled no
Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00
Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01
Bed/extruder 1 beta: 4138.00 resistor: 4700.00 thermistor: 99999.91 inf: 0.09
Bed/extruder 2 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00
Bed/extruder 3 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00
Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
Extruder: 1 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
Extruder: 2 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00
transform correction not enabledok T0: 258.7/-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.4 /-273.1 @:0
ok T0: 282.0/-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.4 /-273.1 @:0
I have checked the thermometer is good, and if I shorted the screw of the etemp on the PCB, it gives T0: -273.1 /-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.5 /-273.1 @:0, which is normal.
Re: the problems about the hot end temperature hot smiley
March 31, 2014 10:43PM
I got almost the same ....
start
echo: M92 X91.43 Y91.43 Z4000.00 E875.00
echo: M206 X20.00 Y0.00 Z0.00
FPU Enabled no
Bed/extruder 1 beta: 3960.00 resistor: 4700.00 thermistor: 99999.92 inf: 0.17
Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00
Extruder: 1 dX: -34.00 dY: 4.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00
Extruder: 2 dX: -11.00 dY: 51.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00
Error:0
: Extruder switched off. MINTEMP triggered !
April 01, 2014 12:42AM
Leave the mains power off switched off, and put the central power jumper to USB power, on the two pins furthest from the screw terminals. Now connect to the slave directly with Pronterface, by USB cable plugged into the slave. It will appear to hang with “Connecting…”. Press reset on the slave, and you should get the message:
RepRapPro slave controller Version 1.1, 2013-05-15 restarted.
Temps:22.37 23.46
If you get something like:
Temps:-273.15 23.46
ERROR: temp bounds exceeded
after this, your thermistors are not reading correctly. Check your wiring, particularly the thermistor wires. The temperature reported will indicate which thermistor is not reporting correctly; the first temperature is T1, the second T2.
If the board doesn’t report temperatures, you need to update the firmware on your Slave.
After put the jumpers (power & reset) in the correct position get voltage from the PSU. Push reset ...
start
.Slave ready
FPU Enabled no
transform correction not enabledechoconfused smileyD card ok
