the problems about the hot end temperature March 20, 2014 07:54AM |
Printer is now online. echo:Marlin 1.0.7 RRP echo: Last Updated: 2013-06-14/2 | Author: RepRapPro - AB echo: Free Memory: 10846 PlannerBufferBytes: 1232 Slave init. Please wait ... Slave error(s); comms errors will also cause heater errors: Dud heater 1, Dud heater 2, Comms timeout, Firmware version: V08, EEPROM version: V08 ok p:12.00 i:2.20 d:80.00 w:125 echotored settings retreived: echoteps per unit: echo: M92 X87.49 Y87.49 Z4000.00 E660.00 echo:Maximum feedrates (mm/s): echo: M203 X300.00 Y300.00 Z3.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X800 Y800 Z30 E250 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X0.00 Y0.00 Z0.00 echoID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 Slave not working! Default values are: M301 H2 P12.00 I2.20 D80.00 W125.00 Slave not working! Default values are: M301 H3 P12.00 I2.20 D80.00 W125.00 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01 Bed/extruder 1 beta: 4138.00 resistor: 4700.00 thermistor: 99999.91 inf: 0.09 Bed/extruder 2 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00 Bed/extruder 3 beta: -273.00 resistor: -273.00 thermistor: -109.27 inf: -273.00 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00 Extruder: 1 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00 Extruder: 2 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 0.00 operating temp: 0.00 transform correction not enabledok T0: 258.7/-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.4 /-273.1 @:0 ok T0: 282.0/-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.4 /-273.1 @:0 ok T0: 282.0/-273.1 T1: -273.0/-273.0 T2: -273.0/-273.0 B:25.4 /-273.1 @:0
Re: the problems about the hot end temperature March 31, 2014 10:43PM |
Re: the problems about the hot end temperature April 01, 2014 12:42AM |
