Hmmm, same error happening again.
Tried slicing a new .stl file to load updated gcode file into pronterface and same error.
Unplugged power and USB and same error.
Pronterface seems to behave ok until the gcode is loaded. I.e., Check temp gives me the temp, but after I start the loaded gcode file, pronterface gives the error and Check temp gives the response SENDING:M105.
It could be the custom gcode I'm using.
I set the start temp at 210 degrees, however I have also set pronterface to 210 and it use to start when the reprap's temp reached 210.
Here's my gcode I'm using.
