Re: Bed Auto Leveling.. check this out December 30, 2013 06:16AM |
Re: Bed Auto Leveling.. z reveresed December 30, 2013 09:53AM |
Re: Bed Auto Leveling.. check this out December 30, 2013 02:17PM |
Re: Bed Auto Leveling.. check this out December 30, 2013 02:54PM |
Re: Bed Auto Leveling.. check this out December 30, 2013 03:47PM |
Re: Bed Auto Leveling.. check this out December 30, 2013 04:08PM |
Re: Bed Auto Leveling.. check this out December 30, 2013 04:28PM |
Yes is .Quote
TobinatorCO
Lee-Saw,
Based on your ""INVERT_(axis)_DIR" settings being all being set to "true", it is a little confusing to me which way is which. is your "home" position in the back right of the plate?
Re: Bed Auto Leveling.. check this out December 30, 2013 05:27PM |
Re: Bed Auto Leveling.. check this out December 30, 2013 08:42PM |
Re: Bed Auto Leveling.. z reveresed December 30, 2013 10:56PM |
Re: Bed Auto Leveling.. check this out December 31, 2013 12:32AM |
uncle_bob
If you have a servo that is not temperature stable (many of them are not), you will get the Z axis to low after a bed level.
Re: Bed Auto Leveling.. check this out December 31, 2013 08:43AM |
Re: Bed Auto Leveling.. check this out December 31, 2013 10:40AM |
Re: Bed Auto Leveling.. check this out December 31, 2013 09:45PM |
Re: Bed Auto Leveling.. check this out January 01, 2014 02:01AM |
Re: Bed Auto Leveling.. check this out January 01, 2014 05:50AM |
edn
Yes, I have the Marlin code ported to the PrintrBoard with Auto-Bed Leveling working... I do have some issues but getting close to getting them resolved.
Re: Bed Auto Leveling.. check this out January 01, 2014 05:54AM |
edn
I have Auto_Bed_Leveling working on the PrintrBoard. (I do have some issues but I'm working through them). What I've got is this code in the PINS.H file for motherboard type 81:
#ifdef NUM_SERVOS
#define SERVO0_PIN 11
#define Z_MIN_PIN 30 //needs to be updated to what ever wire is used.
That logical pin is the corner pin on the Expansion-2 Header that is closest to the main power connector. Wire that pin to your servo control wire and you should see things start to come alive.
Re: Bed Auto Leveling.. check this out January 01, 2014 06:10AM |
p40whk
regpye
After you have it working, you need to do some small adjustments to the Z offset to get it perfect.
Do the normal measurements using the nozzle down 0.01 in Pronterface followed by a M119 to get the endstop status and once you have the exact measurement that shows in the lower right hand window, use this to set your offset.
After testing you may need to adjust this amount very slightly one way or the other. It is really worth spending a bit of time to do this as it will make a huge difference to your final prints.
Once the first layer is down the rest prints nicely anyway, but the first layer is the all important layer in my opinion.
Regpye,
I've performed the nozzle offeset measurements using the M119 to verify my probe hit it's endstop and followed that with an M114 to get the offset coordinates but how do you know if you need to adjust this afterwards and in what direction?
Re: Bed Auto Leveling.. check this out January 01, 2014 10:37AM |
Re: Bed Auto Leveling.. check this out January 01, 2014 02:50PM |
regpye
edn
Can you please share how you connected the servo to the Prinrboard?
Re: Bed Auto Leveling.. check this out January 01, 2014 03:11PM |
Re: Bed Auto Leveling.. check this out January 01, 2014 06:03PM |
regpye
uncle_bob
I've tried several servos. None of them have created issues for the Mega 5V regulator.
The last machine that I just built yesterday I just shorted the 5v and the VVC pins together using a jumper link.
It is working fine, no problems. Still using a TGY-1800A servo, they seem to be good and only cost $3.99.
Bought the servos from HobbyKing, cheaper to buy in a 3 pack.
Re: Bed Auto Leveling.. check this out January 01, 2014 06:07PM |
edn
regpye
edn
Here you go. This is my current Marlin PrintrBoard build environment. I have a couple of comments for you.
Re: Bed Auto Leveling.. check this out January 01, 2014 06:08PM |
Re: Bed Auto Leveling.. check this out January 01, 2014 06:44PM |
Happycamper
Darn, just had the servo start moving on it's own again during a print. It wasn't moving like crazy like it was before the 7805, but it was every once in a while moving a little down. Probably 2-3 times a small amount.
I don't understand why it would be getting any power during a print anyway...
Re: Bed Auto Leveling.. check this out January 01, 2014 07:41PM |
Re: Bed Auto Leveling.. check this out January 02, 2014 08:05AM |
Re: Bed Auto Leveling.. check this out January 03, 2014 12:31PM |
Re: Bed Auto Leveling.. check this out January 03, 2014 07:15PM |
Re: Bed Auto Leveling.. check this out January 04, 2014 11:10AM |
