Bad edges on i3 + e3d v5
June 05, 2014 08:04AM
After a lot of tries, I still can't print with great quality.
I have:
- makerFarm i3 8";
- e3d v5 3mm;
- nozzle 0.4;
- ABS;
steps that I did
1) extruder calibrated using 100mm method ( [www.instructables.com] ); On my printer this value for У steps per 1mm is 955
2) nozzle fully cleaned;
3) Im using KISSlicer PRO, Cura, but the same result sad smiley
4) I'am trying different speeds(30mm/s, 60mm/s), different layers heights(0,15 and 0,3), temp 230C, but result is same.
5) I am using different retraction settings (lower speeds and lover length).
The main problem - is printing small paths, all long paths prints normally.
Please help!
Re: Bad edges on i3 + e3d v5
June 05, 2014 07:43PM
Looks like your Z axis needs better calibration, there are gaps showing in the back of the piece.
MakerFarm 8" Prusa i3v
RAMPS 1.4
0.4mm E3D v6 for 1.75mm
June 06, 2014 08:22AM
With my E3D hot end on my 8" makerfarm I had to put my retract at .5mm to get rid of some of those issues. With the Magma I had before it it was more like 1.2mm retract.
Id print that at 40mm/sec 225c tip and 110c bed with a .2mm layer height.
June 06, 2014 08:32AM
did you try to print at 230C or 235C?
Also I used standard black ABS 3mm from makerfarm site and it very frequently clog my 0.4 nozzle, every .5-1meter sad smiley
June 06, 2014 08:35AM
how to calibrate Z axis?
I know about Z coupling that allow to fix "Z wobbling" [www.thingiverse.com]
June 06, 2014 08:38AM
after changing retraction settings to
- extrusion length - 1mm,
- speed - 30mm/s,
- min travel before extraction - 2mm
I've got twice better results, but not ideal sad smiley
Edited 2 time(s). Last edit at 06/06/2014 08:39AM by abuharsky.
