I have tethered all the unnecessary pins and low active pins to ground, and linked the Gnd Pin to the ATX supply ground to stabilise the Grounding.
I have tried both HI and LOW settings for the Opto pins cos it could be one or another.
The motor is engaged (´cannot move and hums a little.) but does not move.
I understand it is a two wire system? Pulse and Direction??
I Have looked at other drivers and emulated their code, which is just a Hi/low toggle loop with a delay.
SO:
Is there an arduino sketch out there?
I can see indicator LEDS green and red, but i don't know how to read their meaning... I currently have
A 1B Black
B 1A Green
C 2A Blue
D 2B Red
As seen at [
reprap.org] Zapp brand NEMA17
And all the indicators are on...
I would like to know what kind of pulse I need (i have tried 500us pulses, 100ms pulses, and in between)
