What are some ways to decrease stepper motor noise and vibration?
January 14, 2017 09:21PM
I have been tuning my set up for a few weeks now and have most of it dialed in. But, I still don't have my steppers operating like I want them to. They work fine but I want to decrease the harsh changes of direction, especially for short length infill. I have gradually turned down the accelaration and jerk all the way to 750/2.5. In cura I have decresed my speeds to 30mm and 15 for infill and it is still jarring. Today I upraded my mounts and and couplers so it can handle it but I would really like it to get this sorted out. I want to make it cushion the changes in direction so i can turn the speed back up. Also, during starts of moves or transition of lines the motors will make a harsh shuddering vibration and then go back to moving smooth. That is by far the most annoying problem of all.
Any suggestions would be greatly appreciated.
I am going to try to post a copy of my configuration
open | download - My configuration.TXT (35.8 KB)
Re: What are some ways to decrease stepper motor noise and vibration?
I am running 1/32 microstepping btw.
January 14, 2017 10:27PM
If there is a mod in the building can you delete please. It told me it could not post because it thought I was a bot so I accidently doubled posted.
January 15, 2017 01:44AM
there are silent step sticks. 1/256 micro stepping (this is internal only, externally they are still 1/16 so work 8 bit controllers, but runs quiet)
[www.filastruder.com]
There is also RRD Silencioso - 128 microstep driver - Pololu compatible, real micro stepping... needs a 32 bit controller for anything over 1/32 micro stepping.
[www.reprapdiscount.com]
and im sure dc42 will chime in with his reply to everything about upgrading to his controller any moment now.
January 15, 2017 02:30AM
Yes I am actually looking for some new drivers. I want the 1/128 Pololu's so right now I am shopping around for the right 32 bit controller to control them. What controller will dc 42 recommend? Is it the re-arm controller? Because I looked it up and it looked good but I couldn't find where to buy it. I am going to keep reading up on different controllers so I don't get something and regret it. I just want a little more performance so I don't plan on spending too much.
BTW I guess I have been poking around in configuration h. too much. I started to think about what could cause the sputtering while watching it print and I realized I must have turned down the jerk setting too low and my motors were getting limited by the controller everytime they tried to accelerate. I turned it back up to 10 and it is running very smooth again. I have been doing some upgrades all day so now I can finally enjoy them.
January 15, 2017 03:10AM
re-arm has just completed its kick starter and is madly shipping out to all the backers.
The site is [www.panucatt.com]
I suspect he will be out of stock till all of those backers orders have been filled.
These are smoothieware compatibles boards and only run smoothie firmware
[smoothieware.org]
dc42 pushes duet wifi (he sells them, and screens and probes, or something like that.)
It does come with nice quiet TMC2660s Stepper drivers (onboard)
Edited 1 time(s). Last edit at 01/15/2017 03:13AM by Dust.
January 15, 2017 08:56AM
Dust
Just to be clear, it is the Duet WiFi and the forthcoming Duet Ethernet that have the TMC2660 drivers with 256x microstepping. See [www.duet3d.com]. The older Duet 0.6 and Duet 0.8.6 only do 16x microstepping.
