A better 300 colour thingy April 07, 2016 04:21AM |
Re: A better 300 colour thingy April 07, 2016 04:22AM |
Re: A better 300 colour thingy April 07, 2016 04:47AM |
Re: A better 300 colour thingy April 07, 2016 11:20AM |
Re: A better 300 colour thingy April 07, 2016 02:34PM |
Re: A better 300 colour thingy April 07, 2016 09:47PM |
Admin Registered: 15 years ago Posts: 7,311 |
Re: A better 300 colour thingy April 08, 2016 04:36AM |
Re: A better 300 colour thingy April 09, 2016 05:34PM |
o_lampe
The transition from yellow to red should show some orange, but it seems to show red OR yellow instead.
Re: A better 300 colour thingy April 09, 2016 10:33PM |
Re: A better 300 colour thingy April 12, 2016 09:24AM |
o_lampe
It looks really awesome, but the color mixing isn't working very well. Somehow unpredictable...
Is the color the same inside and outside of the part? Or is it red inside and yellow outside and vice versa?
Is it the original diamond hotend?
Re: A better 300 colour thingy April 12, 2016 09:47AM |
frankvdh
o_lampe
I wonder if that's due to the colours being mixed? I don't know what the OP is using, but maybe they're Red, Green, Blue where Cyan, Yellow, Magenta would be better? Or maybe one of the colours isn't the exact right hue?
Re: A better 300 colour thingy April 14, 2016 10:42AM |
Re: A better 300 colour thingy April 14, 2016 01:24PM |
gmh39
Would a longer melt zone allow the colors to mix better? I would think it would since the filament would be spending more time in the heating area of the nozzle.
Re: A better 300 colour thingy April 14, 2016 03:00PM |
Re: A better 300 colour thingy April 15, 2016 01:26PM |
frankvdh
I wonder about threading the inside of the nozzle, so that the molten filament swirls as it comes out?
Re: A better 300 colour thingy April 16, 2016 03:34AM |
Re: A better 300 colour thingy April 16, 2016 07:09AM |
o_lampe
The size of a chamber is only relevant because the slicers are not up to the multicolor task yet. Only the outer perimeters have to have a defined color while the rest( like infill and support ) could act as color change area too. The slicer would need to know how much filament has to be extruded before the "new" color is mixed.
With a bigger chamber I would ignore the higher filament cost if I get a sharp and true color change as benefit.
Maybe it would be possible to print a segment of 1 colour, move away to print some non-visible area or into a purge area and then return to continue the perimeter in the new colour. Man, there sure is a world of possibilities to explore here!
Re: A better 300 colour thingy April 16, 2016 12:39PM |
JamesK
o_lampe
That works for some models, but assumes that colour changes only happen in Z. For colour changes in the XY plane things get a bit more difficult, although... I guess I'm making assumptions tooMaybe it would be possible to print a segment of 1 colour, move away to print some non-visible area or into a purge area and then return to continue the perimeter in the new colour. Man, there sure is a world of possibilities to explore here!
Re: A better 300 colour thingy April 16, 2016 05:29PM |
JamesK
Re: A better 300 colour thingy April 17, 2016 04:12AM |
frankvdh
JamesK
While that's certainly true in general, it doesn't matter too much when printing cylinder-esque objects like the example shown. If all the colour changes happen at the nozzle exactly 10mm (say) after the change is made, and all printing is done in a(say) a clockwise direction, then all that happens is that the colour change is rotated by 10mm around the perimeter of the object.
Re: A better 300 colour thingy April 17, 2016 05:28AM |
frankvdh
JamesK
