Re: Aluminium RepRap with leadscrews January 08, 2014 07:10PM |
Re: Aluminium RepRap with leadscrews January 08, 2014 11:14PM |
Re: Aluminium RepRap with leadscrews January 10, 2014 01:19PM |
Re: Aluminium RepRap with leadscrews January 10, 2014 04:53PM |
Re: Aluminium RepRap with leadscrews January 10, 2014 06:33PM |
Re: Aluminium RepRap with leadscrews January 11, 2014 04:18PM |
Re: Aluminium RepRap with leadscrews January 11, 2014 05:07PM |
Re: Aluminium RepRap with leadscrews January 17, 2014 01:40PM |
samp20
Can you be a bit more specific describing the "vertical wall with a hole"?
This sort of test would show the issue I think you're talking about: [www.thingiverse.com]. The ringing issue was the main reason for me switching to leadscrews.
For reference here's how bad the ringing was with my old printer:
Re: Aluminium RepRap with leadscrews January 17, 2014 06:32PM |
Unfortunately the ringing issue isn't completely eliminated, but massively reduced. I think lowering the acceleration will help a bit further.Quote
karabas
Yes! exactly what I mean.
Is ringing issue eliminated?
About video. It seems X and Y sounds are different. X carriage is more quiet. Yes?
Re: Aluminium RepRap with leadscrews January 18, 2014 04:45PM |
How can it be?? Frame vibrations? I dont thinks so.Quote
samp20
Unfortunately the ringing issue isn't completely eliminatedQuote
karabas
what about car noise removing foam?Quote
The Y axis is noisier than the X. I think the frame and bed are amplifying the vibrations a bit. Some decoupling similar to this idea could work: [www.thingiverse.com], although there's a risk of reintroducing the ringing.
Re: Aluminium RepRap with leadscrews January 18, 2014 06:13PM |
I think it might be the plastic deforming slightly. Ideally I need a stiffer leadscrew nut holder on the X carriage.Quote
karabas
The only thing I can imagine is that motors cannot stop instantly...
Would this be for an enclosure? An enclosure would only hide the source of the noise rather than sorting the problem itself. That being said I have since put some felt which I had available onto the feet which reduces the noise transmitted through the floor.Quote
karabas
Re: Aluminium RepRap with leadscrews January 19, 2014 04:42AM |
I see bed plays along the lead screw. It means flexible bed to nut attachment OR bed springs ( if your bed stands on springs). I have similar on my belt driven bed due to flexible belt holder and spring posts.Quote
samp20
karabas
karabas
I've since recorded some slow motion video (1/8 speed) of the axes with my phone. The Y axis has some obvious oscillation issues. If you look close enough at the following YouTube video the entire leadscrew is moving which indicates flexing in the thrust bearing holders: [www.youtube.com]. The distance moved is 1mm.
Re: Aluminium RepRap with leadscrews January 25, 2014 03:28PM |
Re: Aluminium RepRap with leadscrews February 07, 2014 11:54AM |
Re: Aluminium RepRap with leadscrews February 09, 2014 04:04PM |
Sorry, I'm feeling a bit ill at the moment with my Crohn's, so not much more progress lately. I have done a bit of cable management since last time, but that's about it.Quote
karabas
Any news?
Re: Aluminium RepRap with leadscrews February 20, 2014 05:26PM |
Re: Aluminium RepRap with leadscrews February 21, 2014 01:34AM |
Re: Aluminium RepRap with leadscrews February 21, 2014 02:11AM |
Re: Aluminium RepRap with leadscrews February 25, 2014 03:39AM |
The effective pitch is the distance the leadscrew will move per 1 revolution. This will determine the steps/mm of your printer. Also you can get multi-start leadscrews which have multiple threads. This allows for a smaller diameter leadscrew. The screws I have cost roughly £45 each including the nut.Quote
Staffordknot
I'm not entirely sure what the figures on pitch etc mean or how they effect the performance?
Do you mind me asking how much each one cost?
Cheers
Re: Aluminium RepRap with leadscrews March 04, 2014 03:58AM |
Re: Aluminium RepRap with leadscrews March 18, 2014 07:34PM |
Re: Aluminium RepRap with leadscrews March 18, 2014 08:02PM |
Re: Aluminium RepRap with leadscrews March 19, 2014 04:34AM |
Re: Aluminium RepRap with leadscrews March 19, 2014 07:26PM |
Re: Aluminium RepRap with leadscrews March 19, 2014 08:14PM |
Re: Aluminium RepRap with leadscrews March 20, 2014 07:08PM |
Re: Aluminium RepRap with leadscrews March 20, 2014 07:29PM |
Did you fix it?Quote
samp20
The problem was a flexible bed to nut attachment. I've now designed and printed a sturdier mount which seems to have significantly improved things. I've also shimmed the bed to linear bearing mounts with a few pieces of paper to get the leadscrew nut holder vertically centred. The new mount and the paper have also reduced the vibration to levels I think are acceptable.
Re: Aluminium RepRap with leadscrews March 20, 2014 08:17PM |
Re: Aluminium RepRap with leadscrews March 20, 2014 08:57PM |
Re: Aluminium RepRap with leadscrews October 03, 2015 05:00AM |
