First Printer, 225mm^3 printer / mill combo build February 13, 2014 02:41PM |
Re: First Printer, 225mm^3 printer / mill combo build February 13, 2014 07:37PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 10:19AM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 10:24AM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 01:34PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 01:48PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 02:13PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 02:33PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 03:01PM |
Re: First Printer, 225mm^3 printer / mill combo build February 14, 2014 07:47PM |
Re: First Printer, 225mm^3 printer / mill combo build February 17, 2014 04:18PM |
Re: First Printer, 225mm^3 printer / mill combo build February 17, 2014 06:18PM |
Re: First Printer, 225mm^3 printer / mill combo build February 17, 2014 06:39PM |
Re: First Printer, 225mm^3 printer / mill combo build February 17, 2014 11:31PM |
Re: First Printer, 225mm^3 printer / mill combo build February 17, 2014 11:48PM |
Re: First Printer, 225mm^3 printer / mill combo build February 18, 2014 05:33AM |
Re: First Printer, 225mm^3 printer / mill combo build February 19, 2014 09:08AM |
Re: First Printer, 225mm^3 printer / mill combo build February 21, 2014 11:54AM |
Re: First Printer, 225mm^3 printer / mill combo build February 21, 2014 02:20PM |
Tired2
I'm not sure if this has made all the rounds yet, but for us extrusion builders...
[www.reddit.com]
$150 off if you have never ordered from misumi before, just pay shipping. No minimum.
I thought "I'll get some spare extrusion", and now I've got $300 worth of parts that I have to weed down to a reasonable value.
Re: First Printer, 225mm^3 printer / mill combo build February 21, 2014 02:55PM |
Re: First Printer, 225mm^3 printer / mill combo build February 21, 2014 03:54PM |
Re: First Printer, 225mm^3 printer / mill combo build February 21, 2014 04:28PM |
Re: First Printer, 225mm^3 printer / mill combo build February 22, 2014 12:48AM |
Part Desc Qty Ea Total AGTFW24-GT3090-6 3GT 24 tooth double bearing 9mm belt 6mm shaft 2 $30.82 $61.64 GPA24GT3090-B-P6 3GT 24 tooth high torque drive, 9mm belt, 6mm bore - NEEDS DRILLED 1 $16.71 $16.71 GPA24GT3090-A-P6.35 3GT 24 tooth high torque drive, 9mm belt, 1/4" bore 1 $14.84 $14.84 GBN11133GT-90 3GT Belt , 9mm x 1117mm, X Axis closed 1 $13.78 $13.78 GBN8103GT-90 3GT Belt , 9mm x 810mm, Y Axis closed 1 $11.40 $11.40 NFBG32-6-25-B bendy feet 4 $5.97 $23.88 HBLFSSW8 z axis gussets, cast, curved 2 $4.25 $8.50 SC608ZZ skate bearing 7 $1.56 $10.92
Re: First Printer, 225mm^3 printer / mill combo build February 22, 2014 01:54AM |
Re: First Printer, 225mm^3 printer / mill combo build February 24, 2014 11:23PM |
Re: First Printer, 225mm^3 printer / mill combo build February 25, 2014 08:39PM |
Re: First Printer, 225mm^3 printer / mill combo build February 26, 2014 05:20PM |
Re: First Printer, 225mm^3 printer / mill combo build March 04, 2014 07:58PM |
Re: First Printer, 225mm^3 printer / mill combo build March 04, 2014 10:15PM |
Re: First Printer, 225mm^3 printer / mill combo build March 05, 2014 11:22PM |
