RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 05, 2014 07:50PM |
Admin Registered: 11 years ago Posts: 954 |
---- "Let me make my move" ---- |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 06, 2014 12:06AM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 06, 2014 08:17AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 06, 2014 09:17PM |
Gordie
I thought to use the leadscrew on just one side of the X axis were you now see the NEMA mount, but I think I can get too friction on the opposite sliding IGUS carrier because on pulling and pushing there will be angular movement on the blue carrier. I hope you understand what I mean.
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 07, 2014 09:22AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 07, 2014 01:27PM |
The holding torque of the stepper on the lead screw isn't of too much concern, as much as it's top speed, torque at speed, and acceleration ability. You would have a hard time driving a NEMA 23 past 1000 RPM, especially with inexpensive drivers. Plus, the torque drops off a huge amount at high speeds, especially if you are only running at 12V. 1000 RPM translates to 167 mm/s, which isn't bad if you have enough torque left at that speed to not skip steps. In the end it may very well be possible to use a screw driven Y without any detriment to print speed with proper drivers, motors, and supply voltage, but some experimentation would need to be done and I'm still not sure if it would give enough of a benefit to be worth the trouble and expense.Quote
Gordie
I thought the leadscrew could be strong and fast enough as it has a 10mm of step travel and the NEMA 23 has 15kg.cm holding torque.
The rest of the project looks nice. It would be great to have a multi-function machine that has easily changeable heads for different types of manufacturing. In fact I have been working on a design for a small CNC router that should also work as a decent, if a bit slow, 3D printer or laser engraver with the right tool heads. It's very much preliminary though and I don't have much more than a conceptual CAD model, but my intent is to make as rigid of a machine as possible using large aluminum extrusions, stiff joints, and strong linear guides. All three axes would be screw driven, and would hopefully be able to mill aluminum at a decent speed. Trying to keep the cost down is proving difficult since good lead screws and guides are expensive, although the basic frame should have a reasonable cost.Quote
Gordie
What do you think about the rest of the project?
Floating bearings on one rail of each axis would be a good idea. It reduces friction, makes assembly and alignment easier, and doesn't hurt accuracy as long as the loads are reasonable. I could potentially see an increase in deflection of the axes under high load conditions versus using fixed bearings on both rails, but you are probably more limited by the belt drive in that regard anyways.Quote
Gordie
Look here, at the IGUS page, they talk about floating bearings in Y and Z axises, what do you think? Shuold I use those bearings for compensate misalignment? If so where? Should I lost precision when engraving by using those floating bearing? (I know one fixed and one floating, I'm not saying "every bearing must be floating")
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 07, 2014 02:05PM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 07, 2014 03:41PM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 08, 2014 09:13AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 10, 2014 05:19PM |
The X axis would be a moving carriage attached to rails that run along the upper horizontal extrusions.Quote
Gordie
Hi, yes your moving bed allows for increased rigidity and accuracy, but what about X axis? Has your machine only the bed moving?
SolidWorks.Quote
Gordie
I really like your render, what software did you use?
There's some discussion on whether GT2 is better than T2.5 for linear motion. GT2 supposedly has a better tooth profile for reducing backlash, but I have doubts that it makes a significant difference versus using a proper pulley with T2.5. GT2 is also typically fiberglass-reinforced, where T2.5 is steel-reinforced. T2.5 will therefore be stiffer, but as a consequence cannot bend as tightly as GT2 (resulting in a larger minimum pulley diameter).Quote
Gordie
Edit: I forgot to ask you, what kind of belt do you suggest for mine Y,X Axis? GT2?
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 23, 2014 03:29PM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts March 26, 2014 10:51AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts April 01, 2014 10:42PM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts April 01, 2014 11:39PM |
Now that is a shame you didn't research a little bit more on using ballscrews for printer I'm a big advocate of using them but the ones you chose are absolutely no good. At 4 mm per turn it's going to be the slowest 3-D printer ever made you need at least 16mm per turn and preferably 20 mm or above per turn to reach printing speeds. And as a mill it is also terrible nowhere near strong enough about the only thing you possibly could do is mill a circuitboard balsa or StyrofoamQuote
powool
I'm about 2/3 of the way through something similar to what Gordie proposes and Tired2 is doing (I have similar motivations as Gordie wrote).
A thought I had recently, while trying to hand make parts to get the printer up and running so I can print the final parts is this:
Doing a nice job of a combo printer/light mill would have been a lot easier if I had a small decent quality 3D printer.
So, Chaucer caught my eye as a good start for such a thing.
A good use case is to print threadless ball screws, so I wouldn't have had to buy 1204 ball screws from ebay. In addition, mounting the motors, linear motion stuff, and so on, would have been a lot easier.
I think designing a combo printer/light mill using such parts and an existing small printer would result in much lower cost.
I'll attach an image of my design using ballscrews - the openscad files are a work in progress, and were intended to show proof of concept to me, so do not look finished. I really do like the U-groove ball bearings on ground steel rods - that part I think worked out really well. My base is 3/4 inch Mic 6 aluminum plate.
My printer [attachment 29855 printer2.png] is shown with 1605 ballscrews, which are way too big, I bought 1204 instead. I have nema 23 steppers, arduino due, and ramps-fd sitting on my lap as I type this. Hoping to get it working at 24 volts, although I originally wanted to run 36, but the ramps-fd has 35 volt capacitors on it. I do have one massmind stepper controller, and I may wire a pair of those into the ramps-fd board and use higher voltage for the X and Y axes. The Z axis is not performance critical for 3D printing.
Paul
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts April 02, 2014 08:02AM |
cnc dick
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts April 02, 2014 09:50AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts April 07, 2014 04:24AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts July 14, 2014 08:49AM |
Gordie
(The linear guides used are IGUS Drylin T more specs here: [www.igus.com] and here: [www.igus.com]
Gordie
Gordie
What do you think about the X axis concept?
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts July 16, 2014 06:07AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts July 16, 2014 07:08AM |
Re: RepStrippa, my plans on a multifunction 3D printer Comments are welcome, let me know your thoughts August 25, 2014 07:02PM |
