Re: FLSUN I3 kit review December 03, 2016 11:50AM |
Re: FLSUN I3 kit review December 03, 2016 01:50PM |
Re: FLSUN I3 kit review December 03, 2016 07:19PM |
Re: FLSUN I3 kit review December 03, 2016 09:28PM |
Re: FLSUN I3 kit review December 03, 2016 09:47PM |
Re: FLSUN I3 kit review December 03, 2016 10:22PM |
Re: FLSUN I3 kit review December 03, 2016 11:26PM |
Re: FLSUN I3 kit review December 04, 2016 12:55AM |
Re: FLSUN I3 kit review December 04, 2016 12:04PM |
Re: FLSUN I3 kit review December 05, 2016 03:56AM |
Re: FLSUN I3 kit review December 05, 2016 10:33AM |
Re: FLSUN I3 kit review December 11, 2016 01:33PM |
Re: FLSUN I3 kit review December 22, 2016 10:05AM |
Re: FLSUN I3 kit review December 22, 2016 05:33PM |
Re: FLSUN I3 kit review December 23, 2016 10:44AM |
Re: FLSUN I3 kit review December 25, 2016 12:53AM |
Re: FLSUN I3 kit review January 10, 2017 05:01AM |
KingDWS
I see you had about the same issues I did. Mostly the head scratching for a few minutes trying to figure out if that's what they mean or am I misunderstanding type of problem. Those manuals are definitely not written by a native English speaker. The extruder calibration was the first thing I did as well and it was set to 60 and took 145ish to get 100 on mine as well. A few other guys and myself found the center of our build plates had a slight indentation in the center. Just enough to a make things be annoying and not stick well. Most ended up with using a glass plate to get around it.
One really good thing is a series of calibrations here on the forum. I just searched for calibration and found it. It goes through a bunch of different exercises to get everything from Temps to speeds closer. Really worth trying. That and if you have it printing go to Thingiverse and grab the files to print thumb wheels to use instead of those wing nuts. Much easier to get the bed set, that and a 8 thou feeler gauge instead of the paper (it's more stable than paper etc etc, I have a spare set cuz wife won't let me work on our m-class lol). The thumb wheels really make it easy to align the bed fast.
Re: FLSUN I3 kit review January 11, 2017 03:41PM |
Re: FLSUN I3 kit review January 11, 2017 06:13PM |
Re: FLSUN I3 kit review January 11, 2017 06:56PM |
Re: FLSUN I3 kit review January 11, 2017 10:53PM |
Re: FLSUN I3 kit review January 12, 2017 03:26AM |
KingDWS
The calibration stuff can be found at [reprap.org] and [reprap.org]
It looks a bit daunting but it just cuts down the calibration into a dozen or so steps or focused areas. Printing will be involved so have some filament handy! This is a bit easier when done while connected to Repetier. You could probably blast through this in a day but I would take it easy and make sure. I can't really add anything to what they get you to do other than after a bit go around and check your screws for tightness. These are small prints but they will still work the odd screw loose.
I started with Triffids but found that it wasn't addressing all the areas so I went through the other one as well. It is worth the time as you quickly go from blobs to pretty nice quality.
Re: FLSUN I3 kit review January 12, 2017 04:25AM |
Re: FLSUN I3 kit review January 12, 2017 09:31AM |
Re: FLSUN I3 kit review January 12, 2017 01:13PM |
Re: FLSUN I3 kit review January 12, 2017 01:18PM |
Re: FLSUN I3 kit review January 12, 2017 01:20PM |
KingDWS
There are two Z motor connections on the board so is just plug and play, no need to make anything. Just look at the picture of the board in the manual (pdf) that shows where everything goes.
Re: FLSUN I3 kit review January 12, 2017 05:08PM |
Ynothna
Mine doesn't seem to have 2 connections, and the manual I have shows an adapter used to connect both motors to a single plug on the board. The only other motor plug I have is for another extruder.
Re: FLSUN I3 kit review January 12, 2017 05:39PM |
fadroid
Which board do you have? is it the ramps 1.4plus? (this one has 3 ports for the Z, and they are all the same, one in the regular location under the Z marking, and two vertically placed on its right side)
send a picture of your board if you are not sure.
Re: FLSUN I3 kit review January 12, 2017 07:45PM |
