Re: I can "Air Print" June 16, 2018 11:05AM |
o_lampe
I guess the glass IS a little wavey
If you want to find out if it's wavey or binding mechanics, you could rotate the bed. ( Maybe not, because you glued the bedholder to the glass )
dc42
It looks like you have a slight twist in your gantry too, unless it's the glass again.
Re: Black Beauty Build Log June 20, 2018 08:56AM |
Re: Black Beauty Build Log July 02, 2018 08:29PM |
Re: Black Beauty Build Log July 03, 2018 10:14AM |
Re: Black Beauty Build Log July 03, 2018 10:16AM |
Re: Black Beauty Build Log July 03, 2018 11:35AM |
whosrdaddy
Sorry, above comment may seem rude! Forgot to say, awesome cabling job!
/Kris
Re: Black Beauty Build Log July 03, 2018 03:31PM |
Re: Black Beauty Build Log July 03, 2018 08:30PM |
Re: Black Beauty Build Log July 03, 2018 08:40PM |
gtj
BTW, 2.0 isn't stable for me at all. I get random restarts even with everything at idle. No errors, nothing.
Back at 1.21 everything's stable.
Re: Black Beauty Build Log July 03, 2018 08:56PM |
dc42
gtj
Can you try 2 01beta? It fixes a possible contention between two tasks. If it doesn't help, please run M122 after one of those restarts and post the software reset data and the stack trace.
Re: Black Beauty Build Log July 03, 2018 09:23PM |
Re: Black Beauty Build Log July 03, 2018 10:57PM |
gtj
dc42
gtj
Yeah, that's what I was running, sorry. I'll try again and do the M122.
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet Ethernet 1.02 or later Board ID: 08DGM-95BNL-MGPSJ-6JTD8-3SS6K-11XHZ Used output buffers: 2 of 20 (2 max) === RTOS === Static ram: 28476 Dynamic ram: 95892 of which 0 recycled Exception stack ram used: 176 Never used ram: 6528 Tasks: NETWORK(ready,1612) HEAT(blocked,1336) MAIN(running,3656) Mutexes: FilamentSensors(null) DHT(null) W5500(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null) === Platform === Last reset 00:00:40 ago, cause: software Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6420 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 33.5, current 34.4, max 34.8 Supply voltage: min 1.9, current 2.0, max 2.2, under voltage events: 0, over voltage events: 0 Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Date/time: 1970-01-01 00:00:00 Slowest loop: 0.23ms; fastest: 0.06ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.45ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1) Telnet(0) HTTP sessions: 0 of 8 Interface state: 5 === Expansion ===
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-95BNL-MGPSJ-6JTD8-3SS6K-11XHZ Used output buffers: 2 of 20 (2 max) === RTOS === Static ram: 28476 Dynamic ram: 95892 of which 0 recycled Exception stack ram used: 176 Never used ram: 6528 Tasks: NETWORK(ready,1612) HEAT(blocked,1336) MAIN(running,3664) Mutexes: FilamentSensors(null) DHT(null) W5500(null) TelnetGCodeReply(null) HttpGCodeReply(null) Telnet(null) HTTP(null) SD1(null) SD0(null) DirSearch(null) FileSystem(null) Aux(null) USB(null) MessageBox(null) ToolList(null) SPI(null) Malloc(null) NetworkGCodeInput(null) NetworkGCodeInput(null) FileInfoParser(null) === Platform === Last reset 00:00:31 ago, cause: power up Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6420 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 30.3, current 33.7, max 33.9 Supply voltage: min 1.5, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0 Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Driver 5: ok, SG min/max not available Driver 6: ok, SG min/max not available Driver 7: ok, SG min/max not available Driver 8: ok, SG min/max not available Driver 9: ok, SG min/max not available Expansion motor(s) stall indication: no Date/time: 1970-01-01 00:00:00 Slowest loop: 0.36ms; fastest: 0.06ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.53ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2) Telnet(0) HTTP sessions: 0 of 8 Interface state: 5 === Expansion === DueX I2C errors 0
Re: Black Beauty Build Log July 04, 2018 02:27AM |
Re: Black Beauty Build Log July 04, 2018 08:57AM |
dc42
Odd, the first one says the last reset was a software one commanded by the user. This could mean that M999 was sent, or the Emergency Stop button in DWC was pressed, or it restarted at the end of doing a firmware upgrade.
The second reset shows power up as expected.
Re: Black Beauty Build Log July 04, 2018 07:00PM |
dc42
Re: Black Beauty Build Log July 05, 2018 01:57AM |
Re: Black Beauty Build Log July 05, 2018 07:36AM |
o_lampe
I wonder, if that's related to the ribbon cable connector between Duet and DueX? Where did you probe the endstop signal?
Re: Black Beauty Build Log July 06, 2018 06:05PM |
Re: Black Beauty Build Log July 14, 2018 12:03PM |
Black Beauty Has Foaled!!! July 19, 2018 07:21PM |
