Re: Grounded Experimental Delta Printer May 15, 2013 11:09AM |
Re: Grounded Experimental Delta Printer May 16, 2013 05:35AM |
Re: Grounded Experimental Delta Printer May 16, 2013 10:15AM |
Re: Grounded Experimental Delta Printer May 16, 2013 11:28AM |
Re: Grounded Experimental Delta Printer May 16, 2013 11:16PM |
Re: Grounded Experimental Delta Printer May 17, 2013 12:09AM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Grounded Experimental Delta Printer May 17, 2013 09:31AM |
Firmware could also be a challenge since I have never modified firmware before.
Re: Grounded Experimental Delta Printer May 17, 2013 10:36AM |
Re: Grounded Experimental Delta Printer May 17, 2013 10:49AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Grounded Experimental Delta Printer May 17, 2013 12:59PM |
Re: Grounded Experimental Delta Printer May 17, 2013 01:07PM |
Re: Grounded Experimental Delta Printer May 17, 2013 05:37PM |
Item Unit Cost Quantity Total Microcontroller (Azteeg) $70.00 1 $70.00 Hot End $59.00 1 $59.00 Stepper Driver $12.49 4 $49.96 2lb Plastic $38.85 1 $38.85 Stepper $9.35 4 $37.40 3x6x2 Minature Bearing $1.42 18 $25.56 Silicone Heater Bed $19.99 1 $19.99 Glass $18.00 1 $18.00 Power Supply $17.99 1 $17.99 25x37x7 Thin Section Bearing $3.93 4 $15.72 Skate Bearing $0.40 26 $10.40 Hobbed Bolt $8.00 1 $8.00 Big Spring $2.01 3 $6.03 Hall Effect Sensor $1.34 3 $4.02 M3x45 $0.22 18 $3.96 Bowden Tube $1.37 2 $2.74 Braided Filament $2.54 1 $2.54 M3x25 $0.12 21 $2.52 Bed Leveling Spring $0.82 3 $2.46 Wooden Bed $2.28 1 $2.28 M3 Stopnut $0.04 51 $2.04 .25"x.25" N48 Magnet $0.50 3 $1.50 M3x10 $0.07 21 $1.47 5/16x3 Bolt $0.24 3 $0.72 5/16 Stopnut $0.06 12 $0.72 5/16x7.5 Bolt $0.65 1 $0.65 M3x50 $0.15 4 $0.60 5/16x2 Bolt $0.12 3 $0.36 5/16x1.5 Bolt $0.11 3 $0.33 M3x4 Set Screw $0.05 3 $0.15 M3 Nut $0.02 3 $0.06 Total: $406.02
Re: Grounded Experimental Delta Printer May 18, 2013 04:42AM |
Re: Grounded Experimental Delta Printer May 18, 2013 05:17AM |
Re: Grounded Experimental Delta Printer May 19, 2013 04:50AM |
Re: Grounded Experimental Delta Printer May 19, 2013 06:23AM |
Re: Grounded Experimental Delta Printer May 19, 2013 06:54AM |
Re: Grounded Experimental Delta Printer May 19, 2013 10:04AM |
Re: Grounded Experimental Delta Printer May 24, 2013 06:06PM |
Re: Grounded Experimental Delta Printer May 27, 2013 09:32PM |
Re: Grounded Experimental Delta Printer May 28, 2013 09:42AM |
Re: Grounded Experimental Delta Printer May 28, 2013 01:56PM |
Re: Grounded Experimental Delta Printer May 28, 2013 04:22PM |
Re: Grounded Experimental Delta Printer May 29, 2013 12:56AM |
Re: Grounded Experimental Delta Printer May 29, 2013 01:26AM |
Re: Grounded Experimental Delta Printer June 01, 2013 11:07AM |
Re: Grounded Experimental Delta Printer June 01, 2013 01:03PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Grounded Experimental Delta Printer June 01, 2013 01:22PM |
Re: Grounded Experimental Delta Printer June 01, 2013 01:48PM |
Re: Grounded Experimental Delta Printer June 01, 2013 06:00PM |
