Re: 3DR "Simple" Delta Printer May 24, 2014 12:45PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 12:55PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 01:00PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 01:04PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 01:22PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 01:44PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 05:51PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 06:11PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 06:42PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 07:00PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 07:06PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 07:10PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 09:25PM |
Re: 3DR "Simple" Delta Printer May 24, 2014 11:49PM |
Re: 3DR "Simple" Delta Printer May 25, 2014 02:10PM |
Re: 3DR "Simple" Delta Printer May 25, 2014 05:04PM |
Re: 3DR "Simple" Delta Printer May 25, 2014 05:08PM |
Re: 3DR "Simple" Delta Printer May 27, 2014 09:24AM |
Re: 3DR "Simple" Delta Printer May 27, 2014 11:43AM |
Re: 3DR "Simple" Delta Printer May 27, 2014 04:16PM |
Re: 3DR "Simple" Delta Printer May 28, 2014 12:35AM |
Re: 3DR "Simple" Delta Printer May 29, 2014 10:13AM |
Re: 3DR "Simple" Delta Printer May 29, 2014 11:05AM |
Re: 3DR "Simple" Delta Printer May 29, 2014 11:46AM |
Re: 3DR "Simple" Delta Printer May 31, 2014 06:45PM |
JohnSL
It's starting to come together. Yesterday I printed the three parts that make up a third of the base. I went through several iterations before the parts you see here, which are themselves not even final. I added alignment dimples and indentations between the three parts, which makes it really easy to assemble these parts perfectly. I also added nut indentations in so you don't need a wrench to assembly the parts. I'm pretty happy with how these turned out, so I'm printing the next generation of parts in order to assembly the second third of the base.
Re: 3DR "Simple" Delta Printer June 03, 2014 10:57AM |
Re: 3DR "Simple" Delta Printer June 05, 2014 08:45AM |
Re: 3DR "Simple" Delta Printer June 05, 2014 09:05AM |
umdpru
Has anyone gotten their 3dr simple to print well? I see many have them "printing" but how many are dialed in?
Re: 3DR "Simple" Delta Printer June 06, 2014 12:02PM |
Re: 3DR "Simple" Delta Printer June 08, 2014 12:55PM |
umdpru
Very nice!
I'm quite jealous, actually. Did you have any difficulties calibrating it? What did you use to print the parts in the first place?
I had a thought last night that my steps/mm for the three axes could be causing my problems ( I left them at 55.5 default). I calibrated those and everything is very close so that wasn't it. I'm back to waiting to finish printing a new frame.
I'm seriously hoping that the frame is the issue.
