Re: Cherry Pi III Is Available June 09, 2014 09:33AM |
AndyCart
Hi Sebastien
Mine was fine. I will upload it again though. Maybe a rogue file slipped through.
Will be sometime on Sunday
Andy
Re: Cherry Pi III Is Available June 09, 2014 04:59PM |
Re: Cherry Pi III Is Available June 09, 2014 06:31PM |
Re: Cherry Pi III Is Available June 10, 2014 08:33AM |
Re: Cherry Pi III Is Available June 11, 2014 11:15AM |
Re: Cherry Pi III Is Available June 11, 2014 02:30PM |
Re: Cherry Pi III Is Available June 12, 2014 05:48PM |
nka
Thanks a lot Andy!
Compared your setting with mine gave me some information on what to ajust. I changed some and added note to others, so I'll know what to change if it dosent go right.
Does your RAMPS use 1/16 Step? (I have the same motor as you btw, taked on AliExpress).
Re: Cherry Pi III Is Available June 12, 2014 05:56PM |
Re: Cherry Pi III Is Available June 12, 2014 08:17PM |
Re: Cherry Pi III Is Available June 13, 2014 03:01AM |
nka
Why the sort of R4 ? Tried to find informations, but I can't find any (I might be bad...).
Seems to be for the extruder.
Re: Cherry Pi III Is Available June 13, 2014 05:11PM |
Re: Cherry Pi III Is Available June 13, 2014 07:08PM |
zoltan
Hi Andy,
Thank you for design and sharing. Your design is very nice engineered. I would like to build on your design but I would like to do some changes, so, is it possible to provide igs or step files of the parts?
Re: Cherry Pi III Is Available June 15, 2014 04:12PM |
Re: Cherry Pi III Is Available June 15, 2014 05:22PM |
Re: Cherry Pi III Is Available June 15, 2014 06:12PM |
Re: Cherry Pi III Is Available June 16, 2014 08:59AM |
Re: Cherry Pi III Is Available June 16, 2014 05:31PM |
Re: Cherry Pi III Is Available June 16, 2014 08:47PM |
Re: Cherry Pi III Is Available June 20, 2014 05:22AM |
Re: Cherry Pi III Is Available June 20, 2014 08:47AM |
Re: Cherry Pi III Is Available June 20, 2014 05:24PM |
Re: Cherry Pi III Is Available June 20, 2014 08:32PM |
Re: Cherry Pi III Is Available June 23, 2014 12:34PM |
Re: Cherry Pi III Is Available June 23, 2014 11:44PM |
Re: Cherry Pi III Is Available June 24, 2014 02:10AM |
Interesting. That's not evident looking at the STLs; there's a wall at the end of the hole there. But I could see how that would make it more rigid.Quote
AndyCart
My design uses an M5 bolt through the hole and into a T nut in the tower to fix the top vertex to the tower.
So if I understand this correctly, you have two flanged bearings side-by-side, with the narrow parts together. This is where the belt sits. Is that right?Quote
AndyCart
This bolt also carries my two flanged 16mm bearings to form the top idler.
Re: Cherry Pi III Is Available June 24, 2014 08:01AM |
Re: Cherry Pi III Is Available June 24, 2014 08:03AM |
Re: Cherry Pi III Is Available June 24, 2014 10:19AM |
Re: Cherry Pi III Is Available June 24, 2014 11:10AM |
AndyCart
I'm away on vacation for a couple of weeks so can't upload any images.
AndyCart
You will probably have your machine built by the time I get home
Re: Cherry Pi III Is Available July 01, 2014 07:38AM |
