What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? September 15, 2014 03:49AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? September 16, 2014 05:15AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? September 17, 2014 05:54PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? October 10, 2014 06:22PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? October 13, 2014 04:26AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? October 13, 2014 08:12PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? October 21, 2014 12:02PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? November 12, 2014 07:21PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? November 13, 2014 07:15PM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? February 09, 2015 11:40AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? February 11, 2015 01:17AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? February 23, 2015 06:55AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? February 23, 2015 11:44AM |
Source: [whatskenmaking.com]
new DELTA_DIAGONAL_ROD = measured_length / target_length * original DELTA_DIAGONAL_ROD
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? March 07, 2015 10:21AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? April 04, 2015 12:56AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? March 12, 2016 10:50AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? March 17, 2016 12:17AM |
Re: What parts do I need to replace / modify if i use 2020 aluminum frame for Kossel Mini? March 17, 2016 12:56PM |
