Custom Delta 3d printer bed levelling problems
November 21, 2014 02:25AM
Hello everybody
Sorta new guy here.
I'm building custom 3d delta printer based on cherry pi plastic parts.
Vertical extrusions 700mm and horizontal 350mm (20x20 extrusions)
Using CF rods with magnetic joints for carriers and end effector (rods 283mm).
Made my x,y,z max end stops (mechanical) adjustable for mechanical adjustments
I'm using nema 17 steppers arduino mega + ramps 1.4 (Rich Cattell marlin) e3d v5 hot end and nema 17 with planetary gearbox for extruder
Problem:
I can dial in 3 points on front of each tower with no problems using end stop adjustments, but centre point is too high, in my case motion is concave.
was trying to increase delta smooth rod offset and delta radius in marlin, but no changes, a bit stuck in this. for last 2 days trying to find any info in web, but no luck
Can somebody give me any hint, how to sort this out, will appreciate any info
Thnx Dj
open | download - photo 1.JPG (473.9 KB)
open | download - photo 3.jpg (389.3 KB)
Re: Custom Delta 3d printer bed levelling problems
November 21, 2014 04:45AM
I'm a novice in this field, but I am adapting the Duet firmware to support delta printers, so I have recently done the maths. The factor that affects whether the printing plane is flat, convex or concave in Marlin firmware is the ratio between DELTA_RADIUS and DELTA_DIAGONAL_ROD. I assume you have set DELTA_DIAGONAL_ROD correctly to the distance between the centres of the universal joints on each rod. So you probably have DELTA_RADIUS wrong.
For each pair of diagonal parallel rods, imagine the point midway between the two universal joints at at one end of the pair, and the point midway between the two joints at the other end. The outer 3 points are on a circle of radius R1 centred on the printer central axis (when the carriages are all at the same Z level). The inner points are on a circle of radius R2 centred on the centre of the effector. Then DELTA_RADIUS should equal R1 - R2. In the standard Marlin firmware, DELTA_EFFECTOR_OFFSET is meant to be R2, while DELTA_SMOOTH_ROD_OFFSET-DELTA_CARRIAGE_OFFSET should equal R1. But it doesn't matter exactly how you set these 3 parameters (DELTA_EFFECTOR_OFFSET, DELTA_SMOOTH_ROD_OFFSET, DELTA_CARRIAGE_OFFSET) as long as DELTA_RADIUS comes out correctly.
Edited 1 time(s). Last edit at 11/21/2014 03:26PM by dc42.
November 21, 2014 08:49AM
Thanks for response, will try to play with them as soon i will get home
Dj
November 21, 2014 10:11AM
If you can handle a bit of math (and know or are willing to learn a bit of maxima) then you can use this approach to calibration:
[github.com]
It allows you to calibrate your printer as precisely as possible in one step.
If you cannot handle the math then it may be still useful to read the comments in the document.
I just updated the notebook. I did not upload my Repetier branch yet but the Marlin branch is there.
November 21, 2014 10:38AM
Looks awesome, definitely will try
Thank You hercek
Dj
November 22, 2014 05:34AM
Hello guys again.
Just sited down to computer, willing to try advised techniques,
issued m666 l in pronterface and realised that all changes witch i made in configuration.h (marlin) are not taken in account. as example i set #define DEFAULT_DELTA_DIAGONAL_ROD 305.0, upload changes to arduino mega, when i issued m666l it shows : R (Delta Radius): 176.00 D (Diagonal Rod Length): 283.00 H (Z-Height): 242.00
I'm getting confused
Dj
Edit:
Just realised, in pronterface doing changes with m666 r does all necessary changes.
One step closer
Dj
Edited 2 time(s). Last edit at 11/22/2014 06:16AM by didzix.
November 24, 2014 06:15AM
I had similar problems with my delta a few days ago. I adjusted my Endstops ABC until I could get a piece of paper under the Nozzle. In Center, the nozzle was to high. I increased Delta Radius, rehomed and got the nozzle to center again: no change, still to high.
Solution: after you changed Delta Radius, You have to readjust the Endstops again to have the change at center! Maybe you need 2 or 3 Iteration to get the Printhead flat at ABC and center.
Watch the print result here
Manu
November 26, 2014 02:19AM
didzix
Hello guys again.
Dj
Edit:
One step closer
Dj
Don't forget to issue an M500 command to save all the changes. You will lose them when you power down if you don't! Ask me how I know? Lol
December 09, 2014 11:22AM
Hercek,
I downloaded WXMaxima, and pasted the code in directly from calibration.wxm from your github above and got the error in 'WXMax_Error.jpg', attached.
Then I downloaded the zip from the github and just double clicked the calibration.wxm file and got a different error, shown in 'WXMax_Run_Error' attached. The first time I've heard of wxmaxima was about 10 minutes before i tried using it so it's probably something wrong on my end tongue sticking out smiley
I'm having the same issue as the guys here though; my "Bed" plane through 0,0,0, is convex, it's touching the glass at (-100, 00, 0,) and (+100, 0, 0) but at (0,0,0) the tip is about 1.5mm off the glass plate.
The frame is wooden & the top and bottom plate are made of separate planks screwed together, so I'll probably be attempting to make good use of your tower error programs too :L
open | download - WXMax_Run_Error.PNG (144.3 KB)
open | download - WXMax_Error.PNG (90.6 KB)
December 09, 2014 04:43PM
As for as the errors: Most people using this on Windows had problems with symbols names α,β,γ. Try to open it first in some editor and do search and replace: α -> alpha, β -> beta, γ -> gama. If it does not help then I do not really know. I used it on Linux. It works fine there. The document is UTF-8 encoded Unicode text. If you find the windows maxima in-usable with the notebook you can try this: [github.com] (Dejay ported it to a C/C++ application - I did not use it so I do not know more about it).
As for as your bed level error: You provided too small info to have an idea what calibration data are wrong. At least 7 points must be provided to guess manually. The document needs at least 8 points to run the computation. If you want to try to calibrate manually then read the comments in the documents. There are some hints there for which kind of errors.
If your frame is solid (no wiggle while head is moving), and the joints/sliders do not have an unwanted play, and the bed is planar, and towers are equidistant and almost perfectly perpendicular to bed then the document will find the best calibration parameters possible. Good luck.
PS: I still did not publish my Repetier branch to use with the maxima notebook. If you want to do it with Repetier instead of Marlin then let me know. I'll try to do it soon.
December 25, 2014 01:02PM
FIRST OF ALL PERMISSION TO PUBLISH AM MarceloVivanco of Argentina settled in Peru / Lima making a Reprap club in Peru spreading free software for all and start with 3D printers and I got the typical box in PLA and the star but I can not make parts larger ...
3D auto-leveling problems delta
G 28
PLAYING IN THE FIRST VIDEO OVER 100 TIMES probing BED
THEN FOUND IN A MATRIX CPP MARLIN TO WHO MAY MODIFY AND JUST REDUCED AMOUNT 3X3 DOT MATRIX
DO WHEN YOU FINISH G29
  GIVES THE FOLLOWING REPORT AND THEN WHAT I KEEP WITH M500
SHIPPING AND THEN HAVE SEVERAL CHANGES M666 AS THE CORRECTION IN EACH TOWER MM NOT GET MORE DETAILS IN THE DETAILS OF PRONTERFACE
THE G1 Z0 AUTOLEVEL ARRIVE BEFORE PERFECT AND THEN GETS A 6 CM GLASS AS I DO TO START PRINTING NEED SOME COUNCIL I LEAVE THE RESULT AFTER PRONTERFACE AUTOLEVEL AND MY CONFIG.H
I am very eager to replicate my spare 3D delta and start making Reprap Club Peru Lima and make ongoing armed delta 3D printer
>>>G29
SENDING:G29
6.488 6.488 6.488 6.000 5.825 5.825 5.825
5.475 5.475 5.200 4.775 4.688 4.700 4.700
6.337 5.300 4.362 3.962 3.487 3.250 3.487
6.087 5.000 4.325 3.825 3.162 2.862 2.800
7.987 6.587 5.350 4.112 2.987 2.350 2.375
6.387 6.387 4.962 3.950 3.212 2.625 2.625
6.700 6.700 6.700 4.412 3.362 3.362 3.362
>>>M500
SENDING:M500
echoconfused smileyettings Stored
>>>M666L
SENDING:M666L
Current Delta geometry values:
X (Endstop Adj): 0.00
Y (Endstop Adj): 0.00
Z (Endstop Adj): 0.00
P (Z-Probe Offset): X0.00 Y10.00 Z15.00
A (Tower A Position Correction): 0.00
B (Tower B Position Correction): 0.00
C (Tower C Position Correction): 0.00
I (Tower A Radius Correction): 0.00
J (Tower B Radius Correction): 0.00
K (Tower C Radius Correction): 0.00
R (Delta Radius): 123.48
D (Diagonal Rod Length): 253.00
H (Z-Height): 274.80
Connecting...
start
Printer is now online.
echo:Marlin 1.0.0
echo: Last Updated: Dec 10 2014 08:22:45 | Author: (3Delta Reprap Lima Peru)
Compiled: Dec 10 2014
echo: Free Memory: 3260 PlannerBufferBytes: 1232
echoconfused smileytored settings retrieved
echoconfused smileyteps per unit:
echo: M92 X80.00 Y80.00 Z80.00 E100.00
echo:Maximum feedrates (mm/s):
echo: M203 X200.00 Y200.00 Z200.00 E200.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X6000 Y6000 Z6000 E9000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echo:Endstop adjustment (mm):
echo: M666 X0.00 Y0.00 Z0.00
echogrinning smileyelta Geometry adjustment:
echo: M666 A0.00 B0.00 C0.00 E0.00 F0.00 G0.00 R123.48 D253.00 H274.80 P0.00
echotongue sticking out smileyID settings:
echo: M301 P15.34 I1.57 D37.45
CONFIG.H
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
// This configuration file contains the basic settings.
// Advanced settings can be found in Configuration_adv.h
// BASIC SETTINGS: select your board type, temperature sensor type, axis scaling, and endstop configuration
// User-specified version info of this build to display in [Pronterface, etc] terminal window during
// startup. Implementation of an idea by Prof Braino to inform user that any changes made to this
// build by the user have been successfully uploaded into firmware.
#define STRING_VERSION_CONFIG_H __DATE__ " " __TIME__ // build date and time
#define STRING_CONFIG_H_AUTHOR "(3Delta Reprap Lima Peru)" // Who made the changes.
// SERIAL_PORT selects which serial port should be used for communication with the host.
// This allows the connection of wireless adapters (for instance) to non-default port pins.
// Serial port 0 is still used by the Arduino bootloader regardless of this setting.
#define SERIAL_PORT 0
// This determines the communication speed of the printer
//#define BAUDRATE 250000
#define BAUDRATE 115200
//// The following define selects which electronics board you have. Please choose the one that matches your setup
// 10 = Gen7 custom (Alfons3 Version) "https://github.com/Alfons3/Generation_7_Electronics"
// 11 = Gen7 v1.1, v1.2 = 11
// 12 = Gen7 v1.3
// 13 = Gen7 v1.4
// 3 = MEGA/RAMPS up to 1.2 = 3
// 33 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed)
// 34 = RAMPS 1.3 / 1.4 (Power outputs: Extruder0, Extruder1, Bed)
// 35 = RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Fan)
// 4 = Duemilanove w/ ATMega328P pin assignment
// 5 = Gen6
// 51 = Gen6 deluxe
// 6 = Sanguinololu < 1.2
// 62 = Sanguinololu 1.2 and above
// 63 = Melzi
// 64 = STB V1.1
// 65 = Azteeg X1
// 66 = Melzi with ATmega1284 (MaKr3d version)
// 7 = Ultimaker
// 71 = Ultimaker (Older electronics. Pre 1.5.4. This is rare)
// 77 = 3Drag Controller
// 8 = Teensylu
// 80 = Rumba
// 81 = Printrboard (AT90USB1286)
// 82 = Brainwave (AT90USB646)
// 9 = Gen3+
// 70 = Megatronics
// 701= Megatronics v2.0
// 702= Minitronics v1.0
// 90 = Alpha OMCA board
// 91 = Final OMCA board
// 301 = Rambo
// 21 = Elefu Ra Board (v3)
#ifndef MOTHERBOARD
#define MOTHERBOARD 33
#endif
// Define this to set a custom name for your generic Mendel,
#define CUSTOM_MENDEL_NAME "Delta"
// This defines the number of extruders
#define EXTRUDERS 1
//// The following define selects which power supply you have. Please choose the one that matches your setup
// 1 = ATX
// 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
#define POWER_SUPPLY 1
//============================== Delta Settings =============================
// Enable DELTA kinematics
#define DELTA
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 200
// Center-to-center distance of the holes in the diagonal push rods.
#define DEFAULT_DELTA_DIAGONAL_ROD 253.00 // mm
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 211.50 // mm //158
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 46.02 // mm
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 42.00 // mm
// Effective horizontal distance bridged by diagonal push rods.
#define DEFAULT_DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET)
//Uncomment to enable autocalibration debug messages
//#define DEBUG_MESSAGES
// Precision for G30 delta autocalibration function
#define AUTOCALIBRATION_PRECISION 0.03 // mm
// Diameter of print bed - this is used to set the distance that autocalibration probes the bed at.
#define BED_DIAMETER 100 // mm
// Z-Probe variables
// Start and end location values are used to deploy/retract the probe (will move from start to end and back again)
#define Z_PROBE_OFFSET {0, 10, 15, 0} // X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe.
#define Z_PROBE_DEPLOY_START_LOCATION {20, 96, 30, 0} // X, Y, Z, E start location for z-probe deployment sequence
#define Z_PROBE_DEPLOY_END_LOCATION {5, 96, 30, 10} // 10 ANTES 0 X, Y, Z, E end location for z-probe deployment sequence
#define Z_PROBE_RETRACT_START_LOCATION {49, 84, 20, 0} // X, Y, Z, E start location for z-probe retract sequence
#define Z_PROBE_RETRACT_END_LOCATION {49, 84, 1, 0} // X, Y, Z, E end location for z-probe retract sequence
#define AUTOLEVEL_GRID 24 // Distance between autolevel Z probing points, should be less than print surface radius/3.
//ANTES 24 // Distancia entre Autolevel Z palpaciones , debe ser menor que el radio de la superficie de impresión / 3 .
//=============================Thermal Settings ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 60 is 100k Maker's Tool Works Kapton Bed Thermister
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup)
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_BED 4
// This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Actual temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define BED_MAXTEMP 150
// If your bed has low resistance e.g. .6 ohm and throws the fuse you can duty cycle it to reduce the
// average current. The value should be an integer and the heat bed will be turned on for 1 interval of
// HEATER_BED_DUTY_CYCLE_DIVIDER intervals.
//#define HEATER_BED_DUTY_CYCLE_DIVIDER 4
// PID settings:
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX 255 // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#ifdef PIDTEMP
//#define PID_DEBUG // Sends debug data to the serial port.
//#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
#define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
// is more then PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
#define PID_INTEGRAL_DRIVE_MAX 255 //limit for the integral term
#define K1 0.95 //smoothing factor within the PID
#define PID_dT ((16.0 * 8.0)/(F_CPU / 64.0 / 256.0)) //sampling period of the temperature routine
// If you are using a preconfigured hotend then you can use one of the value sets by uncommenting it
// J-Head with 12v 40W heater cartridge
#define DEFAULT_Kp 15.34
#define DEFAULT_Ki 1.57
#define DEFAULT_Kd 37.45
// Makergear
// #define DEFAULT_Kp 7.0
// #define DEFAULT_Ki 0.1
// #define DEFAULT_Kd 12
// Mendel Parts V9 on 12V
// #define DEFAULT_Kp 63.0
// #define DEFAULT_Ki 2.25
// #define DEFAULT_Kd 440
#endif // PIDTEMP
// Bed Temperature Control
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT above is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#ifdef PIDTEMPBED
//120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
// #define DEFAULT_bedKp 97.1
// #define DEFAULT_bedKi 1.41
// #define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
//this prevents dangerous Extruder moves, i.e. if the temperature is under the limit
//can be software-disabled for whatever purposes by
#define PREVENT_DANGEROUS_EXTRUDE
//if PREVENT_DANGEROUS_EXTRUDE is on, you can still disable (uncomment) very long bits of extrusion separately.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MINTEMP 170
#define EXTRUDE_MAXLENGTH (X_MAX_LENGTH+Y_MAX_LENGTH) //prevent extrusion of very large distances.
//=============================Mechanical Settings===========================
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
// fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined
// #define ENDSTOPPULLUP_XMAX
// #define ENDSTOPPULLUP_YMAX
// #define ENDSTOPPULLUP_ZMAX
// #define ENDSTOPPULLUP_XMIN
// #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN
#endif
#ifdef ENDSTOPPULLUPS
#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR 1
#define Y_HOME_DIR 1
#define Z_HOME_DIR 1
#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below.
// Travel limits after homing
#define X_MAX_POS 90
#define X_MIN_POS -90
#define Y_MAX_POS 100
#define Y_MIN_POS -90
#define Z_MAX_POS 260.70//MANUAL_Z_HOME_POS (SIEMPRE ES MENOR H DEL EJE Z)
#define Z_MIN_POS 0
#define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS)
#define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS)
#define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS)
// The position of the homing switches
#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used
#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0)
//Manual homing switch locations:
// For deltabots this means top and center of the cartesian print volume.
#define MANUAL_X_HOME_POS 0
#define MANUAL_Y_HOME_POS 0
#define MANUAL_Z_HOME_POS 274.8 // For delta: Distance between nozzle and print surface after homing.
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {200*60, 200*60, 200*60, 0} // set the homing speeds (mm/min)
// default settings
//#define DEFAULT_AXIS_STEPS_PER_UNIT {98.5222, 98.5222, 98.5222, 760*1.1} // default steps per unit for Kossel (GT2, 20 tooth)
//GT2.0 da 100 con 16 DEINTES ---- GT MXL 2.3 con 16 DIENTES da 98.5222
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 80, 100}
#define DEFAULT_MAX_FEEDRATE {200, 200, 200, 200} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {6000,6000,6000,9000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// Desplazamiento de las extrusoras (descomentar si se utiliza más de uno y contando con firmware para posicionar al cambiar).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 20.0 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
//=============================Additional Features===========================
// EEPROM
// the microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores paramters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
//define this to enable eeprom support
#define EEPROM_SETTINGS
//to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out:
// please keep turned on if you can.
#define EEPROM_CHITCHAT
// Preheat Constants
#define PLA_PREHEAT_HOTEND_TEMP 180
#define PLA_PREHEAT_HPB_TEMP 70
#define PLA_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255
#define ABS_PREHEAT_HOTEND_TEMP 240
#define ABS_PREHEAT_HPB_TEMP 100
#define ABS_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255
//LCD and SD support
//#define ULTRA_LCD //general lcd support, also 16x2
//#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family)
#define SDSUPPORT // Enable SD Card Support in Hardware Console
//#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error)
//#define ULTIMAKERCONTROLLER //as available from the ultimaker online store.
//#define ULTIPANEL //the ultipanel as on thingiverse
// The MaKr3d Makr-Panel with graphic controller and SD support
// [reprap.org]
//#define MAKRPANEL
// The RepRapDiscount Smart Controller (white PCcool smiley
// [reprap.org]
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PCcool smiley
// [reprap.org]
//#define G3D_PANEL
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PCcool smiley
// [reprap.org]
// ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com]
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1
// [reprapworld.com]
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel
// [www.elefu.com]
// REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: [github.com]
//#define RA_CONTROL_PANEL
//automatic expansion
#if defined (MAKRPANEL)
#define DOGLCD
#define SDSUPPORT
#define ULTIPANEL
#define NEWPANEL
#define DEFAULT_LCD_CONTRAST 17
#endif
#if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER)
#define DOGLCD
#define U8GLIB_ST7920
#endif
#if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL)
#define ULTIPANEL
#define NEWPANEL
#endif
#if defined(REPRAPWORLD_KEYPAD)
#define NEWPANEL
#define ULTIPANEL
#endif
#if defined(RA_CONTROL_PANEL)
#define ULTIPANEL
#define NEWPANEL
#define LCD_I2C_TYPE_PCA8574
#define LCD_I2C_ADDRESS 0x27 // I2C Address of the port expander
#endif
//I2C PANELS
//#define LCD_I2C_SAINSMART_YWROBOT
#ifdef LCD_I2C_SAINSMART_YWROBOT
// This uses the LiquidCrystal_I2C library ( [bitbucket.org] )
// Make sure it is placed in the Arduino libraries directory.
#define LCD_I2C_TYPE_PCF8575
#define NEWPANEL
#define ULTIPANEL
#endif
// PANELOLU2 LCD with status LEDs, separate encoder and click inputs
//#define LCD_I2C_PANELOLU2
#ifdef LCD_I2C_PANELOLU2
// This uses the LiquidTWI2 library v1.2.3 or later ( [github.com] )
// Make sure the LiquidTWI2 directory is placed in the Arduino or Sketchbook libraries subdirectory.
// (v1.2.3 no longer requires you to define PANELOLU in the LiquidTWI2.h library header file)
// Note: The PANELOLU2 encoder click input can either be directly connected to a pin
// (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
#define LCD_I2C_TYPE_MCP23017
#define LCD_I2C_ADDRESS 0x20 // I2C Address of the port expander
#define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD
#define NEWPANEL
#define ULTIPANEL
#endif
// Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs
//#define LCD_I2C_VIKI
#ifdef LCD_I2C_VIKI
// Note: The pause/stop/resume LCD button pin should be connected to the Arduino
// BTN_ENC pin (or set BTN_ENC to -1 if not used)
#define LCD_USE_I2C_BUZZER //comment out to disable buzzer on LCD (requires LiquidTWI2 v1.2.3 or later)
#define NEWPANEL
#define ULTIPANEL
#endif
#ifdef ULTIPANEL
// #define NEWPANEL //enable this if you have a click-encoder panel
#define SDSUPPORT
#define ULTRA_LCD
#ifdef DOGLCD // Change number of lines to match the DOG graphic display
#define LCD_WIDTH 20
#define LCD_HEIGHT 5
#else
#define LCD_HEIGHT 4
#endif
#else //no panel but just lcd
#ifdef ULTRA_LCD
#ifdef DOGLCD // Change number of lines to match the 128x64 graphics display
#else
#define LCD_WIDTH 16
#define LCD_HEIGHT 2
#endif
#endif
#endif
// default LCD contrast for dogm-like LCD displays
#ifdef DOGLCD
# ifndef DEFAULT_LCD_CONTRAST
# define DEFAULT_LCD_CONTRAST 32
# endif
#endif
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not ass annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// M240 Triggers a camera by emulating a Canon RC-1 Remote
// Data from: [www.doc-diy.net]
// #define PHOTOGRAPH_PIN 23
// SF send wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder.
//#define BARICUDA
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Servo Endstops
// This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes.
// Use M206 command to correct for switch height offset to actual nozzle height. Store that setting with M500.
//#define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1
//#define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 70,0} // X,Y,Z Axis Extend and Retract angles
#include "Configuration_adv.h"
#include "thermistortables.h"
#endif //__CONFIGURATION_H
GREETINGS FROM LIMA PERU
December 25, 2014 01:13PM
MERRY CHRISTMAS HAPPY 2015
open | download - 5.jpg (598.6 KB)
open | download - 6.jpg (600 KB)
open | download - 14.jpg (587.8 KB)
open | download - 10.jpg (589.3 KB)
open | download - DSC00402.JPG (129.1 KB)
December 26, 2014 07:01PM
From watching the video it seems perhaps your Z probe isn't very repeatable, you can tell because it probes for a different number of times on each spot.
I believe that, for some versions of marlin, the routine will probe at one spot until it gets two consecutive readings that are the same, if the Z reading is varying each time then you will see this repeated probing, the levelling will take a long time and it won't be accurate.
Check that nothing is too loose on the Z probe or perhaps the bed fixing. You might also consider modifying the Z probe routine to print the probed height for each attempt so you can tell if you are improving the situation.
Cheers,
Robin.
December 28, 2014 08:23PM
very good:
are unequal numbers I did not realize that detail height of the bed , I hope to be more homogeneous if not the code , thanks for your prompt courteous response to your advice thanks hope to print this before the end of the year.
Thanks Zedsquared
Marcelo L, Vivanco Lima Perú.-
February 01, 2015 06:58AM
hercek
Hey,
I'm really interested! I had to switch from RichCatell's Marlin with AutoCal to Repetier because of 32bit electronics and I'm not happy with the manual calibration. I modified the g30 command of my repetier to print out the carriage positions, but it seems as i don't get the right values.
It would be really helpful, if you could release your repetier-version.
Thanks,
Jan
