Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2015 08:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2015 09:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2015 10:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2015 11:14PM |
newline
I also got the corner brackets from RobotDigg. However the top ones are unlike the ones that came with the Folger Tech. They don't have the cone shaped structure to hold the belt pulley or the tension screw hole. So far I haven't been able to find any references to what parts are need to make them work. The bottoms look perfect. I've emailed RobotDigg to ask about them.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 01:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 02:04AM |
gaddcasey1
newline
I am trying to get some pictures or instructions from robotDigg, i will post if i get any.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 02:30AM |
newline
I heard back from Derek @ robotdigg... "I am afraid we use a corner idler."
I haven't heard back yet on where to get them or how much.
Sure wish the robotdigg web store had said that this was required, or at least had a picture that showed it
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 02:35AM |
jculver09
newline
In that image it looks as though the idler rides on bearings which I assume are pressed into the aluminum (I see no other way of affixing them in the image).
Have you measured the holes? My bet is you could find the bearings that fit the aluminum and mount your own shaft and bearings instead of their idler. I would avoid their idler because the flanges are almost guaranteed not to align with where your belt will want to ride (I could be wrong though), this will cause the belt to slowly shave itself away on the flange, over time causing the belt to fail.
My fix would be to fit the bearings into the aluminum (bearings will probably be 608 or 624 or something else common in the reprap world). Get a bolt long enough and large enough to match the ID of the bearing, and throw a stack of bearings on the bolt so that no matter where the belt wants to ride it will be on smooth bearing, no gaps, no flanges, no problems.
The two holes next to the idle make me think the whole assembly could be held in with a plate that is not shown (rather than press-fit bearings). If you go the idler route I would ask more questions about how it is held in place (additional hardware/parts).
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 03:02AM |
newline
gaddcasey1
newline
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 03:34AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 09:24AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 09:35AM |
Flish
You could print some spacers or cut off the those mound shaped parts from the existing corner for spacers. Just a thought...
What color did everybody get? I ordered black but seeing the above pic of the blue I'm kinda digging it.
Anybody order any of the other parts? the carriges don't seem to need to be aluminum...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 10:21AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:07AM |
Flish
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:08AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:42AM |
Koenig
I ordered 5 of theese: "GeeTech StepStick DRV8825" and got them today, However I noticed that they had a slightly different pinout
than the steppers that came with the kit, see pic:
I assume that M0-M2 corresponds to MS1-MS3 and that FLT is the same as VDD, BUT the pins named 2A and 1B has switched places, and looking at the RAMPS thoose pins corresponds to the connectors for the motors so I should be good by just switching place on the cables for the motors right?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:53AM |
thevisad
They are a direct replacement for the a4988 drivers; however, your 16 step will be 32 step with the jumpers in the current place.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:56AM |
Mylation
Hey all! Started my build last night - following the manually as close as possible except I cut my rods down to 200mm for a total length of 250mm. I'm not 100% of where to place the carriages. From what I saw in this forum earlier, a 250mm rod length pushes the height right up to the top although we'll have to see.
In addition, the build manual is a little confusing about jumper placement on the RAMPS board. I get the microstep jumpers and I get the auto level servo but I putting the jumper at the pins marked in the attached photo with the blue arrow isn't clear. Any help?
Finally, I don't know if it's my slide rails or the tension on my belts but each of the axis seems more difficult to move by hand than it should. I could be missing something or it might not be as bad as it seems.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 11:59AM |
Koenig
thevisad
Are you really sure?
looking at this: [www.geeetech.com]
I get the sense A and B corresponds to the two phases of the motor, and thus switching 1B and 2A will make the motor not do what it is supposed to...?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 12:27PM |
thevisad
Koenig
thevisad
Yes, I am positive http://forums.reprap.org/read.php?94,164010
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:12PM |
hedgehogsmoker
I recently bought this folger tech kossel 2020 and assembled it according to the manual and set up firmware too. When I attempt to print the xyz motors will bring down the extruder 1mm from bed, then after a minute or so the extruder will slide off the bed, hit the bed and make tons of noise. It's completely stuck so I diconnect and power off.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:23PM |
hedgehogsmoker
Do you mean where it says -1.4 offset. Should I put 0? These instructions are unclear.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 05:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2015 06:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 01:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2015 02:21AM |
