Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 02:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 02:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 02:20PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 03:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 04:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 05:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 07:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 07:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 07:51PM |
Captain_Tim
paul_delta
If you want to go forward - start from vRef...
That seem to fixed the loud extruder noise. The X carrage is still stuck. I guess I need to take it off and have a look at it.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 07:59PM |
paul_delta
Captain_Tim
paul_delta
Some of us received this kit with sliders that are too tight. So tight that the adjusting screw doesn't make any sense. Just move slider up-down couple of times or insert something like piece of bamboo stick
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:02PM |
Captain_Tim
paul_delta
Captain_Tim
paul_delta
Well my troubleshooting leads me to believe the motor might have seized. The carriage alone moves fairly easily. I attach the belt and attach that to the motor, try to move it manually and it's virtually stuck. If I just pull the belt tight while it's not attached to the motor, it moves reasonably smoothly as well. Thus my conclusion is the motor. Any one else have an opinion on this matter?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:07PM |
Captain_Tim
paul_delta
It's easy to check - just switch X and Y drivers and see if the problem will move to Y or not.
That was my next step. It'll have to wait till tomorrow though after work. If it does end up being the motor, I would contact Folger for a replacement correct?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:20PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 15, 2015 08:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 08:07AM |
paul_delta
I spent a lot of time reading forums, etc to get answers to my questions. Memories will not last forever, so I decided to return something in the community while it is still fresh
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 04:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 06:34PM |
Captain_Tim
Bad News
The new X-axis now won't turn. The machine is powered off so it should be able to move freely correct? Looks like Folger will be getting an email asking for a new motor. I hope that will be some of the last of my problems.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 06:48PM |
llamatrails
Do you have the motor wires unplugged when trying to turn the motor by hand? On steppers, if you short one of the windings, it will not turn.
Pull the motor wires from either the RAMPS end or the motor end, and then try turning it.
Rick
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 07:45PM |
Captain_Tim
To those who have wired the Z-probe (not the servo arm, but the actual probe in the newer kits), how did you wire the resistors and ground it? Could I get an image of your wiring for reference? The new build manual give a wiring diagram, but that's it when it comes to wiring. Easy to know how to attach Endstops/motors/heated bed/and hot end heater, but the rest isn't as clear. Thanks for the help
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 07:52PM |
Captain_Tim
llamatrails
Rick
With the Motor connection disconnected from the RAMPS board, it is still stiff and doesn't turn.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 09:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 16, 2015 11:23PM |
paul_delta
Just repeat your calibration near screws, measure the Z difference in the center and multiply by 2.2. Add or substract the result to/from delta radius and repeat calibration.
But I suggest to find the center of plate (actually, the center of ABC towers triangle) first, as provided in video. In Marlin there is no procedure for that, so you can just use the rod or ruler to place endstops equidistant from the floor. The more your center is off, the more errors you will get near your screws after delta radius adjustment.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 17, 2015 08:20PM |
fattmann
paul_delta
I think I have determined that my printer is printing on an angled plane. I know that has been discussed in this thread, but the search function on here is god awful.
I took that difference, multiplied it, and adjusted as you suggested. The X+- seems to stay even, but the Y+ and Y- seem to be opposites of each other. When Y- is about 2mm above the bed, Y+ is closer to like 4mm when I add to the radius adjustment, and drops them when subtracted. No amount seems to level them out tho, there's always about a 2mm difference.
All my endstops are at the same height when measuring with a ruler. That being said I will probably pick something up tomorrow to try that rod method in the video.
Nozzle is centered above the actual center of the print bed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 17, 2015 08:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 17, 2015 08:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 17, 2015 08:53PM |
Captain_Tim
So while I wait for Folger to get back to me as to whether or not they'll replace the motor, I have a few questions to ask you guys.
1. When I manually position the effector to be what looks like in the center of the build platform, it appears that two of the 3 carriages are at equal heights, but the thrid one needs to be higher up then the other two to center the effector. What could cause this, and what could I do to fix it? All the arms, but one, off by about 1mm or so (can't remember if it's slightly longer or shorter), are the same size.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 17, 2015 08:55PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 18, 2015 04:48PM |
Captain_Tim
