Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 29, 2015 09:54PM |
wrangellboy
Delta_Stu
New owner of a FT Kossel here. Read through the entire 81 pages.
Was there a concensus on the length of the diagonal rods that allows a good compromise between width and height?
The rev.b manual mentions 240mm total length.
I just re-did my arms. The Rev A. called for 230mm end to end which was frustratingly short. The thing to do is to assemble the frame and measure from one tower at the bottom of your travel to the far opposite side of the bed. Subtract out your effector and truck offsets, and that will give you an arm long enough to reach anywhere on your bed.
I'll measure my new rods when I get home but if memory serves they ended up about 260 end to end, but that's on a rev A with linear sliders so your numbers will be different.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 29, 2015 10:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 29, 2015 10:05PM |
paul_delta
With previously recommended 230mm I was not able to print LCD box (finally I printed it with lot of support, rotated to 90 degrees) for my Kossel because the real printable diameter is 158mm with 230mm diagonal rod and FolgerTech carriages/rollers. Let us know how it prints with 260mm rods. Is the rod diameter still 5mm? I afraid that 5mm is not enough for 260mm length because of flexibility.
wrangellboy
Delta_Stu
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 30, 2015 05:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 30, 2015 06:05PM |
guitarhammer
I was having the same problem as MarkM92 with the "mintemp" error. Found that the sensor wires had been cut when crimped into the brass holder. Manufacturer error. Now to get a replacement somehow.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 30, 2015 06:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 30, 2015 06:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 30, 2015 06:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 01:19AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 01:25AM |
deisengard
Recently finished assembling my Rev B machine and have a number of issues, but here's the main one right now: Somehow the temperature readings for my extruder and heated bed are tied together. When I turn on the hot end, the temperature for both the hot end and the heated go up in tandem even though the heated bed is off. It's as if it's using the same sensor for both. When I do the opposite and leave the hot end off and turn the heated bed on, the same thing happens--both temperature readings go up. This seems to suggest they electrically tied together. Anyone run into anything like this before?
What would I need to change in the configuration if I wanted to use T2 for the heated bed thermistor instead of T1 to see if that works independently? I'm using the FT-supplied Marlin firmware.
Thanks in advance for any help!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 01:30AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 02:19AM |
deisengard
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:18PM |
deisengard
Thanks Paul. I switched the heated bed to T2 and it read different than the extruder, but real low (5 C) vs room temp (21 C) for the extruder. I figured it must not be reading anything on T2, but when I swapped the heated bed and extruder on the board and in software, the readings stayed the same--the heated bed (on T1) read 5C and the extruder (on T2) read 21 C. So T2 seems to be working ok, but maybe not my heated bed thermistor. When I turn on the heated bed, the thermistor reading does go up correspondingly, as though it's just reading 10-15 C lower than it should be. After letting the heated bed cool a while it now seems to be holding at 10 C. So I guess I have a defective heated bed thermistor?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:28PM |
deisengard
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:42PM |
wrangellboy
Anybody ever to try to convert the stock hot end to all metal? I have a couple rolls of petg and printing at 240+ with the stock lined hot end makes me nervous. I ordered this and installed it, but it jammed like mad on PLA. I know the standard answer is to buy an e3d, but petg just isn't worth an $85 hot end for me...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:46PM |
wrangellboy
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:48PM |
paul_delta
My stock FT hot end (rev.B.) is all metal - no plastic tube inside. I print with PETG, Nylon without any problem.
wrangellboy
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 12:54PM |
wrangellboy
paul_delta
wrangellboy
They must have upgraded the rev B then. My rev A. definitely has a liner. I figured the only difference would be the heat break, but the one I got wasn't really functional at all.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 04:13PM |
paul_delta
Update: oops, looks like you tried exactly the same part.
If your heat break barrel has plastic tube, you can just replace it with all metal one, something like [www.ebay.com]
no need to change the whole hot end that works good.
wrangellboy
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 31, 2015 06:45PM |
wrangellboy
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 01, 2016 03:18AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 02, 2016 11:17AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 02, 2016 11:00PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 03, 2016 12:22AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 03, 2016 03:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 03, 2016 09:06AM |
guitarhammer
Got mine built and running. The z is 2 or 3mm higher on the edge of the print bed than in the middle. How do I go about fixing this? I gather it is with end stop offset but I can't figure it out. G29 just makes everything climb to the top and crash into the stops.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 03, 2016 09:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 03, 2016 02:36PM |
