Delta Printer bad prints - Part II (ABS) February 24, 2015 03:13PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 03:46PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 04:23PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 04:53PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 05:03PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 05:48PM |
Stephanel
BTW: how much amperage do you have for your power source (if you use a heated bed, and have Nema 17 0.7A motors or similar)? Seems like 30A still is kinda stretching it...
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 05:59PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 06:01PM |
Re: Delta Printer bad prints - Part II (ABS) February 24, 2015 06:06PM |
Stephanel
I use am MK2Y 200 heated bed. I do not know what the resistance of that bed is. It's not listed on the sale page either...
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 12:29AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 02:51AM |
Stephanel
Hey!
Thanks! I tried using cura, but ended up with Slic3r. Didn't know it was so much better, seemed like Slic3r has all the necessary options as well... It printed nicely with PLA :-) But indeed, might be worthwhile trying out Cura now...
The problem with my current design is that I have no way to easily tighten the belts without a tensioner :-( Let me look into another method to tension this, or print yet another tensioner!
The hot end indeed is about 210degC. I will increase it, but my little power supply already has quite some difficulties managing the bed and hot end. Kinda strange as it is a 30A 12V power supply?...
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 08:47AM |
dougal1957
Stephanel
Hey!
This sounds like a similar problem I had in the early days.
I guess you are still using a Ramps board.
1 put a heatsink on the hotbed FET.
2 Get a fan blowing over the board.
when that Fet get's hot it starts to effectively shut down and doesn't let the amount of current to flow that is required.
Untill I did these 2 things I could barely get my hot bed to 90C (took about 40 mins to get there as well) with the 2 mods then 115 is easy and takes around 15 mins now.
and for what it's worth I print ABS at 110 bed 245 extruder temps (the extruder temp will vary depending on the filament you use. I use ESUN Filament which is excellent by the way and can be got from www.hobbyking.com make sure you are ordering from the EU Warehouse tho and not the HK one not only is it excellent quality it is very cheap approx. 15eur/Kg)
HTH
Doug
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 09:32AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 09:35AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 09:41AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 09:51AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 09:56AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 10:38AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:05AM |
Stephanel
It is probably like you say, the cardridge heater seems not to be able to heat the block up to 250degC. I have increased the power supply voltage to 13.5V and the supply at the RAMPS board to the extruder now reads about 11.7V. Still the extruder cannot exceed 238-242degC.
Strange, because I thought this was a standard 3D printer cardridge. Apparently, it is not and I have to look for a better one. Any suggestions as to what you use?
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:07AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:10AM |
Stephanel
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:22AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:40AM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:42AM |
Mine looks exactly like that, and has the same specifications... Not sure how to test these things if they indeed are 24V.Quote
dougal1957
Stephanel
I wonder if you may have got a 24V Heater by mistake any 12V 40 watt one should be able to take you towards 400-500 C easily (There are photos on here somewhere showing one glowing Red which is towards 900c or more for steel (Can't remember exactly been out of Mech Engineering for to long to remember those facts lol).
try one from RepRapWorld 12v 40W heater cartridge (they are in the Hague Netherlands)
Doug
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 11:55AM |
Stephanel
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 12:29PM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 02:10PM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 04:40PM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 06:18PM |
Re: Delta Printer bad prints - Part II (ABS) February 25, 2015 07:38PM |
