Ebay SINTRON Kossel Mini full kit July 31, 2015 06:36PM |
Re: Ebay SINTRON Kossel Mini full kit August 02, 2015 03:22PM |
Re: Ebay SINTRON Kossel Mini full kit August 02, 2015 07:01PM |
Re: Ebay SINTRON Kossel Mini full kit August 03, 2015 03:29AM |
Re: Ebay SINTRON Kossel Mini full kit August 04, 2015 09:33PM |
Re: Ebay SINTRON Kossel Mini full kit August 05, 2015 03:44AM |
Miamicraft
I cannot recommend this kit for a non-reprapper. The corners don't fit and I am going to have to print a new set. This is not a show stopper if you have another printer and don't mind spending 8-10 hours printing new parts. I have spent some time examining a couple of problems with the existing corner design and before I print I will make a couple of modifications including for the drop in t-nuts. Basing new design off file from thingyverse. He provided step files which are much easier to work with using Autodesk 360 (free). I will upload STL and Step files to thingyverse if successful.
Miamicraft
Olaf, wheels don't worry me too much as they are extremely hard and I see a lot of similar designs. Mega2560 definitely has limitations with no floating point and square root. Chinese ARM based boards with Smoothieware are reasonably cheap but I haven't taken the time to look at them. Is it as easy as just loading the binary and using a canned ini file on SD?
Re: Ebay SINTRON Kossel Mini full kit August 05, 2015 11:50PM |
Re: Ebay SINTRON Kossel Mini full kit August 06, 2015 07:12AM |
Re: Ebay SINTRON Kossel Mini full kit August 06, 2015 07:15PM |
Re: Ebay SINTRON Kossel Mini full kit August 07, 2015 02:16AM |
Re: Ebay SINTRON Kossel Mini full kit August 07, 2015 02:19PM |
Re: Ebay SINTRON Kossel Mini full kit August 08, 2015 04:05AM |
Re: Ebay SINTRON Kossel Mini full kit August 11, 2015 08:05AM |
Re: Ebay SINTRON Kossel Mini full kit August 11, 2015 05:56PM |
Re: Ebay SINTRON Kossel Mini full kit August 11, 2015 10:23PM |
Re: Ebay SINTRON Kossel Mini full kit August 12, 2015 01:08PM |
Do you still need this done? I have Solidworks and im more than capible to help you with this little fix.Quote
Miamicraft
Emailed a copy to a friend with Solidworks. No joy.
[attachment 59493 BadSTL.png]
I was just trying to flatten the area (circled) behind the t-nut hole to allow the t-nut to fully grip the 20/20.
Re: Ebay SINTRON Kossel Mini full kit August 12, 2015 02:04PM |
Re: Ebay SINTRON Kossel Mini full kit August 12, 2015 02:45PM |
Re: Ebay SINTRON Kossel Mini full kit August 12, 2015 11:04PM |
Miamicraft
Nebbian,
The belts are tightened by sliding the top of the machine (triangle) up the extrusions. If all the belts are the same length no problem.
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 05:35PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 06:51PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 07:40PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 07:45PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 07:59PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 08:38PM |
Re: Ebay SINTRON Kossel Mini full kit August 13, 2015 11:47PM |
Re: Ebay SINTRON Kossel Mini full kit August 14, 2015 01:00AM |
Re: Ebay SINTRON Kossel Mini full kit August 14, 2015 02:49AM |
Re: Ebay SINTRON Kossel Mini full kit August 14, 2015 02:55AM |
nebbian
Are either of you considering twisting the belt so that the idler bearing at the top rests on the smooth part of the belt, rather than the teeth? I've read about several people who did this, which reduced noise, vibration and inaccuracy of the print. The Ormerod does this, which seems to be a good idea to me.
Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 08:11AM |
