Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 07:16PM |
Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 09:34PM |
Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 10:09PM |
Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 10:12PM |
Re: Ebay SINTRON Kossel Mini full kit August 18, 2015 11:17PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 03:12AM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 09:04AM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 03:37PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 08:24PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 09:12PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 09:50PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 10:17PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 10:33PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 10:35PM |
Re: Ebay SINTRON Kossel Mini full kit August 19, 2015 10:57PM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 01:34AM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 02:16AM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 03:39AM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 04:17AM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 11:06AM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 06:30PM |
Re: Ebay SINTRON Kossel Mini full kit August 20, 2015 10:44PM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 02:37AM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 02:48AM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 03:07AM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 05:02AM |
nebbian
@o_lampe,
Good call on the cooking water for 10 miuntes, I'll give that a go.
Regarding the 0.35 mm, drilling and gluing, that's certainly an option. My issue is that I'm not confident that at the end of it I'll have joints that are any closer than just by using the threaded rods and cutting threads into the rod ends.
To visualise this I got out my calipers and measured 0.35mm. In the old language this is 3/5ths of 5/8ths of f..k all I mean how would you measure this?
The only way I can think of is to get a 3mm rod (from where? You can't use a 3mm threaded bolt as this is less than the diameter of the hole in the ball), somehow permanently attach it at exactly 90 degrees to something solid, get another 3mm rod, somehow put this on a sliding trolley so that it stays at exactly 90 degrees to your solid object, put yet another 3mm rod at something like 220 mm from the first one, slide your diagonal arm onto the first two rods, and measure from the second to the third rod with calipers.
And be sure not to pull too hard on any part, as this will deflect everything more than the distance you're trying to measure.
Yeah not easy.
Would 0.35 mm actually make any difference to the geometry anyway? I've tried drawing parallelograms and triangles in the same dimensions as the rod arms, which is just confusing me more.
Maybe I'm overthinking this.
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 04:21PM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 07:28PM |
Re: Ebay SINTRON Kossel Mini full kit August 21, 2015 09:21PM |
Re: Ebay SINTRON Kossel Mini full kit August 22, 2015 03:07AM |
