Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 03:06AM |
o_lampe
@nebbian
Definitely time to measure the power supply output voltage. In the end, they sent you a 15V PSU with the kit
That would also explain the arduino problems. The 5V regulator is overheating...
-Olaf
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 03:25AM |
nebbian
Errr no I'm using a 20 amp power supply instead of the 10 amp supply they provided. Mine measures 13.8 volts, 13.5 when under heavy load with all heaters on full.
13.8V vs 12V won't cause a linear regulator to overheat, especially at the low power levels we're talking about. The regulator blew because I shorted the 5V line with a trimpot cover that came loose and shorted out some components on the stepper driver board.
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 03:38AM |
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 03:50AM |
o_lampe
How does a 8bitter work on a delta with a 12864 dot matrix display? I thought, that would be impossible?
o_lampe
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 04:03AM |
nebbian
o_lampe
Yeah it doesn't. I don't know anywhere in this thread that people are claiming to use that display, either. I think that dc42 is mistaken. I also think he might also have missed the part where I replaced the 5V regulator with a higher powered one.
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 08:51PM |
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 09:11PM |
Re: Ebay SINTRON Kossel Mini full kit September 09, 2015 09:17PM |
Re: Ebay SINTRON Kossel Mini full kit September 12, 2015 11:23PM |
Re: Ebay SINTRON Kossel Mini full kit September 12, 2015 11:44PM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2015 03:31AM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2015 05:04AM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2015 05:30AM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2015 06:41AM |
Re: Ebay SINTRON Kossel Mini full kit September 14, 2015 03:05AM |
Re: Ebay SINTRON Kossel Mini full kit September 14, 2015 03:41AM |
Re: Ebay SINTRON Kossel Mini full kit September 14, 2015 10:45AM |
Re: Ebay SINTRON Kossel Mini full kit September 14, 2015 09:36PM |
squall
I had an old PC power supply (18 Amps) which I hooked up to test out just the motors and movement.
Are we supposed to connect the power supply to both the 5A and 11A markings on the RAMP board? The pdf instructions only show the 5A.
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 04:34AM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 05:01AM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 07:20PM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 08:37PM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 08:48PM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 10:15PM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 10:52PM |
Re: Ebay SINTRON Kossel Mini full kit September 15, 2015 11:24PM |
Re: Ebay SINTRON Kossel Mini full kit September 16, 2015 11:08AM |
Re: Ebay SINTRON Kossel Mini full kit September 16, 2015 06:47PM |
Re: Ebay SINTRON Kossel Mini full kit September 17, 2015 06:31AM |
