Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 05:26AM |
patrol420
mine seems to be working fine now apart from when its doing infill it seems to speed up the extruder too much, when doing solids its fine? ive calibrated the extruder. do i have to change the acceleration value for e in firmware?
Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 11:32AM |
theda1
My Heatbed would not come up to temperature at all. (86Degrees instead of 110)
Larger wire (20 Amp) from Power supply to 12 volt relay the Thermister on the heatbed will cycle Ramps and then the relay to keep the temperature Correct and connect Ramps output to Relay to actuate
All heat problems on the ramps board disappear and full voltage can get to the heat bed.
Car relay is 30 Amps and cheap.
Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 01:05PM |
Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 02:00PM |
nebbian
Did anyone else find that they had to set the MAX_BED_POWER to 275 to stop the relay clicking like a maraca?
Re: Ebay SINTRON Kossel Mini full kit October 17, 2015 09:06PM |
Re: Ebay SINTRON Kossel Mini full kit October 18, 2015 04:51AM |
nebbian
theda1
Thanks for posting, theda1!
I have been having problems with my heatbed drawing too much current, even with the duty cycle set low and a fan blowing on the polyfuse. For some reason I never considered a relay. Today I bought a relay, and wired it in with a 15 amp fuse. No more problems with the polyfuse turning off the power at startup. 4:30 to get from room temperature to 100 degrees C. That's not bad, I can live with that.
Anyway thanks again for posting, I'm pleased as punch with my heatbed now.
Re: Ebay SINTRON Kossel Mini full kit October 18, 2015 11:24PM |
My RAMPS smoked. The poly fuses are terrible and I did the inline Car fuse trick and it works. But I also have a fan blowing on the RAMPS now.Quote
theda1
I to had this problem..cheap 30 Amp Car relay did the trick and 20 Amp wire (so it does not heat up and become resistive)
Aurduino board operates the relay with Thermister operating Arduino board so temp stays good and No more big Loads on the Ramps or Arduino
I still had to wind up the Power Supply to 13.6 volts to get 100 Degrees
Re: Ebay SINTRON Kossel Mini full kit October 18, 2015 11:29PM |
Tha_Reaper
I have it moving! took me a while to figure out some error messages, and a bug that caused the printer to shut down immediately because of too high temperature (turns out thermocouplers are set as default....
Just one thing: When the printhead moves to the edge of the print area, my printer emits a noise like its having a severe asthma attack. pretty high pitched wheezing... is it supposed to do that?
link to a video: [www.dropbox.com]
near the end you'll hear my wife saying: "that doesn't sound very healthy...". It may just be something that i'm doing wrong...
Re: Ebay SINTRON Kossel Mini full kit October 18, 2015 11:40PM |
hacker
o_lampe
@nebbian Sorry for OT, but could you put the sloppy Traxxas joints in cooking water for 10mins. and let them cool down in it?
We used to do that with all plastic parts back in RC-Car days...
I´d like to know, if the slop is gone by the treatment..
THX
-Olaf
I ordered two sets and some 5-6 turned out sloppy. Treatment fixed approximately half them.Three are still sloppy.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 12:47AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 01:27AM |
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 02:38AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 02:48AM |
nebbian
Does anyone know which thermistor setting to use in the marlin configuration? I seriously don't trust the Sintron guys to know or set up their software properly.
I've been using 1 for the hotend, but am having to go to 255 degrees for printing ABS which seems high to me. If I go lower in temperature then the parts have layer delamination issues when you really stress them. 255 is the lowest temperature where the layers really fuse together properly and you can't separate them with a strong thumbnail jab.
I'm thinking that I've got the wrong thermistor selected, and it's not actually that hot. But who knows. I don't have a thermometer that can reliably measure the hotend properly.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 04:23AM |
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 04:35AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 04:48AM |
nebbian
Thanks Sir Death
I'm printing those perimeters at 40 mm/s (20 mm/s for external perimeters, but all of them are delaminating), with a 0.4mm nozzle and 0.1mm layer height.
The level of detail is really nice, repeatability is excellent, the only concern is that I might be getting a bit too hot. If you say that it's normal then I'll just shrug my shoulders and accept that that's just the way to do it I guess.
Thanks for your help.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 08:22AM |
nebbian
DrTak,
I've found that the most reliable way to calibrate the output size is to measure your diagonal rods as precisely as you can. You need to measure from the centre of the round ball to the centre of the other round ball. Plug that number in, and then calibrate the smooth rod offset so that you get a flat print surface. Then you're DONE with adjusting those measurements. No more printing, no more measuring, no more adjusting, no more scratching your head. None. Step away from the printer...
I don't know how many of those circular delta calibration prints I printed but it would be more than a dozen. In the end I realised that I was over extruding, which was causing my measurement differences.
For reference I set up a friend's delta yesterday via a video stream and remote desktop session... the technology we have available to us now is amazing. It took 4 hours to go from a freshly built machine to one that prints calibration cubes precisely (well, within 0.1mm when measuring the outside of the cube, which is well within tolerance). In fact the very first cube we printed was perfect, apart from the layer fan cooling the print head too much so the output stopped.
The reason it was so quick was that we followed the method of measuring the diagonal rods as well as we could, then did the paper test lots of times both in the centre of the bed and the edges, which gave us a perfectly flat print surface. Once that was done you are FINISHED with calibrating print sizing.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 08:24AM |
Sir_Death
nebbian
Thanks Sir Death
It is just important, that the cool end stays cool! - Else the Effector might melt.
When you heat up to 255°C and the Hotend cooling fan is on, it must be possible to touch the cool end without burning! - then everything is OK.
Some guys even apply Teflon film on the upper end of the heatbreake (hollow screw) to stop heattransmission to the cool end - I think, this is not necessary.
Right now I'm printing with 0.2mm layer height, and the external Perimeter and Top + Bottom Layer with 5mm/sec (everything else 30mm/sec) 0.4mm nozzle
Level of detail is really good, but I've having to big size :-) 10mm box is 10.55mm - have to check, where it is comming from...
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 09:08AM |
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 10:22AM |
Sir_Death
DRTak
Ha. Thats the same issue I had. And your unit is perfect. I forgot to mention. I also changed the perimeter to 1mm and that fixed my sizing issue as well.
I'm using Slic3r - where do you change the Perimeter to 1mm?
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 11:04AM |
hacker
Sir_Death
DRTak
I don't think you can directly, but you can look up the perimeter extrusion width at the beginning of g-code and set the number of perimeters accordingly. But I'm not sure you have the same problem… If it is about extrusion width, maybe you want to do this — [github.com] — with Slic3r.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 11:48AM |
Sir_Death
hacker
Sir_Death
DRTak
Thanks for the Link - I already thought of the extrusion width, but had no Idea on how to Check it!
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 01:02PM |
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 01:04PM |
Sir_Death
hacker
I think if it's extrusion width the error stays constant if you print 10x10 and 50x50 cubes. If it's assembly dimensions it should probably be constant percentage.
I thought of the extrusion width, because it is the same on 10, 25 and 60mm
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 03:59PM |
hacker
Sir_Death
hacker
Slic3r calibration might help then. Also make it's a good idea to calibrate e-steps first. Though technically extrusion multiplier and e-steps have the same effect, I believe.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 04:43PM |
Sir_Death
hacker
Sir_Death
hacker
After some Testing:
E-steps are 100Steps/mm, not 94 as Sintron says.
But:
; external perimeters extrusion width = 0.40mm
Measured: 0.75mm!
First try is setting "External Perimeter" in Slic3r manually to 0.4mm width, if that does not work, I'll try Setting to 50%....
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 05:17PM |
hacker
My step/mm are 104.027 to the best of my calibration. And the extrusion multiplier is normally within 0.9-1. I think, though, you should look at perimeters, not external perimeters. Not sure why. Or else I'm always doing it wrong ;-) But .75 is still a bit off.
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 05:20PM |
Sir_Death
hacker
I'm on the way..... 0.6.... next try running...
Seems it was the Filament! - Measured at the beginning: 1.72 - 1.78 --> 1.75 OK
Now: 1.89 to 1.96 --> now I know where the overextrusion is comming from...
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 05:21PM |
Sir_Death
DRTak
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 05:24PM |
DRTak
Sir_Death
DRTak
Print Settings > Advanced > Perimeters
