auto level crashing into bed when done September 11, 2015 07:43PM |
Re: auto level crashing into bed when done September 12, 2015 03:21AM |
Re: auto level crashing into bed when done September 12, 2015 12:03PM |
Re: auto level crashing into bed when done September 12, 2015 03:11PM |
xile6
I fix my problem.
Turns out i had the Z max set to high/low i guess. These delta type printers are a little backwards to me.
I had it set at 280 and i been printing for a a few days on my old setup.
Then when i change the autoleveling from hotend with micro switch to inductive probe i had the problem.
I fix it by redoing the Z max. I beileve i ended up with 275.4
I have no idea why this needed to be change if the 280 was working fine before. I printed out over 12 hour of stuff on that setup without problem.
But either way the problem is fix.
Re: auto level crashing into bed when done September 13, 2015 03:01PM |
Re: auto level crashing into bed when done September 13, 2015 03:12PM |
Re: auto level crashing into bed when done September 13, 2015 04:09PM |
Re: auto level crashing into bed when done September 13, 2015 09:29PM |
Re: auto level crashing into bed when done September 14, 2015 07:40AM |
Re: auto level crashing into bed when done September 14, 2015 04:48PM |
LarsK
I have no idea why it is doing that. It is wrong. It should probe the actual point.
Try
G28
G1 Z10
G30 P1 X55 Y0
G30 P1 X-55 Y0
Re: auto level crashing into bed when done September 14, 2015 06:44PM |
Re: auto level crashing into bed when done September 15, 2015 06:37PM |
Re: auto level crashing into bed when done September 15, 2015 06:44PM |
Re: auto level crashing into bed when done September 15, 2015 07:41PM |
Re: auto level crashing into bed when done September 15, 2015 07:59PM |
Re: auto level crashing into bed when done September 16, 2015 11:19AM |
Re: auto level crashing into bed when done September 17, 2015 04:25AM |
Re: auto level crashing into bed when done September 17, 2015 04:12PM |
Re: auto level crashing into bed when done September 17, 2015 08:57PM |
Re: auto level crashing into bed when done September 20, 2015 12:42PM |
Re: auto level crashing into bed when done September 20, 2015 01:59PM |
Re: auto level crashing into bed when done September 20, 2015 06:57PM |
LarsK
Instead of actually understanding your problems with alignment you now have some numbers which, assuming they are anything close to what you posted two posts backs, are completely off.
Your printer firmware have saved the day by finding a compromise that allows you to print. But double digits endstop corrections and full digit tower adjustments is wrong.
I hope for you that you can get some prints out now and enjoy your printer - It seems that is the priority for you, which is fair enough.
But this thread and the results should be read with a good deal of skepticism and not be used as an example of how to calibrate a delta. The Rich Cattell auto calibration (G30 A) is undoubtedly a powerful tool but it should not be applied as above.
Re: auto level crashing into bed when done September 21, 2015 05:16AM |
